Question about Copystar CS-1820 Copier
Error code c6300- How do you reset this copier? Copystar GS-1820
  • 143 Answers
Enter the service mode and enter reset code 163.
Posted on Jun 26, 2009
E 6000
6000 error. Broken fuser heater lamp wire The fuser temperature does not rise after the fuser heater lamp has been turned on
Nov 12, 2013 | Kyocera Copystar CS-1820 Black and White...
Getting error code 2101 when scanning a document into our kypcera mfp cs 1820. What is the error and how does one fix it?
you have to have a user name and password set up on the computer you are scanning to then you set theat up in the address you set up on the copier.
Mar 02, 2010 | Kyocera Copystar CS-1820 Black and White...
Service code c 6000 comes up what do we do? 314 308 5296
fuser error..nothing you can do but replace the fuser unit..
Jan 25, 2010 | Kyocera Copystar CS-1820 Black and White...
Copystar 1810 GS
that's because it thinks it's out of toner. keep opening and closing the front door and let it run.
Jan 21, 2010 | Kyocera Copystar CS-1820 Black and White...
How to reset gs-1820 copystar to factory default
press system menu/counter
select service settings via up and down cursor keys
now while pressing start key and # key press enter
then select maintenance mode by using the up down cursor key
then use the arrow keys to get to u020
and select and then run the reset...
these machines do not automatically restart so you will have to flip the power switch manually to reset the machine
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 10, 2009 | Copystar CS-1820 Copier
Cs 1820, shows code co220
error code is for a communication problem between two of the internal printed circuit boards. I would just open machine toner door and close to see if it resets if not , you'll have to find a dealer for repair
Apr 04, 2009 | Copystar CS-1820 Copier
Kyocera cs 1820 or copystar = error message = 3200
3200 is a problem with the exposure lamp. If you are in a dirty enviroment, the problem could be dirty mirrors under the scanner glass.
Apr 02, 2009 | Kyocera Copystar CS-1820 Black and White...
Error code c6300
The code C-630 indicates an abnormally high fixing temperature.
Check the thermistor, if it is shorted, replace.
the Fixing Heater Control Circuit is located on the power source PCB> relace as needed.
Apr 01, 2009 | Copystar CS-1820 Copier
Error C6000 - call for service
hello sir; It can be reset the procedure as follow;
1, press and hold down these keys by order, "start', left "#",
2, press "enter".
3, enter 163 then press enter.
4, choice "execute", then press "enter".
5, turn off the power and back on.
Feb 09, 2009 | Copystar CS-1820 Copier
KYOCERA copystar CS-1820 ERROR C6000
Your problem is heat related, or the lack of heating at least. one of 2 things went wrong here... either the fuser unit overheated causing the thermal fuse (aka the thermostat) to blow, or the heating lamp in the fuser unit is blown. Basically the 6000 code is displayed when your machine fails to reach the correct temparature at a specific time. Unfortunately you will have to call a service person to check which to of the mentioned components are at fault and to replace that component for you. After replacing, the component the code will still be displayed as a safety measure, so the service representative will need to clear the code via the machine's service mode
Sep 22, 2008 | Kyocera Copystar CS-1820 Black and White...
156 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
