Question about Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher works but is no water insider - Bosch 24 in. SHU53 Built-in Dishwasher
E1 error on Baumatic BAD6003
If you are getting E1 error then the dishwasher is suggesting that water is getting in but not enough. But if you are getting no water into the dishwasher then the water inlet valve inside it is faulty. Have you checked if there is water inside the dishwasher when you get E1 error. Another thing to find out is the water pressure specification of dishwasher and whether it is consistent with the mains pressure in the house. Usually there should be a plate on dishwasher door which would give water pressure required.
Apr 20, 2014 | Baumatic Dishwashers
Water does not come into the dishwasher. can hear the pump, the heater works, the indicator lites illuminate, but water does not come in. The water supply is hooked up and turned on, there is good flow...
Usually the problem is the soleniod valve that lets the water into the dishwasher...
here is a tip that I wrote that gives many more details about this problem...
Dishwasher Trouble No Water entering Dishwasher
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Aug 21, 2010 | Dishwashers
My dishwasher was working fine until yesterday, now it doesn't seem to use all the soap, I tried 2 times and there was still soap left over.
Hello there:
It doesn't get the dishes clean dot_lineone.gif 1. No water
Make sure you get water to the dishwasher. Check to see if the watershut-off valve (located under the sink) is open. If you get water tothe dishwasher, but there is still no water inside during the fillcycle, the problem might be with a faulty water valve (located at thebottom of the dishwasher, behind the kick panel, on either side), inwhich case replace the water valve. There are also screens and filters that need to be cleaned to ensure proper operation so please check these as well
2. Not enough water
If there is not enough water, the dishes would not get cleaned. Thiscould be caused by a partially closed water shut-off valve (locatedunder the sink), or a faulty dishwasher water valve (located at thebottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Makesure there is no debris blocking the holes inside each spray arm. thee are also screens and filters under these arms that may need toi be cleaned
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.if not increase the hot water heater temp
5. . Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside thedishwasher. Try cleaning you dishwasher using a dishwasher cleaner.There are a few out there, we recommend Dishwasher Magic®.
Jan 13, 2010 | Frigidaire 24 in. FDB126RB Built-in...
My dishwasher is not cleaning well and not rinsing well.It's leaving a film on the dishes'
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
Concerning the Film.
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaning agent. Try Dishwasher Magic. It is a very good cleaner.
Dec 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dishwasher leaves soap film
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning your dishwasher by using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
Aug 31, 2009 | Frigidaire Dishwashers
Dishwasher sprayer arms not working
you are not getting enough water inside of dishwasher.you can pour 1gal of water inside. to see if arm work better should be 3 or 4 inches of water in side of dishwasher. water valve maybe bad or dirty screen inside of valve.ck to see if enough water is in bottom of dishwasher.ck to see if flote switch in left front corner of dish washer is moving up and down.
Aug 12, 2009 | Kenmore Dishwashers
Dishes have a powdery residue
NOTE(((excessive calcium build up inside the dishwasher can cause this as well. I recommend cleaning the inside of the unit with a dishwasher cleaner called Dishwasher Magic. its good stuff and it will get rid of that calcium build up)))
Jul 30, 2009 | Jenn-Air JDB1105AWS Stainless Steel...
Kitchen Aid dishwasher is not cleaning like it use to
Check the following to address this issue further.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there.
Jun 21, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Water into washer
Jun 05, 2009 | Roper 24 in. RUD3000 Built-in Dishwasher
My dishwasher sounds like its working but when i open it nothing
1. No water
2. Not enough water
May 30, 2009 | Bauknecht 24 in. GSX7551 Built-in...
Bosch 24 in. SHU53 Built-in Dishwasher Logo
26 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
