Question about Genie Powerlift 900 Garage Door Opener
Genie powerlift 900 wired keypad won't work - Genie Powerlift 900 Garage Door Opener
Beam: one red light, one green light - how to make both green?
Have a look at the 'remote control programming' section on page 9 of the manual. Note, the manual says that the LEDs illuminate blue, not green.
http://www.geniecompany.com/data/products/genie_owners-manual_eng.pdf
Apr 24, 2016 | Genie PowerLift 900 1/2 HP Screw Drive...
Garage door closes but doesn't stay closed
if nothing is obstructing the door then there are 2 possibilities:
a) your limit switch for closing is too low and the closer detects the motor stall as the floor is reached, then opens in case it's a kid under the door.
b) your tracks and garage door are mis-aligned, causing excessive force to trigger the reversal. Make sure the door closes easily by hand.
Jun 19, 2015 | Genie Powerlift 900 Garage Door Opener
Genie 900 door operator
hello,there is an adjuster on the side of the motor,also check that the micro switch[if fitted on your particular type} is 'clicking' and actually in contact with the arm as it revolves closed. hope that helps, cheers
Jun 02, 2014 | Genie PowerLift 900 1/2 HP Screw Drive...
Garage door opener Chamberlain - programming problems
I bought a new keypad and 2 VISOR remote (30498). As to programming garage door opener, I did like here:
- it tooks me 20 minutes and works great
Feb 07, 2013 | Sears Craftsman LiftMaster Chamberlain...
Why wont the carriage assembly go past the screw splice
I think the threads are different. I have the same problem and the threads in the small splice part are different. i must have the wrong splice.
Dec 30, 2010 | Genie Company Genie PowerLift Excelerator...
Genie excelerator light won't turn off...
First unwire the wall button. If the light will go off now replace the wall button. If not then you will need to replace the logic board on this unit(genie.com for replacement). Protect this with a surge protector as well 900 joules or higher. Thanks BB
Jan 21, 2010 | Genie Company Genie PowerLift Excelerator...
The motor on my Genie Chain Glide garage door operator runs but the chain does not run or move.
If the chain does not move but the motor runs then you have stripped the internal gears. I would replace here. These chain glide units are not very strong. There might be a chance the chain is telescoping down the rail but the trolley is not hooked up. Pull the red cord back toward the motor to engage. Thanks BB
Dec 29, 2009 | Genie Company Genie PowerLift Excelerator...
Genie Powerlift 900 Garage Door Opener Logo
Top Genie Televison & Video Experts
ray gallant
Lex Landa
Lex Landa
Level 1 Expert
Are you a Genie Televison and Video Expert? Answer questions, earn points and help others
