Question about Friedrich CP12G10 Chill Series 12,000 BTU Window Air Conditioner with 3 Speeds, 24 Hour Timer, Remote Control and Energy Star Qualified - R410A Environmentally Friendly Refrigerant
Unplugged air conditioner and plugged back instarted without tuning on
Accidently unplugged unit without turning power off. when plugged back in power will not come on. i reset the plug and got the green light and when hit test it popped as per the instrunctions on the cord.
Because you used a common plug that already has 5 or more amps of current on it it would be bound to trip easily. Many modern homes that are put together fast have the wires pushed in the back of them and hence can't take a huge load like that. One of the plugs in the system likely failed to pass the power to the next one in the chain. That is why an informed consumer calls an electrician when they get a new appliance like an air conditioner and have a designated plug installed with a wire size and a breaker that can handle it. Sometimes they put in a high quality commercial plug.
Jul 01, 2013 | LG Goldstar GWHD5000 wall/window Air...
READS E1
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Aug 08, 2011 | Haier HWR08XC7 Air Conditioner
E1 error code
Aug 07, 2011 | Haier HWR06XC7 Air Conditioner
Unit will not turn on without the remote.
To operate the unit without having the remote .. Turn the unit OFF and unplug it for 15 minutes. After the time has elapsed, plug the unit in and turn the ON/OFF Switch to ON. You should now be able to operate the controls on the unit itself. As it should have reverted back to the original factory setup settings.
Hope this helps you and thanks for choosing FixYa.
Aug 07, 2011 | Amana ACD105R 10000 BTU REMOTE/TOUCH ROOM...
Turning off code e1 flashing what is e1 code
Jul 28, 2011 | Sharp Comfort Touch AF-R120EX Air...
What does E1 mean?
This is a reminder to clean the air filter. It happens every 720 hours of operation. Here are the steps to get it back up and running:
1. Power down the air conditioner using the "power" button on the front panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air conditioner normally for another 720 hours, but only if you followed the instructions above EXACTLY.
Jun 26, 2010 | Sharp Comfort Touch AF-R120EX Air...
Air conditioner is flashing e1
hi..
panel.
button.
thank u
rate me
Jul 18, 2009 | Sharp Heating & Cooling
The screen is flashing E1
I was told the filter needs to be cleaned.
Turn the air conditioner OFF and unplug it.The air conditioner must be unplugged for the automatic filter clean timer to reset. Clean the filter. After cleaning, replace the filter and plug the air conditioner back in.
Hope this helps :)
Aug 07, 2008 | Danby Heating & Cooling
Aircondition not working
E1 indicates  Filter needs replacing/Cleaning , this code flashes after 720 hours of operation time.
Disconnect the power plug
Clean or replace filter
HOLD DOWN (dont let go) Of  the ON/OFF button and plug the unit back up and continue to hold the ON/OFF button until you hear a beep
After the beep unplug your A/C
Then plug it back up to and turn it on for normal operation
IF THIS FAILS TO REMOVE THE CODE
UNPLUG A/C  THEN HOLD DOWN THE MODE BUTTON AND PLUG IT UP STILL HOLDING THE MODE BUTTON UNTIL YOU HEAR A BEEP.
UNPLUG UNIT  AND THEN PLUG IT BACK UP AND ONE OF THESE 2 STEPS WILL FIX YOUR PROBLEM   UNLESS THERE IS A MAJOR PROBLEM IN THE CONTROL BOARDS
Oct 13, 2007 | Sharp AFS60FX Air Conditioner
Fedders air conditioner beeps but doesn't turn on.
Unplugged unit first. Take control panel out but dont unplug wiring. Cut Firth wire out from the center on the touch pad six wire plug. Cap both ends and plug back in. now unit will run on high cool and turn it on and off by plug and unplug
Aug 15, 2007 | Fedders X Chassis A6X05F2B Air Conditioner
Friedrich CP12G10 Chill Series 12,000 BTU Window Air Conditioner with 3 Speeds, 24 Hour Timer, Remote Control and Energy Star Qualified - R410A Environmentally Friendly Refrigerant Logo
Top Friedrich Heating & Cooling Experts
Bill Long
Michael Vincent Cruz
Tim Whalen
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
