Question about Kitchen Appliances - Others
Bunn troubleshooting water in the reservoir is cold on a BX-B Model
  • 2039 Answers
SOURCE: BUNN BX-B Coffee Maker Leaking
is it the water container that leaking the best thing to do is open it maybe is a loose pipe or dry pipe connected to water container and if it the water container use 5 or 1minute epoxy cheers
Posted on Jan 29, 2008
freetek
  • 5568 Answers
SOURCE: Bunn BX-B
I didn't download it since we have a lousy connection but your manual should be available here:
http://common.csnstores.com/common/marketing/bun1002_use_manual.pdf
Despite the '1002' in the URL, it is the link for your model.
Posted on Oct 20, 2008
  • 131 Answers
SOURCE: empty bunn coffeemaker
The easiest way to empty these brewers is to turn them upside down over the sink. Turn it on it's side, always keeping the fill hole down toward the sink, and keep on going until you have the unit completely upside down. If there is a push switch under the lid to stop water from going into the pot until the lid is closed, you will have to keep this pushed in until the unit is empty
Posted on Feb 11, 2009
EsWorld
  • 1618 Answers
SOURCE: The Bunn CW Series overflows the pot. How canwe
Open the front panel, there is a set of instructions on it, you will have to make sure the board is set to program and not lock, before you adjust.
Posted on Aug 14, 2009
  • 3 Answers
SOURCE: When I pour water into (empty) pot to fill. Bunn coffee maker
If you pour water into the machine, and water comes out, then the reservoir is full of water. There is no way the water can bypass the reservoir and go directly into the pot.
Posted on Apr 28, 2010
How to fix a leak on a bunn NHBX coffee maker
The leak is most likely between the water reservoir and the tank. Bunn uses a soft silicone seal for that connection that gets compressed over time and starts to leak water whenever you make a pot of coffee.
It's planned obsolescence. Bunn won't sell you a new seal. So you have to improvise. But it's simple enough to do.
Remove the top cover and the plastic water reservoir right below it. Don't tamper with the little valve that opens when you close the lid.
Look for the seal. It could be stuck to the bottom of the reservoir, or sitting loosely on top of the metal tank. Make sure to preserve its top-to-bottom orientation (don't put it back in upside down).
Apply a narrow bead of clear silicone into the grooved side of the seal. Press the seal gently onto the reservoir, then apply a thin layer to the smooth side.
Re-install the reservoir and reassemble the unit.
Aug 09, 2014 | Bunn NHB Coffee Maker
When making coffee water dumps water all over the counter,extremly irritated.third one weve ownd w/ the same problem.unless this is easy fix i wont buy bunn again.
Please call customer service at 800-352-2866 with the model and date code. We will be able to either replace or repair your unit.
Jan 07, 2011 | Bunn BX HOME BREWER 10-Cup Coffee Maker
It only makes 1/2 pot when I pour the water in after sitting over night some times it takes 2 pot of water or more to make a full pot
I recommend slowly pouring in about a half a pot of cold water without coffee in the filter basket 5 or so minutes before you brew in the morning. There are 2 good reasons to do this-
1. Overnight you are having some evaporation due to the fact that your Bunn brewer has a reservoir that keeps a couple of pots worth of water at brewing temperature... a better temp than most "home" model brewers. This will top off the reservoir and you will not "short pot" except for the amount that the grounds themselves hold back.
2. Also overnight, due to the fact that the water is kept hot, the oxygen can dissipate from the water in the tank. Topping off with fresh water will mean a fresher first pot.
The Bunn brewers have a low wattage/keep warm heater so the actual heating element isn't doing all of the work over those long periods... it only kicks on when the temperature in the reservoir drops considerably (like after brewing). Be sure to let the brewer heat back up before brewing (you will hear it stop heating)
Hope this helps.
Oct 28, 2010 | Bunn Pour-Omatic Coffeemaker, 10 Cup White
My bunn stopped working completely. It will not heat water and warmer wont come on. All switches are in correct position
Plug something else into the same outlet and see if you are getting electricity in that outlet. If it is on a ground fault circuit, push the little red button in in the middle of the outlet. or check the breaker box to see if the breaker has kicked. It is unusual for everything to quit working at the same time if it is getting power.
Sep 08, 2010 | Bunn BX HOME BREWER 10-Cup Coffee Maker
My brand new Bunn BX... despite following exact measuring for the perfect cup of coffee, and trying various stronger measurements, my coffee comes out tasting like water. When I look at the grounds after...
It sounds like you might be missing your sprayhead. If you remove the filter basket and look up above it, there should be a dome piece with 5 holes in it. If not, please call customer service with the model and date code and we can provide you with a new sprayhead.
Dec 25, 2009 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Unit leaks water from bottom bunn pouromatic
What model of Bunn is this? If it is a bx-b or any of the other home models, what has happened is that the plastic pour-in tray has become brittle and cracked where it mounts onto the tank. The only repair for this is to replace the tray with one from another brewer (possibly your local bunn Dealer has an old brewer lying around). If it is a commercial brewer (VPR, VPS, Ect) there will be a sael leaking on the top of the tank.
Nov 26, 2009 | Bunn Coffee Makers & Espresso Machines
I haveBX-B . I had the pot set up for me to push the on button for Monday Morning, but the water ran throug and it was not on.So now I have cold coffee in the Decanter.
The Bunn coffee maker does not operate as most coffee makes do. You cannot leave the Bunn in the off position and then just flip the switch to on and pour the water in. You will always get cold coffee if you do this. It takes time for it to heat the water. The On/Off switch should be left in the On position all the time. This keeps the water hot in the tank, thus providing hot water when you need to make coffee. You then just pour the cold water in the top, shut the lid, and have a pot of coffee in 3 minutes. The On/Off switch is a vacation switch, and you use it only when you are not going to use the coffee maker for a couple of days. Older Bunn coffee makers did not even have an On/Off button. You simply unplugged them when going on vacation. So turn the switch to the On position and leave it there. The unit will then work as designed. Forget how other coffee makers work, this is a Bunn and it is the fastest coffee maker you can buy and must be left on all the time. that way the water stays hot and the unit will keep it that way.
Nov 16, 2009 | Bunn BX HOME BREWER 10-Cup Coffee Maker
Bunn BX-B
Oct 20, 2008 | Bunn NHB Coffee Maker
Jan 29, 2008 | Hamilton Beach BrewStation Deluxe 47474...
Kitchen Appliances - Others Logo
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
