Question about Epson Stylus CX9300F Series
Waste ink pad is saturated. how to replace it?
loumsc
  • 114 Answers
SOURCE: EPSON r360
Are you sure it is staurated or it just the printer showing the error. Apparently there is a usage timer in the printer firmware that will display this error after so many hours of usage. Epson has a small program to reset this error but warns that if the pad is saturated it may leak out onto you table/desk. My R220 displayed this error and I reset it with Epsons resetter program. If you are not sure of the pad, I would put something under the printer just in case it is saturated and leaks. I don't think you can buy replacement pads from Epson as they say the printer is disposable. I also don't know what material the pads are made of but I have never seen one overflo in all the years I have used Epson printers. There is always a first time so if I were resetting mine I would defininately put something under the printer to watch for leaking ink. The program to reset the ink counter is EpsonIPRUtility.A10.exe and is available at www.Epson.com
Lou
Posted on Aug 23, 2008
SOURCE: Need To Replace The Waste Ink Pad on my Epson Stylus C66
I modified a little what Worldvet had done. I opened the door as if to change the ink cartridges. I first used a pair of needle nosed pliers and carefully took out the sponge type pad which is along bottom of the printhead travel lane. One will see the two center plactic guides within this lane. The sponge is very delicate, so be very gentle in removing it. It has ink residue in it so use gloves if necessary and upon removal place the sponge on a paper towel folded in triplicate so the ink does not bleed through the towel. Remember to what position it was before removal, so there is no problem when you try to replace the sponge after cleaning.
The second sponge I removed as follows: With the power on, I pressed the ink cartridge removal light (red) (far left) once. This moved the print head to the "far left", before the position to change cartridges. With the power still on and the printhead to the far left, I was able to very gently (with the same needlenose Pliers) remove the sponge under where the printhead was parked. It too is very delicate and be careful not to rip it. It too, one will find, has two plastic slots on the botton which the sponge will have to be returned into. I then turned the printer off, which caused the printer head to return to the parked position.
I took both sponges, and with Alcohol (Pharmacy type), I placed the sponges in a disposable plastic bowl and filled it with the alcohol. I gently used the needle nosed pliers (Closed) as a device to gently press on the sponges which were submerged into the alcohol. I continued to alternate up and down the sponge pads, causing the alcohol to dilute and clean the pads. When the alcohol became saturated with the ink from the pads, I took the pads out of the alcohol bowl and placed the pads on a triple folded paper towel so the remaining ink would not bleed through anything.
I then took the bowl of alcohol/ink and while I flushed the toilet and the water was going down, I emptied the alcohol down the middle of the water spout as the toilet water was completing its flush. This keeps any ink from touching any porcelion.
I then refilled the plastic bowl again with fresh alcohol and resubmersed the pads, just incase there was any ink still left in them. Upon pressing on the pads and the alcohol remained clear (indicating all the ink was removed) I again used another set of paper towels, trippled, and placed the pads onto the paper towels, and squezzed them dry. I disposed of the alcohol the same as before.
I then, first replaced the large pad onto the printhead travel lane, back into the same position, being careful that the holes and slots fits back into its proper position and the edges are tucked under the proper hooks (little plastic hooks attached to the side of the travel lane).
Upon reinstallation I pressed gently on the pad to make sure it was secure.
Replacing the second pad, I again turned on the printer and pressed the ink replacement light (red), same as before, causing the printhead to travel to the far left as before. I then very carefully replaced the second pad into the slot from which it came from.
After I made sure the second pad was secure in its proper position, I pressed the ink replacement light twice, causing the printhead to return back to the parking position. I had already reset the counter, so that was not neccessary. I returned to the computer and printed a test page to make sure the printer was working properly, at which time it was, so I therefore returned to what I was doing and the Service Warning was cleared. My fingers got a little ink; but what the heck, soap will take care of that! Good for another 20,000 pages. Hope this helps, not as bad a it sounds.
Posted on Mar 26, 2009
tigertail
  • 163 Answers
SOURCE: waste ink pad saturated. EPSON STYLUS PHOTO R360
Replacing the pads is costly, messy and requires the printer to be taken completely apart. If you have little or no experience of stripping down printers it is best left to a proffessional. Contact Epson to find your nearest service centre, but remember to get a quote as it may be more economical to replace the printer. Sometimes the counter can "jump" to the end of life number, this especially happens where 3rd party or refilled inks have been used. If you believe this to be the case and there is no sign of ink leakage and the pads look fairly clean then you can just reset the counter using special software called the SSC utility. See these sites:
http://www.ssclg.com/epsone.shtml
http://inkjetprinterhelp.us/epsonSSC.html
More information about this issue and the "official" Epson resetter is available from the Epson web site, please read this link:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Please take a moment to rate this solution. Thanks.
Posted on Apr 14, 2009
  • 5 Answers
SOURCE: EPSON 2200 - Waste Ink Pad Replacement
You can replace the pads yourself.... I wouldn't really mess with it though. There are other ways Google search "Waste Ink Epson 2200" to see how to setup an external tank.. I have mine setup this way and its been no problem.... If you're set on taking them out remove the screws from the sides and middle and the bottom will drop away and reveal the pads.
Posted on Apr 16, 2009
SOURCE: waste ink pad is saturated how can i reset
You can also try dabbing the waste pad with absorbing paper. This worked for me.
Posted on Dec 21, 2009
How to reset counter
Waste ink pad typically captures ink waste when the printer cleans itself (print head). Resetting the counter without replacing the absorbent material can cause ink leakage and a profound mess.Epson suggests servicing the printer, but it may be more cost effective to replace it.
Aug 18, 2014 | Epson NX200/SX200/TX200
EPSON R545 waste ink saturated
You need to reset your printer. Goolgle search for "indoreset for rx595" and download it. That is the program you need to use to reset the waste ink pad counter back to zero.
Jul 20, 2010 | Epson Office Equipment & Supplies
What is waste ink obserber? How it will be replaced?
waste ink pad absorber is like a waste tank made of absorbent pads, in here the waste ink is absorbed. In time this waste ink pad will be saturated or full. When it happens the printer will suddenly stop working. The printer needs to be reset to function again and the waste ink pad replaced to prevent flooding of waste ink inside the printer. The waste ink pad is replaced by disassembling the printer.
Jan 17, 2010 | Canon PIXMA MP150 All-In-One InkJet...
I have a warning that my ink pad is saturated and needs replacing contack dealer for assistance (help)
Ink means pad for waste ink nearly full. Epson program read and count all waste ink from head cleaning and ink charge. Next, you need reset waste ink counter, and replace or washing pad. You can extend outlet pipe to outside of printer, so next time you don't need replace pad again.
Jun 27, 2009 | Epson Printer
Ny epsom r360 reads ink pads saturated
don't replace the ink pads install a external waste ink tank instead, then reset the printer using reset program . . search on eBay for epson waste ink tank it incudes the reset program.
Jun 07, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson stylus 830Uink pads full not printing help
The Waste Ink Pads in your printer are saturated with ink and the waste ink counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. Should you decide to have a go at changing the waste ink pads, the 830 service manual can be downloaded from here:
http://www.mediafire.com/?m6ouftizois
Jul 13, 2008 | Epson Stylus Photo 820 InkJet Printer
Epson C46 has stopped printing with message saying service needed but nobody wants to make it carry on working
If both printer lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced as soon as possible. You can overcome this problem temporarily by using the SSC utility - download from
If you wish to pursue this matter further, report back.
Apr 12, 2008 | Epson Stylus Photo R200 InkJet Printer
Computers & Internet Logo
48 people viewed this question
Top Epson Computers & Internet Experts
teamtech
teamtech
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
