How to configure netgear genie wn3000rp extender
One computer will not connect to internet but others do....will do so only with ethernet cable
    Top Expert:
  • Computers & ... Master
  • 14,162 Answers
how to videos on netgear genie
c
Posted on Feb 21, 2015
Can a hg568 router modem work with a netgear range extender and if so how do u get it to work
Might have a issue with the wireless. Suggest you connect both with ethernet. Using a netgear genie verify connectivity
May 01, 2016 | NetGear Computers & Internet
Www mywifiext net
1-888-939-9092 is Netgear support. I have used them many times in times in the past for help. Give them a call and they might help configure it for you.
Jul 17, 2014 | NetGear WN3000RP Universal WiFi Range...
Your connection is limited
What router and where is it that you are connecting the Extender to? An extender is not a router. You need a router to extend the wifi signal from.
Mar 22, 2014 | NETGEAR CONSUMER New - Netgear Wn3000rp...
Mywifiext net
Have you first established the connection between the Router and the Extender?
If so, have you connected e.g. a laptop to the Extender?
So if your WLAN networks SSID is NETGEAR, the WLAN network of the Extender is NETGEAR_EXT and you have to connect the laptop to NETGEAR_EXT.
Then you have to open your favorit internet browser and have to type in www.mywifiext.net, which I guess is a buildin Setup-Assistant.If this doesn't work, make sure, your laptop is configured, to get an ip address automatically via DHCP.
Or read http://kb.netgear.com/app/answers/detail/a_id/20912
Apr 26, 2013 | NETGEAR CONSUMER New - Netgear Wn3000rp...
Cannot connect NetGear WN3000RP with wireless
If you use a Netgear router to broadcast a WI-FI (Wireless Fidelity) signal in your home, you can easily double the range of your network by connecting a second router to one of the LAN (Local Access Network) ports located on the back of the Netgear router. You can use a Linksys, Belkin, D-Link or even a second Netgear router to extend the range. Any router that allows you to access the router settings to turn off the router's DHCP server is usable as a range extender.
Complete a master reset on the router you want to use as an extender. Typically, routers have a reset hole located on the back or side of the router. Push a metal push pin into the hole until the lights on the router flash. Often the settings on routers have been manipulated to enhance a network connection. Resetting the router ensures you can access all of the settings and not encounter any issues when making the connection. Plug an Ethernet cable into one of the router's LAN ports located on the back of the router. Plug the other end of the Ethernet cable into the Ethernet port located Enter the router's IP address into an Internet browser Web address field. If you do not know the default IP address, reference TechSpot.com for a list of router IP addresses. Enter the default username and password for your router. If you do not know the default login information, reference Router Passwords.com for the default login information for your router brand. Access the DHCP server settings. Usually, this is located in the "Basic Setup" section of the router settings page. Turn off the DHCP server and then select "Update Settings." The location of the DHCP server can be located on a different page if the router is an uncommon brand. Access the "Wireless Setup" page and change the SSID to match the network name you use for your Netgear router. Select "Update Settings" to save the network name. This allows computers to move from the Netgear router to the router used as a range extender without requiring a second wireless profile being set up on the computer. The SSID could be located on a different page if the router is an uncommon brand. Access the "Wireless Security" page and update the router's password to match the password used on the Netgear router. If you do not secure your network, skip this step. The wireless password could be located on a different page if the router is an uncommon brand. Remove the Ethernet cable from the router and the computer. Plug one end of the cable into the WAN (Wide Area Network) port located on the back of the router you want to use as a range extender. Plug the other end of the cable into one of the LAN ports located on the back of the Netgear router. Hope this helps
b>
Dec 05, 2012 | NetGear Universal WiFi Range Extender...
I am trying to install my netgear Universal Wifi Range Extender WN2000RPT. I have green lights for my connection to the router, the extender is on and it is connected to the main PC. But I only have...
For that you need to check WAN settings and also make sure local ip settings gateway should be your router ip address. Make sure WAN settings are fine connect internet cable to WAN port of router. Then check. You can configure router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
Nov 10, 2010 | NetGear Computers & Internet
I have an hp comp that wont connect to my netgear internet access
Define/explain "wont connect".
Are you trying to use an Ethernet cable to connect the two devices? If so, try a different cable, to rule-out a "bad" cable.
Do you have any software like "Norton Internet Security" on the HP? It is notorious for "blocking" attempts to connect to "unknown" networks.
Does your desktop computer have a wireless networking adapter that you are trying to configure/use?
Will any other computer, either via Ethernet cable or wirelessly, connect to the NetGear router? If not, then maybe the NetGear is the problem.
Any error-messages when you try to "connect" ??
Exact wording?
Sep 07, 2010 | Computers & Internet
Belkin f5d7132
For best results, you should connect it directly to the other router with an ethernet cable.
Jul 21, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
Computers & Internet Logo
270 people viewed this question
David Payne
David Payne
