Question about Garden
Where can I find Giovanna seating range to try
Manuals giovanna by deni model.95400
I have the manual for this Giovanna Italy by Deni 95400 in pdf form. Not sure how to post it here but I can email it
Aug 23, 2013 | Deni / 5201 / 5202 / 5203 / 5205 Ice Cream...
I lost my installation cd for my microsoft lifecam vx-3000 and i need o install it in order to get the webcam to work..i don't know how to get the software.
Giovanna:
Please download the drivers and software from the Microsoft web site.
You can start locating the files for your lifecam here: (click here)
Good Luck and Thanks for Using FixYa
Feb 16, 2011 | Microsoft LifeCam VX-3000 Web Camera
I have a 2004 Chevy Silverado. The heated seat on the drivers side does not work. When you push the button to turn it on, the lights come on briefly then turn off.
Would you say it stays on about 30 seconds and does the passenger side do the same thing? If possible retrieving the codes will narrow down the search for a correct solution.If the passenger side is ok we may be able to eliminate the passenger side as bring part of the problem.Please advise so will know which way to go with your solution.
Condition/Concern:
Driver and passenger heated seats inoperative or shut off in 30 seconds. There will be DTCs B2435, B2440, B3606 and/or B1825 set in the Drivers Seat Module. The adjustable pedal position sensor, seat recliner position sensor and both heat seat thermistors share the same 5 volt reference internal to the Drivers Seat Module. A fault in any of these components/circuits can make the heated seats inoperative or shut off in 30 seconds, as well as, the seat recliner and/or adjustment pedals may move in short increments when operated. A fault in heated seats, adjustable pedal or seat recliner will affect BOTH heated seats.
Note:: Even if the vehicle is not equipped with adjustable pedals DTC B3606 still may set.
To help isolate the area of concern use the Tech 2 or a comparable scanner and go to "Sensor Data" in the Drivers Seat Module. Monitor the following parameters for being out of range:
Recline Position- Normal range .39V-4.58V
Pedal Position (if equipped) - Normal range .39V-4.58V
Psgr. Seat Heat Sensor- Normal range 1V-4V
Drvr. Seat Heat Sensor- Normal range 1V-4V
If a parameter is found to be out of range inspect circuits for any opens, shorts to ground, or voltage. If none found replace the suspect component.
Please be aware of the following common areas of concern:
  1. The adjustable pedal position sensor internally shorted pulling the 5 volt reference low. Disconnect the adjustable pedal position sensor and see if the heated seats start working correctly, if so replace. Note Important:: The APP (Accelerator Pedal Position) sensor is NOT the adjustable pedal position sensor. Make sure the correct sensor, adjustable pedal position sensor, is disconnected.
  2. The seat recliner position sensor internally shorted pulling the 5 volt reference low. Disconnect the recliner position sensor and see if heated seats start working correctly, if so replace.
  3. An open in either heated seat thermistor circuits (signal or low reference). The most common is the passenger thermistor where it passes through seat connector C305 pin "L" or "K" or C399 pins "R" or "G".
  4. A chaff to ground on either heated seat thermistor signal circuits. The most common is circuit 5475 black/red or dark blue shorted to ground in the passenger seat near the buckle. Note Important:: The heated seat thermistors act differently to "OPENS and SHORTS" than the adjustable pedal position sensor and seat recliner position sensor. The adjustable pedals and seat recliner sensors can be disconnected for testing of the heated seats. Where as the heated seat thermistor circuit must be working correctly before EITHER heated seat will operate. Disconnecting one thermistor, which may have a concern will not allow the opposite heated seat to work correctly, BOTH side must be operational before EITHER heated seat will operate.
Clearing DTCs
If DTCs will not clear when using the Tech 2 or comaparable scanner after a repair has been made, try operating the device in which the repair was made. Example, if a repair was made to the passenger heated seat thermistor circuit, the DTCs may not clear unless the passenger heated seat is operated.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Nov 17, 2010 | 2004 Chevrolet Silverado 2500HD
Presumed bad circuit board on my LG LRE30755ST electric range
You may wish to try removing and re-seting some of the connectors on the back of the control panel...worked for me when our oven and timers stopped working.....
Remove the sheet metal panel at the top of the back of the oven..three phillips screws....then slide the two blue ribbon, wire connectors out, and re-seat them a few times to get a good connection.
Try to un-seat and re-seat some of the others aswell...perhaps un-plug from the wall first....but make sure there is good connections....then re-plug in, and see what happens...
Jan 02, 2010 | LG LRE30755 Electric Kitchen Range
Lg oven not workink
Dec 01, 2009 | LG LRE30755ST Kitchen Range
1991 range rover passenger seat doesn't move
You could try swapping out the seat switch from the other side if you are just trying to move the **** portion forward or backward. What usually goes wrong is the seat switch gets corroded and needs to be disassembled and rebuilt. The opposite seat switch will no fit the other side and mount but you can finesse it around to a position where you can make connectioin.
To remove seat switches - Use a small screw driver to carefully pry up the button control knobs (**** and back knobs) on top of the switch housing. Next, remove the cover plate and there you will have 2 screws exposed to remove the switch.
Mar 22, 2009 | 1990 Land Rover Range Rover
How to take a close up of an object
Iused a different camera!!!
thanks anyway.
Jan 27, 2009 | Fuji Finepix A370 Digital Camera
Controls
If you take the sheet metal backing off the top portion of your range, then un-seat and re-seat the two blue wire ribbons, to try to get a better connection...you may find you have success. try re-seating others as well...typically a loose connector...worked for me...
Oct 09, 2008 | LG LRE30451 Electric Kitchen Range
Garden Logo
270 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
