Question about Toshiba 55ZV650U 55 in. LCD HDTV
Toshiba 55zv650u won't power up
Will not power on period
WHY DO I GET DISTORED SOUND ON MY TOSHIBA 55ZV650U
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Jul 28, 2014 | Toshiba 55ZV650U 55 in. LCD HDTV
Toshiba 55zv650u will not turn on
That is an odd value! If it is swollen, replace it.
Jan 23, 2013 | Toshiba Computers & Internet
Toshiba satellite l305d-s5934 Won't charge battery dont power On
POWER SUPPLY & BATTERY PROBLEM
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 25, 2012 | Toshiba Satellite L305D-S5934 Notebook
No video for toshiba regza 55zv650u TV
Hello JAPP,
This failure is in the main board.,All the HDMI's are on the main board. If you can find a main board and DIY, then it might be cost effective to fix the TV.
Jun 08, 2017 | Televison & Video
Power light blinks 3 times over and over but wont turn the set on
Did you ever find a solution to this. Mine does the same thing.
Aug 17, 2011 | Toshiba 55ZV650U 55 in. LCD HDTV
I have a new Toshiba 55ZV650U TV, appro. every 5 hrs the audio misses up, sounds like the audio goes into reverber, this last for appro.10 minutes, then goes back to normal. We usally just cut TV off, then...
Contact Toshiba support by phone (look in your owner's manual for the toll free number). They issued new firmware last week to fix several HDMI audio and video problems. They will send it to your home with easy to follow instructions. I hope this helps.
Mar 16, 2010 | Toshiba 55ZV650U 55 in. LCD HDTV
I want to mute my 55zv650u tv with out half mute
Unfortunately this is a feature built into the software of the set and there is no way to get rid of it. Thanks for using fixya though.
Nov 06, 2009 | Televison & Video
Toshiba 55ZV650U 55 in. LCD HDTV Logo
65 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
