Question about Radio Communications
Pair code for gear4-blackbox pg143
Can't pair with iPhone 4s
Badchariot
  • 3 Answers
SOURCE: How to pair Motorola H12 with iphone?
I just figured it out myself!!
here is how:
1.) press your home screen button at the bottom of your iphone
2.) open settings
3.) go into your general settings (same gear picture as home page)
4.) touch to open bluetooth
5.) turn on your H12 headset and place close to your iphone
6.) turn on bluethooth on iphone and it will automatically find the headset
7.) touch the motorola H12 button and it will enable the connection
Posted on Jul 08, 2009
bob_computer
  • 3153 Answers
SOURCE: cannot pair my Emerson EM-227 wireless headset with my Iphone
Some headsets have a built in code not all are 0000 check your documentaion for both the phone and headset
Posted on Aug 08, 2009
  • 497 Answers
SOURCE: What is the default password please to pair up a Blueant BTSVBC3?
Try with 0000 (four zero) or 00000 (five zero) or 1234 or 12345.
Good Luck!!!!!
Posted on Oct 19, 2009
  • 49 Answers
SOURCE: I can't get my new iphone to pair with my BlueAnt.
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etc
Posted on Apr 09, 2010
SOURCE: how do i pair the
Just did it myself. Ensure the iPhone is discoverable and searching.
Switch the Stone off by squeezing down the control surface until it bliddle-omps.
Put it into pair mode by squeezing the thang again until the bluetooth light flashes. Keep squeezing.
Watch the iPhone - it will pair automatically - no password required.
Posted on Oct 11, 2010
I want to pair my iPhone 4s with my Mini Cooper s convertible 2007
Turn the car on. Click Add Device. Got to iPhone Settings, Bluetooth and click Search. When found, the car will give you a code to add to the phone.
Whenever you get in your car, they will connect. Options will appear on the car to access your Contacts and Music.
May 04, 2016 | 2007 Mini Cooper Convertible
Why can't I pair iPhone 4s with 2008 BMW
make sure your bluetooth is turned on by going to settings>bluetooth
Jul 19, 2014 | Apple Iphone 4s I Phone 4 S Factory...
Big Ble / iphone 5s pairing
clear any past stored passwords. reset unit and put into discovery mode. Usually holding the pair button for a few seconds puts the LED blue into fast flashing - discvery mode
Apr 09, 2014 | Brookstone Big Blue Live Wireless...
Echo watch won't pair with iPhone 4S and map my runs
Delete the (bluetooth)? connection then reinstal.
Jan 28, 2014 | GPS
Pairing iphone 4s to 2010 mazda 3 bluetooth
1.) Enable Bluetooth on your phone/device and go to "search for devices" on it. Pic below is the screen on the iPhone, go to "settings" and then "general" to get there:
2.) Push the audio control button on the right side of your stereo on your speed3 a few times until "BT Setup" shows up and then spin to the right to choose "pair device" and click it.
3.) After a delay "Mazda" should show up on your device list on the iPhone. Choose it and then enter the pin "0000" and it should connect.
Aug 11, 2013 | Apple iPhone 3G
Pair iPhone 4s with 2006 BMW x5
Key-in, Ignition On (but don't need to start the engine)Press the R/T button on the steering wheel. "Activate Phone" should display on the radio. On the iPhone search the BT device. Select your car and enter the passkey when prompt on the iphone. Make sure there is no other BT phone near-by or the old one that has paired with the car previously. There is also the maximum number of devices you can have in the BMW BT sharing. If you reach the max, you may have to clear the car BT pairing memory by removing the power to the BT unit (by removing a fuse in the rear fuse box). The info is in the manual and inside the fuse box (which tell you which fuse is for the BT.)
Feb 06, 2013 | BMW X Series & X5 1997 >2006
I have BMW X5 2007, I tried to pair my iPhone 4S with the car thru idrive ! I managed once successfully .... But suddenly Pair drop . next time both can't see each other. I failed to pair anymore. Tried...
If the BMW system is like my system: I found I need to select the phone, then delete it from the system. Make sure your phone Bluetooth is set to on, and available to other devices, then set the car to look for, or add phone. It should find it, then once again, if like my system, send a code to the phone which you need to OK for it to work.
Jan 03, 2018 | Apple iPhone Smartphone
IPhone not pairring with parrot ck3100: I pressed "forget this device"
remove other paired devices on your device, may be the device has crossed the limit of phones it can connect.
start pairing fresh on both devices- phone and bluetooth device.,
Jun 06, 2017 | Apple iPhone 4S
My iPhone 4s won't pair with this kit hkt 300 by
Hi
I have just paired my Iphone 5 with the Hkt300.
I used the code 0000 while holding down the button on the car set.
Have fun
John
Nov 04, 2011 | Samsung Radio Communications
Radio Communications Logo
464 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
