Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Need cubic square footage of kenmore coldspot refrigerator model number 106.69902990
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
SOURCE: kenmore coldspot - How do you remove the ice maker box to clean
I have the exact same Kenmore and exact same model #77292798. It's the top freezer model with ice maker. Here's what I did:
Empty everything in the freezer.
Turn water to ice maker off from source behind unit.
Remove bottom panel (two screws)
Every screw in the freezer is the exact same size. I used a screwdriver style socket and, I think
this works the best.
Remove ice maker (4 screws) and unplug from socket.
Remove rear panel (2 screws).
My freezer was loaded with ice underneath the bottom panel. The ice scraped away easily. There is a tin pan underneath the coils that drains toward the middle where the drain hole is. Again, my freezer was full of ice beneath this tin pan and, I had to scrape away. You may be tempted to try and remove the coil because it would be easier to get to drain hole. I tried this and, it did no good. Don't try it. Once all the ice was scraped away, I realized that the drain hole was plugged with ice. I used boiling hot water and used a squeeze bottle to pour the hot water into the drain hole. I then wrapped a paper towel around a thin screwdriver and used that to soak up the now cold water in the drain hole. After doing this a dozen times or so, the drain finally cleared.
Then, reassemble. This was a much easier task than I thought it would be and, will take care of it much quicker next time.
Posted on Apr 17, 2009
SOURCE: how many cubic square feet is our kenmore
25 cubic foot
Posted on Sep 27, 2009
Testimonial: "I recieved an answer in less than 2 minutes!!! Thankyou Thankyou!!! My kenmore refrigerator model #51582200 is 25 cu ft. Now I can list it and sell "
rogrrabbit
  • 986 Answers
SOURCE: Oue Kenmore Coldspot ice-maker quit working. Any
Wake up one morning and Boom no ice left in the bin. What happened and What can I do to fix it without calling someone? Some ice makers will get a piece of ice in the wrong place and jam the extraction. Get a hair dryer and heat up the ice maker to release the fouled ice cube and that baby will start going. No water in ice mold?Do this easy test: pour some water in the ice maker mold and wait. If it kicks out a batch, but it has no water in it, most likely the water valve is bad. water%20valve%20for%20water%20and%20ice%20through%20the%20door.jpg Watervalve for SxS box Since it is the cheapest part and you can do it yourself replace it. If it turns out you need a new ice maker then you have a new water valve already to go with it. What if the ice maker has ice in it but won't harvest any? One cheap and easy item for the do it yourselfer to replace is the ice mold thermostat. Check for voltage between T and H if you have 120 volts then the bi-metal (inside that ice mold thermostat) is bad. If it's good you will have 0 volts. ice%20mold%20thermostat%28modular%29.jpg Ice mold thermostat Located in the plastic housing and seated against the ice mold is that thermostat. This looks intimidating but is easily fixed by anybody who could change a spark plug. There is no wiring. One more thing to look for: You can put a jumper between L and V and this will activate the watervalve. Have rags ready! If you are a cheapskate and want to be frugal and not buy a new ice maker or a new head(brain) head1.jpg modular crescent ice maker you may want to remove the main gear and clean the copper plate behind it. That plate gets dirty and won't allow for a good contact with the water valve connection and does not power up the valve...Shhh! They will all be doing it! Modular crescent Icemaker test points: With NO power to the icemaker, and ice ejection fingers in the freeze position: Your ohm meter should read 8800 ohms between L and M, and 72 ohms between L and H. With power ON to the ice maker: If meter reads 0 volts between L and N you have no power to the ice maker. If the meter reads 120 volts then you have power to the ice maker. If you have 0 volts between L and H heater is off if you have 120 between L and H the heater should be ON. If you have 0 power between L and M the motor is off. If you have 120 between L and M then the motor should be ON. If you have 0 volts between T and H the thermostat is closed If the meter reads 120 between T and H then the thermostat is OPEN. If the voltage is 0 between N and V the water valve is closed. If the meter reads 120 water should be filling the mold.
Posted on Nov 11, 2009
aasc
  • 1606 Answers
SOURCE: I need to take the handles off on my kenmore side
Try sliding them upwards ( the top ones ) , downwards ( for the bottom ones ) , as far as they will slide , then remove .
Posted on Nov 13, 2009
How many cubic feet is Kenmore Coldspot Refrigerator Model 10674254400 Serial ER3139075
Kenmore appliance model numbers have a three digit prefix (106 in this case) for the manufacturer. The rest of the model number indicates a lot of the specifics for the refrigerator. The third digit is the second group indicates the capacity. This fridge is a 22 cubic foot model (or slightly smaller).
I hope this helps.
Apr 15, 2017 | Kenmore Refrigerators
What is the cubic feet of Kenmore refrigarator model #253.562824on and also need mearsurements of outside.
You seem to be missing a few digits in the model number. Sears Parts Direct lists 11 refrigerator models that start 253.562824. (The full models numbers have 2 extra characters, including 253.56282400 and 253.5628240N.) See http://www.searspartsdirect.com/model/search.html?q=253.562824 for the list of models.
Kenmore uses the 3rd digit after the decimal point to indicate the cubic footage of their refrigerators. With a 2 in that position, this model has a 22 cubic feet capacity (probably 21.6 or 22.1 cubic feet before rounding). Using the size of other models, the external dimensions will be between 30" W x 31-3/4" D x 69" H (the size of a 21 cu. ft. model) and 35-5/8" W x 28-1/4" D x 69-3/8" H (23 cu. ft. model). One current Frigidaire 22 cubic foot side by side model has the external dimensions: 33" W x 32" D x 69-7/8" H. (Note: the 253 in the model number indicates a product made by Frigidaire for the Kenmore line.) Unfortunately, I can't find the dimensions for any of 253.562824 models.
I hope this helps.
Aug 30, 2016 | Kenmore Refrigerators
Where can I find the cubic feet on my 2006 kenmore coldspot refrigerator?
it might tell you on the tag that has serial number and model on it
Jan 11, 2015 | Kenmore Refrigerators
What is the cubic feet of the Kenmore refrigerator Coldspot 106.5706602
According to your model number, this refrigerator has a total capacity of 25.2 cu. ft. It has 15.4 cu. ft. in the refrigerator section and 9.8 cu. ft. in the freezer.
Oct 20, 2014 | Kenmore Refrigerators
What is the cubic feet of 2000 kenmore coldspot refrigerator model #59592992?
I believe that the full model number is 106.59592992. Since the fourth digit after the prefix is a 9, I suspect it is a 29 cu. ft. capacity side-by-side refrigerator.
I hope this helps.
Jan 07, 2013 | Kenmore Refrigerators
Square footage of my refrigerator model #25359489990
Here is a tip that I wrote that tells you how to figure out how big yourrefrigerator and/or your freezer is...
New Refrigerator Size or Refrigerator Cubic Feet
Heatman101
Apr 22, 2011 | Kenmore Microwave Ovens
What is the cubic feet of this model?
Usually the first 2 numbers after the letter designation in the model number is the cubic footage.
Mar 14, 2009 | Kenmore Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
41 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
