Question about Plumbing
Manual for glacier bay faucet 476 122 - Plumbing
  • 349 Answers
SOURCE: I have a Glacier Bay(Costco) kitchen faucet. The
Check the weight and see if it has screws in it to move in on the hose line the distance it lacks retracting.
Most of them can be adjusted to proper retracting mode. It may have a couple of screws in it.
Posted on May 15, 2010
  • 122 Answers
SOURCE: Is there a way to remove the aerator from a
they unscrew from the faucet. counter clockwise.
if they are a little stubborn, you can use channel lock pliers, GENTLY grab the aerator with the pliers and GENTLY twist, counter clockwise.
do not use the pliers to re-install, just hand tight.
Posted on Aug 17, 2010
Dplumber
  • 119 Answers
SOURCE: I just installed a Glacier Bay tub/shower faucet
The faucet may be installed upside-down.
Posted on Aug 25, 2010
  • 13 Answers
SOURCE: i have a single control, new glacier bay bathtub
it is likely required. many new faucets have what's called a pressure balance valve that helps prevent scalding by lowering the pressure of hot when the cold pressure drops (due to a toilet flush or other water being run). Because you have pressure to only one side, that can cause the valve not to provide the necessary volume.
Posted on Dec 12, 2010
bbl242003
  • 1637 Answers
SOURCE: do you know who sells glacier bay faucets
Press Accept or replay
I have a solution for this
Bruce
Posted on Jan 14, 2011
I have a Glacier Bay shower faucet that is getting increasingly harder to control water temperature out of shower faucet! Water temperature is very hot
check the hot water supply first and if needed adjust if to high and or check your anti scald setting --need to remove the center handle on the mixing valve
How To Adjust Glacier Bay Anti Scald Device Yahoo Video Search Results
Jul 31, 2017 | Glacier Bay Home
Tip
How to remove Glacier Bay Lever Kitchen Faucet Handles
To remove the lever handle from a Glacier Bay two-handle kitchen sink faucet: Insert a 2.5mm hex wrench into the small hole underneath the lever. Work the wrench into the small handle set screw.Turn the wrench and setscrew counterclockwise to loosen. Pull the Glacier Bay lever handle off the faucet stem. P.S. You do not need to remove the screw to take the handle off.
on Oct 07, 2010 | Globe Union Glacier Bay 8 In Double Handle...
How do I put seats and springs in a glacier bay Aragon three handle knobs
How to Repair a Glacier Bay 3 Handle Tub and Shower ...
www.faucetinstructions.com > Glacier Bay Faucet Instructions
My three Handle Glacier Bay Tub Shower Faucet Makes a High-Pitch Squealing ...The Glacier Bay tub faucet screw-cover buttons will not stay on the handles. ... Sealthe flanges to the shower wall with a high-grade anti-microbial kitchen and ...
Nov 07, 2015 | Plumbing
Glacier bay led faucet will not light up
It has lost power. If AC, check the electrical breaker, if battery operated, replace the battery.
Aug 04, 2014 | Plumbing
Where to buy handle adapter for glacier bay bathroom faucet
Glacier Bay is a generic faucet brand sold by Home Depot. Good luck finding any parts for it.
Jul 13, 2014 | Home
Glacier bay faucet manual
yup getting a regular wrench up there is not a option...
or a good one...
what you need is a basin wrench get one at the big boxes or local hdwe store. You won't use it often but when you do it makes life good!
here's how they work....
https://www.youtube.com/watch?v=w3mibmhjwHA
Jan 26, 2018 | Plumbing
Do you know who sells glacier bay faucets
Bruce
Jan 14, 2011 | Globe Union Glacier Bay 8 In Double Handle...
How to repair facet stem for glacier bay products kitchen sink
Theres not much you can do to repair the stem except replacing the small O-ring up inside. You can call Glacier Bay and ask for a new stem ( the faucet has a limited lifetime warranty. You can also use Delta faucet repair parts in your Glacier Bay kitchen faucet; they come from the same mold. Heres a link to Glacier Bay 2 handle kitchen faucet repair. Heres one to the Glacier Bay faucet manual for your faucet.
Sep 16, 2010 | Globe Union Glacier Bay 8 In Double Handle...
Need a manual for glacier bay model 881-0002 faucet. Can you e-mail me a pdf?
<a href="http://faucetinstructions.com/glacier-bay-teapot-roman-tub-set-in-polished-brass-model-881-0002,-173-418l(881-0001),-173-418l(881-0002),-173-418l(881-0005).html">http://faucetinstructions.com/glacier-bay-teapot-roman-tub-set-in-polished-brass-model-881-0002,-173-418l(881-0001),-173-418l(881-0002),-173-418l(881-0005).html</a>
Aug 11, 2010 | Plumbing
Plumbing Logo
167 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
