Question about Sherwood Audio Players & Recorders
We bought a RX-4109 receiver and the connection is a very loud noise. What are we doing wrong?
SOURCE: need remote code for sherwood
Comcast came and the receiver / tv was not capable of being run by another remote as far as volume, just off and on
Posted on Jul 21, 2008
  • 7 Answers
SOURCE: sherwood rx-4109 power shuts off
The output transformers may-be gone
looking at +$50 AUS
for just the parts
or a licensed service
for about $150 AUS
Posted on Apr 16, 2009
  • 30 Answers
SOURCE: trying to program my At&t Uverse remote to my
Sherwood Receiver/Amplifier 5027 Sherwood Receiver/Amplifier 5027
always press the mode key of the device they want to control before pressing any other key
Power on the device
  1. Press and hold the appropriate Mode key (TV, DVD or AUX) on the remote control.
  2. Without releasing the chosen Mode key, press and hold the OK key simultaneously.
  3. Release both the Mode key and the OK key at the same time.
    All the Mode keys should flash twice.
    1. Enter the four digit setup code by pressing the number keys (0-9) on the remote control.
    2. The Mode key will flash three times indicating correct entry and return to normal operation.
    • When an invalid code is entered, the selected Mode key will give a long flash to indicate that the Member has not entered the setup code correctly. Start over beginning at step 3.
    • Should the remote control time out before the Member completes the code setup, they will need to start over.
    1. Point the remote control at the programmed device and press the Power key once.
    2. The device should turn off.
    • If it does not turn off, repeat steps 2 through 6 trying each code for the brand until the correct code is found.
    1. Repeat steps 1 through 7 to program other devices if needed.
    2. Press the appropriate Mode key on the remote control to work with the selected device. To use the remote control for the Member's U-verse TV Receiver again, have them press the AT&T Mode key.
    Posted on Sep 20, 2009
    jdvillanueva
    • 2098 Answers
    SOURCE: need the 5digit code for the sherwood rx 4109
    Hi Woodyscarava,
    You may look the remote code in this link http://www.comcast.com/corporate/customers/customer_support/remotes.html. Select the model of your remote control and view the manual.
    Hope I helped you.
    Have a nice day!
    Thanks for using Fixya.
    Posted on Feb 16, 2011
    danbusa
    • 185 Answers
    SOURCE: my dish network remote control
    Try these codes: 670,646 The steps for programming these remotes are below:
    1.) Hold down the aux button until all four mode buttons are lit.
    2.) Enter the three digit code and press pound (#)
    If those codes fail try the steps below they are for what is called a Power Scan. This should resolve this unless there is a compatibility issue.
    1.) With the desired equipment on, press and hold the correct AUX button until all mode button backlights illuminate (about 3 seconds), then release.
    2.) press 0 for a TV, press 1 for a VCR/DVD, press 2 for any other device, then press *.
    3.) Press and release the large red Power button.
    4.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
    Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
    To verify the code works try several different functions for that equipment.
    Daniel Busa
    DISH Network Customer Service
    Posted on Feb 25, 2011
    How do I connect my RX-4109 to a Crown power Amp?
    If your Sherwood has preamp outputs, you can connect directly to the power amp inputs.
    Sep 13, 2014 | Sherwood RX-4109 Stereo Receiver Black
    I have a Sherwood RX-4109 receiver. The right side channel has low volume and cracks, can it be fixed?
    show me a picture so I can tell if it is even worth fixing. you may be better off getting another one.
    Aug 13, 2014 | Sherwood RX-4105 Receiver
    It stopped, while not being used.
    Possibly taken the fuses out suppllying the power stage.
    Mar 12, 2014 | Sherwood RX-4109
    What is a compatible turntable for my Sherwood rx-4109 receiver?
    many decks have pre amps or need preamps. hence the reason why you have distorted sound i would guess. you need the opposite of what you used. What record deck did you try?
    Jan 06, 2013 | Sherwood New-RX-4109 STEREO RECEIVER WITH...
    Can I download manual for RX 4109?
    Hi,here is the link for your download...
    Take care and please Remember to rate/vote and give me 4 Thumbs Up
    for Helping out the Community :)
    Hope this helps!
    http://www.sherwoodusa.com/prod_rx4109.html
    RX-4109 Remote Controlled Stereo Receiver with Phono Section
    Unlike the budget stereo receivers now flooding the entry-level price points at dealers across the country, the Sherwood RX-4109 is designed and built in-house with the same quality and attention to detail we have been bringing to our audio gear for the last 50 years.
    With 105 Watts RMS per channel, phono section, binding posts, a versatile remote control and switching for two pairs of loudspeakers, the only thing that bespeaks the word "budget" about the RX-4109 is its modest cost.
    MSRP 179.95
    Jun 22, 2011 | Sherwood RX-4109
    I have a sherwood RX 4109.....can i hook a pair of 6 ohm speakers and then a powered sub?
    By design, yes for one pair of 6-ohm speakers used at a time; depends on the sub for the second BUT there is no way to control its volume at the Sherwood.
    Mar 25, 2011 | Sherwood RX-4109
    I need a code to allow me to use my Dish Network remote to operate my Sherwood RX-4109 receiver.
    Hello! Try the link below this should help:
    http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
    Daniel Busa
    Jan 23, 2011 | Sherwood RX-4100 2 Channels Receiver
    Keeps turning itself off
    If Both speakers are working at a low volume and you turn it up and it clips and shuts off you have one of 3 problems. you have over driven your speakers and one has shorted the voice coil but still will work at low volume, its a overload protection for ohms short in receiver. unhook each speaker and turn balance to the one hooked up and turn up receiver if it shuts off do the same with other speaker to determine which side is bad. 2 speaker wires are touching at speaker or receiver. 3 a bad receiver output transister. Good luck.
    May 23, 2010 | Sherwood RX-4109
    Sherwood rx-4109 power shuts off
    looking at +$50 AUS
    for just the parts
    for about $150 AUS
    Jan 03, 2009 | Sherwood RX-4109
    Top Sherwood Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Josh Whitehead
    Josh Whitehead
    Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
