Question about Toro Lawn Mower With Toro Power Tools
How to remove personal pace control handle from toro 20092 mower
I am trying to replace the traction lever where the drive cable from the transmission attaches to,but I can't get the handle off
SOURCE: the cable traction cable is broken on my toro
I changed the cable on my toro mower but i cant make it go unless i pull back on the handle .i cant find a picture to see what i am doing wrongcan you help. Thanks
Posted on May 06, 2009
  • 81 Answers
SOURCE: Toro Personal Pace self propel problem.
Your self-propel is probably belt driven. Belts can make an awfully lot of noise when unhappy. Possible it has rolled over and is running on the wrong side of the belt or is worn and just needs replaced. Hope this helps.,
Posted on Jun 19, 2009
SOURCE: Toro 22in Lawn mower. Loud gear noise when try to engage drive.
Problem is in the rear pinion gears on rear axle and the design of the axle itself. I have a 2005 model 20041 had the same problem. I found a Toro dealer that had the fix.The problem is creadted by the fact that there is too much "play" in the rear axle. You have to limit that play by installing shims, or washers First, but the 2 new rear pinion gears for the rear axle. While you're at it, you may as well buy 2 new rear wheels because the "grinding" has worn the sprockets on the reas r wheels.Next, get 2 "fender washers", 1/2" ID and about 1" OD. I found it easier to turn the mower over and set it on saw horses to work on it.( drain the gas and oil first). Remove both rear wheels, pinion gears and all the washers etc. (caution - keep all parts from one side together - do not pile all parts together - keep them seperated by wheel - the reason is I believe there is one more washer/shim on the right side than on the left). Now to put everything back together, find a spot on the axle where the washer will fit in between the standard stuff.Install new pinion gears and replace the rest of the washers/shims just as they came off. INstall new wheels and you'll be good as new!
Posted on Aug 02, 2009
SOURCE: Toro model 20038 self propel problem
Try taking the back wheels off and lubricating the joint cogs and wheels with ,say, 3 in 1 oil . The dealer recommended doing this once every couple of years as preventative maintenance when I bought mine , and it has solved sticking problems for me .
Posted on Sep 12, 2009
  • 5 Answers
SOURCE: I have a Toro Personal Pace Recycler mower with a
It's not that hard. I've never done it on my Toro GTS 5.0, but I have done it on a Briggs and it's pretty much the same. Start by removing the 10mm bolts around the perimeter of the engine shroud. DON'T remove the 4 top bolts on the recoil housing. You might have to remove the fuel tank first. Drain it, then loosen the 2 8mm screws and lift it straight up. No need to disconnect the fuel line, just set the tank aside. After removing the 10mm bolts, the shroud should lift right off. Flip it over and you will see the recoil pulley. Remove any leftover cord from the pulley. Now you need to wind the pulley against the spring in the direction it goes when you pull the cord. It might wind 2 or 3 revolutions but don't overdo it. Now you will need some sort of clamp to hold the pulley in place as you line up the slot in the pulley with the opening where the handle goes. Next, feed the new cord through the opening and into the pulley and tie a knot to keep it from slipping out. Carefully release the clamp and let the pulley slowly wind the new cord onto itself. Finally, attach the handle on the other end of the cord and test it. If you can pull the handle and the cord comes out and it retracts normally, re-install the shroud and tank.
Posted on Oct 03, 2010
Toro model 20332. Have put new transmission, belt and new drive wheels on back. When I use the personal pace bar it makes a grinding noise. Doesnt make noise unless I push that down.
Sounds like either the gears on the wheels or ends of the trans shaft are bad, or the internals of the trans are bad. Are the parts actually new-new, or used and new to the machine, you didn't specify. What happens when you manually spin the pulley on the top of the trans in either direction?
Aug 14, 2016 | Toro 20332 22" Personal Pace Walk Lawn...
Toro 2009 personal pace mower transmission went out
You should post this question in the lawnmower section so the proper expert will see it..
Aug 29, 2012 | Toro Lawn Mower. 22 in. Personal Pace with...
How do I replace the torsion spring in the handle of a Toro Personal Pace lawnmower?
Thanks so much Jamie. I had the top of the handle off but couldn't get any
further. I had to use a screwdriver on one side to get the brass bar out of the
plastic channel (I was afraid I would crack the plastic but didn't). I was able to remove the bar from the handle by myself with lots of effort ( BTW in your
solution did you mean your son pulled vertically up on the handle while you pushed vertically down on the bar?). I had one foot on one side of the handle and pulled up on the other side while pushing down on the bar. Isn't the web and Google amazing. The Toro sight didn't have a service manual. So I just typed "How to replace the torsion spring on a toro lawnmower" in Google an the question came up. I think Toro has a design issue with an overstress point on the spring. That part is on back order at the factory.
I did it.
May 01, 2012 | Toro Personal Pace CARB Walk Power Mower
How do u adjust the personal pace toro...doesnt pull itself like it did.
Up on the left side of the handle should be the bracket that holds the drive cable to the handle bar. Take two 7/16" wrenches and loosen the clamp that holds the cable. Slide cable down towards the deck about 1/4" , then re-tighten clamp. Test the mower to see if it adjusted, might have to go 1/8" or possibly more. Hope that fixes it, some of these mowers have had a problem with the transmissions gears going bad from improper adjustment or lack of grease in the gear box. Also make sure the drive belt is good.
Aug 31, 2011 | Garden
I need a manual or step by step instructions to change the belt on my Toro Personal Pace mower
The mower should be drained of gas and drain the motor oil before starting procedure.
Disconnect spark plug wire from spark plug.
Motor side of the belt:
Remove two bolts under the lawn mower body which holds the top cover over the drive belt.
Remove the belt guard that is around the pulley on the crank shaft.
Then work the belt around the blade and off the the drive pulley.
While blade is removed, sharpen or replace as necessary.
Transmission side of the belt:
Remove the "S" clip on handle for speed / traction cable
Remove the plastic "Rear Baffle" two screws on each side on frame in front of rear wheels one screw in the rear
With the baffle removed, rotate the drive shaft and transmission to gain access
to the pulley drive belt guard, it is held in place with three screws.
Once belt guard is removed, you can easily remove the drive belt
Reverse procedure to replace the belt.
Lubricate drive Axel bearings, wheel bearings, control cables, as necessary.
Replace all fluids as necessary.
Read more: http://wiki.answers.com/Q/How_do_you_change_drive_belt_on_toro_lawn_mower#ixzz1MMJlZFMZ
May 14, 2011 | Toro Personal Pace CARB Walk Power Mower
How do you replace a drive cable on a toro recycler 6.5 hp.
Its a bit of a pain - but with ordinary tools, it can be done. Get the replacement cable first. You can see how the bottom spring wraps around the cable with a universal joint sort of arrangement. Remove the belt protector (three screws from the top deck; if you have a battery compartment, that will temporarily need to go. Release the old cable from the top and middle attachment points, then unhook the spring from the traction lever. You might need to destroy the old cable lock to the mower deck to remove the old cable. Remove the plastic cup next to the cable where it exits the mower deck. Replace parts in this order: New spring/cable to the traction lever, snap in plastic interface to mower deck, small plastic cup top cable attachment, then middle attachment. You might need to move the middle attachment after you give it a test run. Replace belt cover and battery compartment if necessary. A lot of steps but, except for a difficult fit to get the spring hooked up, nothing is really difficult. I paid about $30 for the replacement cable from a local dealer; Overpriced, but I wanted to get the job done today.
Oct 15, 2010 | Toro Lawn Mower With Toro Power Tools
How do i change the throttle cable on a toro personal pace mower model 20031
Run new cable under right side of mortor put cable through throttle brake bracket hook end into slot. Then run other end to handle and hook in slot.
hope this helps.
Joe
Aug 07, 2010 | Toro Lawn Mower With Toro Power Tools
Replace the cable traction (part #105-1844)
I just replaced mine and it was a little difficult and took me roughly an hour to do. First, download the walk behind power mover drive systems at https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=30166&control=SetCommunity&CommunityID=225&PageID=30031#manualsResultPage
While they do not specifically address replacing the cable, you can find out how they do it when replacing the drive belt. As I said, it took me about an hour and I just about had to remove the transmission and rear drive assembly in order to unhook the original cable. Good luck!
Aug 14, 2009 | Toro Lawn Mower With Toro Power Tools
Jul 07, 2009 | Toro Lawn Mower With Toro Power Tools
The cable traction cable is broken on my toro personal pase lawn mower. part number 105-1844 how do i change it
May 04, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
