Question about Conair Weight Watchers WW-87 Body Fat Glass Scale
Changed batteries on scale and don't know how to reset
When touch on/0ff button the .00 comes up however normally at that point you are to stand on for weight and nothing is happening it just stays at the .00
ptooshar
  • 19 Answers
SOURCE: scale appears to be inaccurate
this type of less resoluted scale hasn't repeatability. if you wish to repair it, change the loadcell. use 2 x scale capacity of load cell.
Posted on Dec 02, 2008
r321567499
  • 74 Answers
SOURCE: Can I reset the scale?
This link allows you to ask questions and request a users manual....I hope this helps. http://www.conair-store.com/cc_contactus.asp
Posted on Jan 07, 2009
fitnessbalan
  • 59 Answers
SOURCE: My scale came up with an error message of ErrL
here is the contact information for conair
http://www.conair.com/-cn-18.html
Posted on Mar 21, 2009
  • 67 Answers
SOURCE: Fluctuating weight on Digital Scale from one minute to the next..
i believe that, like most electronic scales, the first time you get on the scale you must step off to allow it to zero itself. Then step back on to get your correct weight.
Posted on Jul 28, 2009
SOURCE: My bathroom scales ww35cha stopped working, i
you have 4 button on this model
1 tap the scale to start, it show 0.0
2 tap set to set person and height, age ...( use set, up, down buttons )
done
when start use
1 tap scale to start , show 0.0 again
2 tap user again and again to choose your user
3 wait after it show your height, age, then it show 0.0 step on the scale and you're done.
i've been through becuase my friend lost his instruction manual.
Now it wook
Have Fun
duccotam@yahoo.com.au
Posted on Jan 22, 2010
I changed the battery to the right one which is CR2032 and put it in and all that comes up on scale is ERRL will not go to 00. Thank You.
CR2032 batteries are light use and I am pretty sure only preserving the memory of the scales, which usually have an MN1500 9 volt battery.
Google
make model manual
Mar 19, 2018 | The Health & Beauty
How do I reset my tissot t touch expert
Steps to Synchronize the Hands
  1. Press the centre pusher (T). The watch should beep once.
  2. Touch the centre of the touch-sensitive face until opt appears, in opt select 24H Cm (or 12H Fft or 24H Fft or 12H Cm) is shown in the digital LCD display.
  3. Press and hold the centre pusher (T) for approximately 5 seconds. The watch will beep once and then again, a second time, after 5 seconds have passed. After the second beep, the digital LCD display should read SYNCHRO. If not, return to step one.
  4. Press the upper pusher (+) to advance the hour hand until it is positioned exactly at 12:00. (PH press T button to to switch to minute hand adjust)
  5. Press the lower pusher (-) to advance the minute hand until it is also positioned exactly at 12:00.
  6. When both hands are aligned together and pointing directly at 12:00, press the centre pusher (T) to save the setting. The hands of the watch are now synchronized
Jan 29, 2013 | Tissot T-Touch T33159851 Wrist Watch
On my Tanita BC-534, I just changed the batteries but now continually get "Lo" in the display. So tested batteries and even tried other batteries, but still get the same message. Please let me...
Hi BJ,
Welcome to fixya!
According to the manual, "Lo" indicates weak batteries. Since you changed batteries, my next question would be... Did you buy fresh batteries at the store or use ones you had at the house? Check the freshness date on the battery package. Sometimes even some of the ones you get in stores aren't fresh enough.
Since you get enough power to get "Lo" reading, but not enough for anything else, this sounds like a battery problem.
Did you check the contacts in the battery compartment? Sometimes cleaning them with a pencil eraser will help make better contact. Also, be sure the springs are tight enough. If they are the tab kind, you can bend them out a little for a tighter fit.
If all else fails, here is the contact page for Tanita: http://www.tanita.com/en/contact-customer-service/
They should stand behind their products.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Jun 26, 2011 | Tanita BC-534 InnerScan Body Comp Scale
Scale keeps showing lo no weight
Try taking the battery out and putting it back in, also there should be a small reset button. You will need a toothpick to push the reset button. Allow time for the scale to reset before stepping on it.
Apr 19, 2011 | Homedics Digital Scale
I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
Jul 21, 2009 | Salter Stainless Steel Electronic Bathroom...
I have a chefmate digital kitchen scale and I do not know how to reset the clock.
I have the same problem. The only way I can figure out how to reset the clock is to take out the batteries and put them back in at 11:59 pm or midnight. Replacing batteries reset the clock to 12:00 am. So if you do it at midnight, you'll end up with the right time. But for the life of me, I cannot figure out how to actually set the clock using the availble buttons.
Apr 13, 2009 | Health & Beauty
Error message
Try this, I have the same problem and I just got off the phone with Taylor, this is what they told me to do and my scale is now working again.
1. take the battery out.
2. put the scale on a flat, hard surface
3. stand on the scale for 10 seconds
4. put the battery back in, be careful not to touch any buttons or turn the scale on
5. put the scale back on the flat, hard surface
6. put one foot on the scale and apply pressure until the display comes on
7. take your foot off of the scale
8. wait for the the display to go blank
9. now stand on the scale to weigh yourself.
This worked for me. Hope that it works for all of you.
Dec 29, 2008 | Taylor Dgtl Body Fat Scale
Big problem
Push the touch button and then the centre of the screen untill the units deg C 24h etc come up then hold the touch button for 5 seconds. This puts it in sycro mode. You can then use the -+ buttons to make them both point to 12
Feb 24, 2008 | Tissot T-Touch T33759851
Conair Weight Watchers WW-87 Body Fat Glass Scale Logo
53 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
