Question about Cub Cadet Lawn Mower Electric PTO Clutch Replaces CUB CADET 7173385A
Turn key on to start and dash panel light goes out.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cub Cadet Master
  • 1,917 Answers
Bad switch replace it
Posted on Dec 17, 2014
My Saturn vue will not start I can put my key in and try to start it and nothing the Ani theft light came one and now it's not on but the car will not start help please
What year is your vue ? Battery an connections good ? Do the dash lights come on when you turn the key to run ? Headlamps work ?
Apr 11, 2016 | Saturn Cars & Trucks
How do my glow plus work we you turn key
when you turn the key on a light on dash goes on and the glow plug relay supplies power to the glow plugs for a certain amount of time, then the dash light goes off and you start the engine.
Jun 20, 2015 | Cars & Trucks
Turn key and just a loud click starter not turning but I noticed when key is in start position all power seems to go out dash lights radieo dome everything goes out until key is returned to run pos.
Everything is supposed to go off in the start position. You would have power to the engine computer and other components to start.
If the engine is not locked up, it could be the starter or a bad connection with one of the battery cables.
Feb 13, 2014 | GMC Sierra Cars & Trucks
1998 Honda Accord LX turn key and power goes
There's a harnes behind the ignition switch small#1philip screw harness about 12-16 inches long 1 plug change harness all set.
Dec 22, 2013 | Honda Accord Cars & Trucks
Turned key..nothing happened, dead, no dash lights interior lights or mileage, released hood button, dash instruments came on, turned key car started..while driving radio goes on and off as well as the...
Check ALL Power and Ground connections coming off the Battery to circuit anchor points. Ignition and Services fuses for a Power supply. If all proves ok, then go to the Main Ignition control Relay and check the condition of the Pins and Recepticles. That is where your apparent problem may eventually be. But travel the initial route first, looking and feeling for Loose or Dirty connecting points.
Regards, David
Nov 28, 2010 | 2006 Chrysler Sebring
How to reset dash lights on oldsmbile alero after changing oil
turn the key to the "on" position and press the reset button in the fuse panel just inside the drivers door once the change oil light starts blinking press and hold the reset button until you hear a chirp sound and the light goes out.
May 01, 2010 | 2000 Oldsmobile Alero
How do I program my key for my 2006 Chevy Impala?
Add Duplicate Key (PK3 or PK3+ key)
1. Insert an existing key into the ignition cylinder.
2. Turn the ignition cylinder to ON (RUN) and back to OFF.
3. Remove the existing key and, within fifteen seconds, insert the new key
and turn it to ON (RUN).
4. The security light will light up for two seconds to indicate success in programming
the key into the vehicle.
Originate New Master Key (PK3 or PK3+ key)
1. Insert new key into ignition cylinder and turn it to the ON (RUN) position.
The security light on the dash will illuminate and stay on for ten minutes.
2. When the security light goes out, you have one minute to start the next
step. Turn the ignition cylinder to OFF and then back to the ON (RUN)
position. The security light on the dash will illuminate and stay on for ten
more minutes.
3. When the security light goes out, you have one minute to start the next
step. Turn the ignition cylinder to OFF and then back on the ON (RUN)
more minutes.
4. After the security light has gone off the third time, the key has been programmed
into the vehicle’s computer and will operate the car. It has replaced ALL the
previous electronic key codes and is the ONLY key programmed into the
vehicle’s computer.
May 20, 2009 | 2006 Chevrolet Impala
92 honda civic turns over fine but doesnt start
ok, this is a commom problem with this 92 hondas,
it may be the pump fuel relay, which is under the dash on the driver side by the fuse panel.
here is a way to determine that.
when you turn the key on the on position
do you hear the fuel pump running while the engine light is on, and does the pump stop running afteer the engine light goes off?
if you do hear the pump running then it means that fuel pump is working fine ( since it way just replaced), but if you don't hear it running while the check engine light is on ( about 2 seconds) chances are the fuel pump relay is not working as it should.
also there are clicks that have to be heard on the starting process.
1 when you turn key to on possition
2 when the check engine light goes off( a click has to be heard just after it goes off)
3 after the car starts
If you don't hear this clicks, try to get your ear close the location of the fuel pump relay( near the fuse panel under the dash).
the fuse relay is just a bunch of circuits soldered, so you can get it to someone who knows how to solder and fix it.
or just get a replacement one at any junkyard. ( cheapp)
Nov 30, 2008 | 1992 Honda Accord
Clicking noise...car won't start
well if when turning the the key and you get a flashing dash lights that tells me that your ignition module is bad. i would also check the connections under the dash you could have a shoryt or a few loose wires.
Sep 01, 2008 | 2004 Dodge Intrepid
Change oil light remains on after oil change and light over license plate does not work after bulb change
To reset the Change Oil Light: Open driver's door and open fuse access panel
Turn ignition key to on (don't crank the starter) Push reset button located in fuse panel When Change Oil Light starts to flash Press and hold reset button until it beeps and light goes off Repace panel
Jul 17, 2008 | 2003 Oldsmobile Alero
Cub Cadet Lawn Mower Electric PTO Clutch Replaces CUB CADET 7173385A Logo
46 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
