Question about Husqvarna Zero Turn Mower Z5426
Iz2352 husqvarna zero turn runs hour or two then need to jump it to start
Run hour or two then need to jump it to start
5 Suggested Answers
  • 109 Answers
SOURCE: Husqvarna zero turn mower won't start
Usually if all you hear is a clicking noise, it is the solenoid itself that has gone bad...if you can jump the solenoid and the mower turns over, it is the solenoid.
Posted on May 03, 2009
SOURCE: I have a Husqvarna 23hp 48
not sure but is battery being charged the right way have seen battery's put in and charged backwards
Posted on May 15, 2009
mickey813
  • 472 Answers
SOURCE: hour meter flashing hours and oil
soundslike the oil sensor is bad
Posted on Oct 15, 2009
  • 6468 Answers
SOURCE: husqvarna zero turn runs great but after about 30 mins the blades stop turning
when this happens you need to see if it you loose power to the clutch to see if the clutch is failing or the circuit feeding it power
Posted on Apr 28, 2012
2015-16 Husqvarna zero-turn lawn mower MZT52 will not start up again after engaging the hand brake.
The is a problem with one of the switches in the safety circuit. Either the seat switch or brake switch is bad.
Does the mower start and blades run without the brake? If so, the problem is probably the brake switch itself.
Sep 11, 2017 | Husqvarna Garden
My zero turn RZ4623 will start & run fine in idle, but with blades engaged it only runs about 20 to 30 minutes, and quits.
check your battery if it is weak sometimes the PTO takes all the voltage and motor can not run.
Aug 02, 2016 | Husqvarna Garden
How do I bypass the seat safety switch on a 5424 Husqvarna zero turn mower?
ether unplug it if wont start then jump the wire pigtail with a wire you can bypass both switch like this
Sep 16, 2014 | Husqvarna Rz5424 Zero Turn Lawn Mower...
Is it safe to jump start my zero turn mower from my car?
Check your battery with a voltmeter and also check for safety switches. Make sure you blade switch is off, parking brake is on, and handles are all the way out or apart. On mine when you try to start it the hour meter will show battery voltage and if something is not in the correct position it will light up an indicator light showing a safety switch corresponding to what is wrong
Sep 02, 2014 | Husqvarna EZ4824 24 hp 48" Zero Turn Lawn...
Mower has warning light won oil
If the warning light says "chg oil" the meter is telling you it is time to change the oil. The meter will automatically re-set after 6-8 hours of run time. It cannot be manually re-set.
Jul 08, 2014 | Husqvarna Zero Turn Mower Z5426
Have a husqvarna zero turn I have to jump starter from battery for it to start....Why ?
Take the battery to your local auto store and have charge it and then do a load test on it. If it fails then it is a bad battery.
Aug 15, 2013 | Husqvarna 54'' Package Deal Zero Turn...
2011 zero turn Husqvarna 4216 still on lot. What's it worth?
start it run it use it before it leaves the store
never give asking price 2g or less
Jun 08, 2013 | Husqvarna RZ4216 165 hp 42" Zero Turn Lawn...
May 01, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Zero Turn Mower Z5426 Logo
27 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
