Question about Jon Dicks What a Carry On
Valve clearance nissan patrol Y61 td42 engine
I need cylinder head torque specs for td42 nissan bus
Here's a link Daniel to the head torque specs,just stroll down page and you will see. Nissan Patrol 4x4 Africa
Jun 22, 2017 | Nissan Cars & Trucks
How to bleed cooling system on Nissan patrol Y61 ZD30ddti
Open the heater controls (set them to 'hot'..)
Remove the radiator cap or cap on the coolant expansion bottle.
Start the engine and let it idle for 5-10 minutes.
Any air in the system should have bled out. Top up as necessary
Feb 04, 2017 | Nissan Cars & Trucks
My td42 it gu y61 nissan patrol wont start when hot, replaced glow plug relay and temp sensor , will start whhen hot if you disconect temp sensor
Having the same problem mate! It's to do with the "quick glow " circuit I'm trying to find the exact control unit that is at fault
Sep 01, 2014 | Cars & Trucks
I would like to know where I can find the drainage plug on the Nissan patrol engine block. Engine model TD42
just remove the bottom hose their is no drain plugs on modern engines ,mcor you must be older than me to remember drain plugs
Jul 17, 2014 | Cars & Trucks
2010 Y61 ZD30 Patrol code P0090,P0088?
Check your wire diagram it could be IGN bad wire
Jun 23, 2014 | 2004 Nissan Nissan almera tino
Nissan Patrol 98 petrol valve clearance
hi, i have a nissan patrol st4500 running on gas and petrol and I need a new valve since it has been bad to switch between gas and petrol, do any of you know where I can order it?
Mar 30, 2012 | Cars & Trucks
Need to replace head gasket and require Nissan Patrol Y60 TD42 engine Head bolt torque specs
I frequently use and highly recommend registering for free at www.autozone.com Your registration gives you access to a variety of repair and shop manuals, most giving you detailed repair instructions diagrams and specs.
Jul 21, 2011 | Nissan Pickup Cars & Trucks
I am looking for the wiring diagram for the 1998 Nissan Terrano 2 (AU) I am fitting a Sony xplod. The original Nissan plugs already removed. Just the wiring of the Nissan at the head unit would be fine as...
hope this is of some help its for the patrol, the wiring is virtually the same
http://www.pdfee.com/1998-nissan-patrol-y61-electrical-wiring-diagram-service-and-troubleshooting.html
Mar 18, 2010 | Sony XPLOD CDX-GT200 CD Player
Head stud torque
cyl head torqes.1st stage 29 nm. 2 nd stage 57-67 nm. 3rd stage slacken off 360 cegrees, 4th stage 29 nm. 5th stage 64-74 nm. intake and exhaust valve clearance .38 mm hot setting. hope it goes ok.
Aug 14, 2009 | 1987 Nissan King Cab
Facebook Apps Logo
16 people viewed this question
Top Jon Dicks Facebook Apps Experts
Allen Lightsey
Allen Lightsey
Level 1 Expert
Are you a Jon Dicks Facebook App Expert? Answer questions, earn points and help others
