Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
High copper level - Intex Automatic Salt Water System for Above Ground Saltwater Pool
    Scholar:
    New Friend:
  • 66 Answers
I agree with Charles T Nevin but also watch your active ingredients on your chemicals to make sure you are not adding the copper when treating. Common with algaecides especially.
Posted on Apr 16, 2014
2 Suggested Answers
woodchuck789
  • 4059 Answers
SOURCE: let's start by saying my
A sequestrate from your pool supply can prevent problems from the copper. The water you are adding needs to be checked for copper and algaecide especially for mustard algae will have copper. Diluting it with a water chance is the most common way to take care of the problem.
Posted on Jun 21, 2011
How can you decrease copper levels?
copper levels have to be lowered by delution (adding more water)
your daughters hair rinse with lrmon juice the reason this probably happened your PH and alkalinity are both probably low PH should be between 7.2 and 7.6 alkalinity shouls be between 80 and 120 if un aware of pool chemistry take water to a professional
Jul 14, 2014 | Intex Automatic Salt Water System for ...
Can I run saltwater system with high copper?
no. copper level should be 0.0
if you have a high copper level, you are about to experience severe equipment failure.
Jul 03, 2014 | Intex Automatic Salt Water System for ...
Green
Green is an indicator of metal in the water or no sanitizer. Check your sanitizer level and have your pool service company check for metal. Could be very high acid level ... eating at anything copper in your system.
Jun 12, 2013 | Intex Automatic Salt Water System for ...
Sta Rite 333 Btu Natural Gas Heater Maxetherm Sr333na Leaks water and high copper in my water
It sounds like your water has either been running at a low pH level, or you have a salt system. Basically your heat exchanger coil has dissolved into your pool water.
The exchanger can be replaced although it is pricey. I would recommend replacing it with a cupronickel coil. This is far more resistant to the type of corrosion you have experienced. Just be sure to keep a closer eye on the pH also.
Feb 19, 2013 | Sta Rite 333 Btu Natural Gas Heater...
My climate control only works when i Have it on high
The switch needs to be replaced or cleaned, there r 4 copper connections that regulate the power going to the motor, the previous owners probly only used hi so the connections r dirty
May 13, 2012 | 2004 GMC Envoy
Let's start by saying my pool water was fine and then the high salt alarm went off we drained 20% of the pool and now are copper levels are high i have drained 20% and refilled and then another 20% and...
Jun 21, 2011 | Intex Automatic Salt Water System for ...
I have a inter saltwater system and am using it on a 14 ft pool. All levels appear ok except copper. Copper is low despite 2 boost cycles. I was cautious not to add too much salt or Cushitic acid when...
I'm not sure about an Intex saltwater system, but you don't want the copper levels to be too high. This can cause staining on the pool liner that is difficult to get rid of. I'd recommend taking a water sample to a local pool store and have them check all of your levels. Since the chlorine produced by a salt chlorine generator is unstabilized chlorine, you need to make sure you have the cyanuric acid levels within the proper range. This can be increased by adding stabilizer or conditioner.
Jun 16, 2011 | Intex Pool & Spa
I havent used my scan disk cruzer in months and now i plug it into my computer and it lights up but i cant open it up to retrieve or put info on it
Try cleaning the USB pins with cotton swab to clean all copper connectors in it.
If the above solution doesn't work, you may need to do Low Level formatting to it.
Low Level Formatting is very much different than High-Level Formatting (High-level formatting occurs during operating system installation, or when adding a new disk.).
Low Level Formatting on Windows Environment can only be done through "Control Panel > Administrative Tools > Computer Management" or Run "compmgmt.msc".
On the Computer Management Tools window click on Disk Management under Storage.
Select which drive your SanDisk Cruzer is located then Right click select Format... from there you may choose what File System to use. i advise you to use Fat for a fixed formatting.
Hope this helps. Don't forget to rate.
Jan 06, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Copper coils of aqua pro corroded and leaking on heater
Replace coil. This damage is a result of a continually low ph and alkalinity condition or an extremely high level of chlorine. Test water frequently
Aug 07, 2009 | RTO Aqua Pro Systems Pro 600 60,000 BTU...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
63 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
