Question about Kitchen Ranges
We have a frigidaire professional series range. While moving the range the hinge came loose on the right side. how do I get this spring loaded hinge back to where it supposed to be.
  • 495 Answers
Try putting the spring back. If not possible then call service dealer.
Posted on Jun 18, 2009
Frigidaire Dishwasher door hits on the upper right hand corner when closing. Dishwasher works fine but don't want to have problems later on
check the screws on that side where it's ready you might have to loosen them up and drop the door so it will fit perfectly
Jan 18, 2015 | Frigidaire Professional Series 24 in....
Frigidaire dishwasher (FDB1100RHC2) is leaking from bottom right corner and it appears there are small hairline cracks on the plastic tub. Is there a way to repair them?
Hello - Do you notice if the dishwasher have deflectors installed in the bottom left and right corners of the tub gasket channel? If so, confirmed that they are properly installed and present. In case that it is not, they may possibly need replacing. However, from what you have described it sounds like the springs or hinges may possibly be damaged, or gasket not sealing properly. I would strongly suggest contacting a professional to move forward accurately.
Oct 12, 2012 | Electrolux Frigidaire Professional Series...
Frigidaire over range microwave oven: Door hanging from only top hinge when opening/closing. Came off bottom hinge and can't figure out how to access to repair.
take 3 screws out to take bottom off then you can reach the hinge -I put a screw with a nut in the hole there above the hinge,
fixed mine
Feb 04, 2010 | Frigidaire Professional Series PHS68EJSB...
Frigidaire Gallery Series ES340 ceramic-top range:
The manual is missing a step. After pressing Clean or Quick clean you need to press the ^ button once.
Apr 23, 2009 | Frigidaire FEF366 Electric Kitchen Range
Replacing the oven door to the Whirlpool electric range RF375PXE
There is a hole in the hinge, for placing a pin, to hold fully open. Two man job. One forces the hinge into the fully open position; the second inserts the pin (nail) into the hole.
Jan 31, 2009 | Whirlpool Kitchen Ranges
2002 Thermador Gas Oven door - can't get back on after removal!
You have to get the tension off of the hinge and it will drop right in. The spring loaded arm on the door needs to be drawn back until you can (depending on the style) either lock the u-arm into the notch on the other side of the hinge, or put a small bolt through the aligning holes in the side of the hinge. Once you get the arm straightened out a bit and relieve the spring pressure, you should be able to sit it right in there. Be careful though, that spring is strong.
Oct 25, 2008 | Thermador PGR366 Gas Kitchen Range
Oven door came off
open the door on the hook that's still engaged look in the slot you will see a hinge lock using a small screw driver flip it back to lock the hinge then let the door up til the door engages the hinge lock grasp the door on either side and lift up and back to take the door off then pull the other hinge out till you can lock it then grasp both sides put the hinge hooks on the pins in the slot open the door all the way and fold the locks back in the body of the range and close the door
Feb 13, 2008 | Frigidaire FEF376 Electric Kitchen Range
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
