Question about Samsung Refrigerators
Rf266abpn reads 88
Side by side
8 e code
Most like it is a defrost sensor error in the FF section. On the back of your refrigerator there should be a schematic of what happens when there is an error...normal when performing the self test and all is ok is a reading of 88 88 Different parts of the 8 will blink depicting the error. For 88 88...if the last 8 is blinking the sections on the right side of the eight it looks like an E...but it is not.,..it is blinking an R1 b, or R1 c error. Looking at the chart R1 b is Sensor System in FF Compartment Errors, and R1c is Defrost Sensor Error in FF Compartment Errors.
I hope this clears things up as I see a lot of people say there panel is flashing 88 8Y, or 88 8E when actually it is just different parts of the 8 blinking.
Feb 20, 2014 | Samsung Refrigerators
Samsung bottom drawer freezer is leaking and ice is forming along both sides of the drawer?
Is there a drain at the rear for when it defrosts that has become blocked? Defrost fully and clear drain hole
May 20, 2012 | GE Profile Arctica Stainless Steel Top...
See previous answer re drain blockages. Also check condenser clean and all fans working ok.
May 20, 2012 | Samsung Refrigerators
I Have a rf266abpn and the icemaker front plate f...
I know this is a little old, but I had the same problem. It turns out that under the Ice tray, there are some plastic clamps that you can set the hanging hose onto, along with a hook that the thermostat (harder thing) hangs on.
May 19, 2010 | Samsung RS2534 Side by Side Refrigerator
Samsung RFG 297 series... contro panel reads 88 88
This is technical unit an they can be pretty touchy with power outages sometimes. It may be in a display mode. If you havent already try unplugging the unit for a minute or two and plug it back in. This doesnt reset its programming try holding Energy Saver Key + Lighting Key for 8 seconds and let the unit run thru a self diagnstic test and hopefully it will reset. If neither works its going to have the main board replaced.
Jan 23, 2010 | Samsung RM255LASH Side by Side...
Samsung RF266ABPN icemaker just fell apart and I don't know where to put the parts. Is there a diagram somewhere on the Internet?
your manual could solve all your problems .. if you don't have a manual you can order on line and put your ice maker back together. if not call a service teck and he will do it for you...
Aug 12, 2009 | Samsung RS2534 Side by Side Refrigerator
My Samsung French Door RF266ABPN has a warm freezer and the LED is flashing for the freezer temperature. Unit is less than one year old.
I have read that if you unplug the unit and plug it back in again, it will "reset" it. I would wait 15 or so minutes before replugging just to be sure. Of course, this solution doesn't preclude the problem from happening again - sounds like a manufacturing defect to me.
Apr 07, 2009 | Samsung Refrigerators
Control panel inactive
Your refrigerator is in demo mode. Review your manual on how to remove it.
Feb 24, 2008 | Samsung RM255LASH Side by Side...
Refrigerators Logo
16 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
