Question about Pets - Others
The slap com sign up - Pets - Others
05 Dodge Neon 2.0 Head gasket fail between #3 and #4 cylinder.
YES SOUNDS LIKE A FAILED WRIST PIN, PISTON SLAP IS MOVEMENT OF PISTON INSIDE OF CYLINDER
Feb 22, 2017 | Dodge Cars & Trucks
NAD 3150 cuts out
Hello. Slapping and it working is a tail sign that there is a loose connection, bad solder point, loose wire. When a circuit board gets hot, solder joints separate and an opening occurs in the circuit. Open it up and get a visual. Look for cold solder joint, make sure all the connectors are secure. Good Luck
Feb 13, 2014 | Audio Players & Recorders
My keeway superlight 125cc I have fitted a 150cc
Hi, Anonymous first thing is you forgot to measure the aftermarket for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
piston slap issue
http://www.antiquemotorcycle.org/bboard/showthread.php?19951-What-Causes-Piston-Slap-amp-or-galled-cylinders KEEWAY SUPERLIGHT 125 150 SCOOTER SERVICE REPAIR PDF MANUAL DOWNLOAD 2006... $12
Keewayparts com Genuine Keeway Parts Shipped Worldwide
KEEWAY HURRICANE User Manual
Aug 05, 2013 | Keeway Matrix 150 Motorcycles
What are the signs of a bad computer in a 1997 gmc sonoma
No one sign. Us mechanics perform what we call the slap test. With the car or truck running. Take the ecm out of the holder, leaving the terminals all connected, SLAP the ECM. If the vehicle shudders or stalls, Your ECM is bad.
Jul 22, 2012 | 1997 GMC Sonoma
Alfa 147 80000 miles on an 02 plate when warm the idling noise is louder for about 30 secs then dissapears doesn't happen when cold!
If in all other respects the engine seems to be fine, then it's most likely piston slap. It's a sign of a worn engine and the only cure is a rebuild, but in itself, piston slap is just an annoyance rather than a problem. The piston bores are tighter when the engine is cold and so the pistons are more tightly constrained and less able to slap.
But at 80k miles you really shouldn't have piston slap yet, even on an Alfa. I suggest that you take the car to an experienced mechanic to get the oil pressure checked: it could be that the oil pump is failing and if that goes completely you will be looking at a replacement engine due to consequential damage. Used Alfa 147's of that age are usually dirt cheap though, so if you do need a donor engine it may prove to be more cost effective to sell yours for spares and buy another 147.
Mar 10, 2011 | Alfa Romeo 145 Cars & Trucks
Door will not open on dvd player
Is there a "lock mechanism" that will need to be undone?....accordianman
Jan 19, 2008 | TruTech TT320
Black screen
Well, this is a fatal error that happens with the CCD chip. According to this page, you can try one of two things: You can slap it firmly against your hand in an effort to fix the broken transmission, or you can call up Nikon. According to the link provided above, they are supposed to repair it free of charge and regardless of warranty.
- 2 Bunny
Dec 04, 2007 | Nikon Coolpix S1 Digital Camera
Pets - Others Logo
300 people viewed this question
Top Pets - Others Experts
Ross Keen
Tom Chichester
Ruth summersides
Are you a Pets - Other Expert? Answer questions, earn points and help others
