Question about Toshiba Satellite Computers & Internet
Times used unsure why kept requesting new password so often
Unsure why after entering password 2-3 times next time would be rejected and request new one . That's why I have so many and then was told I had to many changes in short time and was canceled Have not been able to get into my 2 gmail accounts I KEPT GETTING error messages that needed new kept repeating several days and then was refused password after about three uses and would have to make new password and the cycle kept repeating for few weeks and then would not allow me to continue
johnnailed
  • 36 Answers
SOURCE: Network Timeout error
Here is some great source to solve any kinds of laptop's problem.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Gateway Laptop's Solution
» IBM Laptop's Solution
Here is some another Great source to download any kinds of laptop Drivers.
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
» Gateway Driver's Download
» IBM Driver's Download
4s27
Posted on Jan 07, 2009
yourpc
  • 190 Answers
SOURCE: Toshiba M45-S165 startup issues
This is normally a motherboard issue. I had one with the same symptoms and I had to replace the motherboard. Worked great after the board was replaced. I had to replace the board because unlike your issue mine stopped working all together. It did take a while before it quit though. Just a note: I have had to replace several of these motherboards for customers as well. If your LCD is broken, you may be better off to save your data and put it in a new laptop that would include a warranty unless your super fond of the machine or you have access to inexpensive parts.
Hope this helps...
Posted on Feb 15, 2009
technical114
  • 1851 Answers
SOURCE: HP zv5000 request Power on Password
It seems that a bios password keeps you locked out. Try entering the bios (del or F2 during the boot) and get back to defaults or reset the password.
Stelios.
Posted on Feb 21, 2010
drifterK
  • 4924 Answers
SOURCE: I've owned an Everex laptop(NC
ok ..I even read the oher comments and it seams that you are fuzzy in this matter ..
the recovery cd that came with the laptop is a cd ..that gets the computer to the way it came from the factory ....but!!!!! if you have more than one partition ...all the files should be kept in the other one in the moment you make the recovery ..cause if you do it ..no matter which kind ...this will erase the C partition clean ..reinstall (repair) the files for teh operating system and the drivers..eventual the programs for maintenance that was in the pc first ..but no other programs or so ...
you might even have a partition for the recovery ..and that one is accessible by pressing f11 on boot the way you actually enter bios set-up with f2.. ..but only if it is functional will work and will bring the pc ..in the stage it was when first installed..clean ..but no data-s in the D or other partition but C will be lost ..
the system recovery tool appeared in that day probably as a result of pressing that F 11 key by mistake ..or cause the operating system was damaged and could not boot anymore...
If the system is not functional at this moment the way to do is to insert the disk ..and boot from cd ...this is done ..by pressing any key when iot asks ..if the boot order is seted..or ..by changing in BIOS the boot sector order...and choose it to boot from cd if available first ..and than from hdd...save by pressing f10 and after that you can boot directly from the recovery cd ..and let it run and do the job ...
if in the present the system is not functional ...and you have important data on the C drive ... you can not move them ..and to retrieve you have to either use a operating system that boots from cd directly ..( I mean a system that is on a cd and open a windows from it ..and you can operate the partitions..I will link such one if you want) or ..to remove the hdd and hook it in another computer to get the data ...and after that put it back and run the recovery...
in any meanings ..if you run the recovery with no data lost ..if it is available ...even if it tells you that this is deleting and replacing files it refers at the system files of the windows..and not the fils on the C partition ..(my doc or else)..
so ...if you do not have important data ..or have but you afford to loose in case ..... you just boot from recovery cd ..and restore the computer ..following the guide..
or ..you can even try to restore the computer by pressing the F11 on boot ..and this will action with the recovery partition on the Hdd..without the cd ...probably the cd will be asked for the drivers if it is the case..
or ...here is a link with a image file for ..vista home...edition...you download it ..and burn with Nero on a dvd...by double clicking the image direct ..it will open nero by itself ..and make a bootable vista cd ..with this dvd..you can boot from disk ...and install the computer clean ...or choose when it asks..to repair the existing OS...so you do not loose anything but it will just replace the system files..without formating the C partition..
here is the vista download link
http://thepiratebay.org/torrent/4418157/Windows_Vista_Home_Premium_Pre_-_Activated_and_Bootable
read the instructions before ..it says how to boot from it ..and how to burn it on the disk..
This I think covered all your questions ...and I wish you good luck ..I hope its helpful
Posted on Mar 25, 2010
SOURCE: Access control configuration prevents your request from being allowed at this time. Please contact your service provider if you feel this is incorrect.
Sounds like you might be getting redirected to a site or a Proxy Server whereas you don't have access. If that's the case you shouldn't have access because you're not supposed to be there.
Let's start with Internet Options. If you have Windows XP Click Start/Control Panel/Internet Options. If you have Windows Vista or Windows 7 click Start/Control Panel/Network and Internet/Internet Options.
When the Internet Options window opens on the General Tab make sure you have a valid web address as the Home Page. If not, create a simple Home Page by typing: http://www.google.com You don't have to click OK now because if you do the Internet Options window will close.
Click the Security Tab and under where it says "select a zone to view or change settings" Click on the one that says Internet, then scroll down to near the bottom right and make sure that DEFAULT is grayed out (whereas you cannot click on it). You can Click on Default just to be sure. Next click the Intranet so that it is highlighted and make sure DEFAULT is grayed out so that you cannot click on it. Do the same thing for the other two zones (Trusted Sites and Restricted Sites). After all zones under the Security Tab are set to Default click the next Tab which is the Privacy tab.
On the Privacy Tab you want to make sure that DEFAULT is grayed out, if not click on it. When in doubt just click the Default tab.
Next skip over the Content tab and proceed to click the Connections Tab. On the Connections Tab make sure that the Never Dial A Connection is checked if you have something in the white box above it in for Dialup and Virtual Private Networks settings. Look down on the right near the bottom and Click the LAN SETTINGS button. When Lan Settings open up the only box that should be checked is the very first box that says: Automatically Detect Settings. If any other box is checked remove the check from it or you will never be able to connect. Click OK to close the LAN SETTINGS tab.
Next skip over the Programs tab and click the Advanced tab. When it opens slide the blue bar on the right all the way down until you get to the bottom of the window. You want to be able to make sure that if you see something like (Use SSL 2.0, Use SSL 3.0, Use TSL 1.0) that you put a check in the box to the left of each one of them. Afterwards you can click OK to close the Internet Options Window.
Next lets go boot your computer in Safe Mode.
Go to www.google.com and in the search box type:"Download cnet Malwarebytes" (without the quotes). Download and install malwarebytes from the sites download.cnet/malwarebytes. When the site opens up click on the Green Download button on the left. Do not click the Red Download button, that's junk. When it finishes installing the GuiInterface will open up with an offer to Accept a Trial Version or Decline. CLICK DECLINE you want the totally free version. Run a QUICK SCAN. As it scans, if it finds infections the number will be in red. When it finishes scanning, click SHOW RESULTS. A notepad text document will open up showing you the results. You can close the text document and go back to the Gui Interface where you will click REMOVE SELECTED RESULTS. The objects will already be selected for you. When it finishes removing the objects click ok and it will sometimes reboot your machine.
... Let me know if all this works out for you.
Posted on Apr 19, 2012
How to recover Embarqmail Password without phone number?
It is possible to reset Embarqmail account password without using phone number. You can choose to get one-time security code to your password recovery email address or answer your security questions to set a new password for your Embarqmail account.
Here Are The Steps You Can Follow To Recover Or Reset Your Embarqmail Account Password:
  • Open up a web browser on your PC or smart phone.
  • Go to the official web page of Embarqmail Sign in.
  • Please enter your email address in the space offered and click on Next button.
  • The next page will request you to enter your account password.
  • Click on Forgot password link located below Sign in button.
  • The following page will ask you to type the last password you remember.
  • Enter it or click on Try a different question link at the bottom of page.
  • The next page will request you to receive a verification code by text message at your phone number.
  • If you do not want to use your phone number, then please click on Try a different question link.
  • It will ask you a security question - when did you create this account.
  • Select the month and year.
  • Once you've selected the month and year, please click on Next button. That will take you to a page where you can create and confirm a new password for your Embarqmail account.
  • You can choose to receive an email containing a one-time temporary code sent to your password recovery email account.
  • Log in to your password recovery account and click on the email containing one-time temporary code.
  • Paste that code on password reset page to set a new password for your Embarqmail account.
Aug 28, 2017 | Computers & Internet
Tip
How to reset most Kenwood radios when you forgot your password
Theres several types but here are the top three.
I use type 2 more than any other.
Type 1 During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that "..." disappears). Then using your remote enter your code.
Type 2 Press the "Auto" button and "Track up" on face of radio at the same time. The four dash lines ( . . . . ) should "disappear".
Then using your remote enter your code. ------------------------------------------------------------------------------------------------------
Type 3 Press and hold the 1 then the 6 preset key (preset keys are the buttons on face of radio for storing you "favorite" radio stations). "C" should display. Then using your remote, enter your code.
Enter your number from the remote control unit. Your code number is 5227 (KCAR)
* Press numeric key "5" ( 2 times ) and press the Track UP/Next Track key * Press numeric key "2" ( 3 times ) and press the Track UP/Next Track key * Press numeric key "2" ( 1 time ) and press the Track UP/Next Track key * Press numeric key "7" ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the AM/FM mode!
Post replies :)"TRACK UP BUTTON" for 3 seconds.. and youre done.
on Sep 22, 2011 | Car Audio & Video
Have Book Worm Deluxe 1.03 version for more than 5 yrs. For 2 days when trying to download, requests "new user name," but every name submitted rejected. Why, after all these years????????
Hello!
Sometimes companies, make changes to their data base, or users, I recommend, contact via email, to them to seek for your profile. or recommend any new link that you can enter, your Username again.
Carl
Aug 03, 2016 | Book Video Game Consoles & Games
Is there a master password to Dell projector 1220s projector
You can contact Dell support below:
https://marketing.dell.com/solutions
Mar 13, 2015 | Dell Computers & Internet
Sir/Madam who ever is reading this, please please please..I had kept a pattern to unlock my mobile Samsung Behold II SGH T939....but i enterd wrong pattern just to check for more than 5 times..... now...
You're going to need to contact your cellular service provider and request to speak to Tech Support. Once you explain your problem to Tech Support they will probably request that you perform what is called a 'Hard Reset' on your phone.
When you perform a 'Hard Reset' your phone will re-boot as it was new again - which means that all of the information (names, phone numbers, email addresses and passwords will all be erased.) Then, Tech Support will re-activate your phone and this should correct the problem.
Keep in mind, a 'Hard Reset' is always used as a last resort when nothing else will work to correct the problem. That is why you should call your cellular provider's Tech Support for assistance before performing a Hard Reset yourself. They will be more than happy to assist you.
Jan 15, 2011 | Cell Phones
WHAT IS THE SECURITY COOD OF DPX8000MJ
KENWOOD SECURITY CODE CLEAR procedure
Your radio will require one of the following procedures.
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds (so that “…” disappears).
Type 2
The code is KCAR BUT its how you use the code whether it works or not the first thing you have to do is have a remote-Will not work without remote,....Turn on unit and the screen will come up for password..using remote press 5 two times,wait 2 seconds and press enter,NOT track up press 2 three times wait 2 seconds press enter,press 2 One time wait 2 seconds then enter and finally press 7 two times and press enter! your screen will be unlocked if you did it right,If you have to try again turn off and then back on.AGAIN
to reset password
* Press numeric key “5” ( 2 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 3 times ) and press the Track UP/Next Track key
* Press numeric key “2” ( 1 time ) and press the Track UP/Next Track key
* Press numeric key “7” ( 2 times ) and press the Track UP/Next Track key
The security is canceled and the set enters the TUNER mode!
Sep 29, 2009 | Kenwood DPX-4020 CD / Cassette Player
KDC-322 - New battery, now asking for password
There are afew types of override procedures for Kenwood.
Type 1
Type 2
Type 3
Model# DPX-4020 and DPX-4030
Aug 17, 2009 | Kenwood Sirius KDC-MP522 CD Player
Kvt-715 dvd
Type 1
Type 2
Type 3
Dec 13, 2007 | Kenwood KVT-617DVD Car DVD Player
Forgot my password on my kvt 715 help me please
Type 1
Type 2
Type 3
Open Questions:
Cloud Backup For Small Business 'Dataalign We understand the difficulty of reaching a great quality tech support at time. We all have gone through the phase of struggle when we have to look for reliable tech support in affordable prices. Toshiba support is now available at just a click away or just a phone call away on toll free helpline number. Toshiba support by well-informed and erudite experts who have made it a mission of their lives to provide best tech support for their customers. Customers have shown over whelming response to Toshiba tech support as it a one and only needed platform for all tech issues faced by the customers ever. Toshiba support provided by TechFree has always gained appreciative remarks from customers. They have always been praised for their hard work and dedication over the years which has resulted them in gaining a lot of fame for their work. Toshiba customers face many type of issues like dealing with their slow performing Toshiba devices, treating issues faced in Gmail, yahoo or any other email supporting site, networking issues, software not working issues, issues with viruses, malwares and issues in printers, routers or other relatable peripheral devices. These issues and many more are professionally resolved without much delay. Tech support professionals of Toshiba support use their knowledge and experience of years and together with highly advanced technologies to resolve issues of their customers in the right way. They get highly acclaimed by their work and the way they treat their customers with respect and courtesy. They make sure to patiently listen to their customer's issues in order to be able to understand the issue in depth and provide right type of support for longer lasting effects. Tech support of Toshiba can be reached via the toll free helpline number +1 888 784-9316 and they assure to be assisted by expert tech support executives. These executives work 24/7 throughout the year. They also provide 30 days money back guarantee and free device check-up along with free online data backup. For any type of tech support or computer repair services at any time of the hour call on toll free helpline number +1 888 784-9316
Jul 05, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
