Home | Kyocera | Copystar CS-1820 Black and White Copier | CS 1820 color scan qua...
Kyocera Copystar CS-1820 Black and White Copier
Problem for Kyocera Copystar CS-1820 Black and White Copier
CS 1820 color scan quality issues
By pcs3 on Jun 18, 2009
When I scan a color document to a color printer the colors are way off example there are a 3 yellow box's they become a pail green and there is a lot of shodows as well in both black text and color images.
Solution #1
posted on Jun 22, 2009
Not Rated)
copiergeek
Rank: Guru
Rating: 94%, 28 votes
hi
try and scan the doc to your p.c first. If this is ok print the doc on your colour printer.
each brand of machine uses different ways to get colours, and yours do not match
Was this helpful?
Yes
No
Popular Solutions for Kyocera Copystar CS-1820 Black
Questions and Unsolved Problems for Kyocera Copystar CS-1820 Black
Do you recommend Kyocera Copystar CS-1820 Black and White Copier?
Answer
Answer
How do you set the fax mode to manual reception? Copystar cs-1820
Answer
The scan to file is terrible, I have a share on each workstation "\scanner" and each user... (More)
Answer
it wont execute when i try to press enter on the "execute" menu..
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kyocera Copystar CS-1820 Black...:
Top Copier Experts
Rank: Guru Guru
Solutions: 1504
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
