Question about Haan SI-35 Slim & Light Steam Cleaner Floor Sanitizer
Haan Floor Sanitizer gets hot but does not steam. Water is not heating, but the unit feels hot
Haan steam mop
The heating element may have failed.
Jul 25, 2016 | Haan SI-70 Steam Mop With Detachable...
Steam mop not putting out steam although it is heating up
Well, if you have heat and there is water in it then this is one of two things. The delivery hose is clogged either too or from the heating unit or the heating coil is not getting hot enough. Look for dripping water that is not turning to steam while it is running. That would eliminate the clogged problem. Then you could look at the heating temperature at that point.
Jun 03, 2016 | Vacuums
Haan sI70 unit gets hot but no steam is generated, so not hot enough. Anything I can do?
It sounds like the internal temp thermostat is detecting that its hot enough when its not, and cutting the power as its supposed to, but too early. It may not be worth time/effort/money changing this part, in case its a problem with another part. Its a bit desperate but you could turn it off and half fill it with cold water then shake it vigorously to see if washing the internal surfaces impoves things.
Dec 15, 2013 | Haan SI70 Multi Sanitizing Floor Steam Mop...
How do i remove the hose from the haan gs 60
Look for a push-in button on the machine where the hose attaches to it. Also check that there may be a twist off connection with 2 pins on the machine that connect to the holes in the metal end of the hose...either is possible..Good luck!
Dec 28, 2012 | Haan GS-60 Steam Station Garment & Home...
I have the Shark Steam Mop, Model number 120544 (gold case) purchased at Costco in April 2010. The water heats up to steam, but never reaches the cleaning heads; water drips out of the handle to the...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Feb 12, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Unit gets hot but doesn't produce steam!
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
l
Aug 15, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Prolectrix 3 tier steam
Is the unit spraying ok? If not then the heater may be plugged. Other than that, you should fill the tank with hot tap water, the the heater will only heat it alittle more, you won't really see steam.
Jan 19, 2008 | Bissell 1699 ProHeat Clear View Upright...
Haan SI-35 Slim & Light Steam Cleaner Floor Sanitizer Logo
70 people viewed this question
Top Haan Vacuums Experts
ray gallant
Thatvacguy.com
Are you a Haan Vacuum Expert? Answer questions, earn points and help others
