Question about Echo Garden
Echo Chain Saw Service Repair Manual Cs-400evl Gas Saw Kioritz Corp
Loringh
  • 185 Answers
SOURCE: Chain saw starts with starting fluid only but will not run.
Hi lwhssh:
Suggest you drain the fresh gas/oil and add a fresh batch but first add a gas stabilizer to your batch of gas/oil in the storage container. You will probably still need to use starting fluid for a few times When 2 cycle engines sit for a long period of time, the gas/oil mixture undergoes a change and tends to leave a residue on the delicate parts of the carb. The gas stabilizer will help that.
I always do the following for 2 cycle engines when I put them up for the winter. Empty the gas container on the device and then start it to use up any gas left in the fuel lines and carb. this keeps any residue from forming.
Hope this helps Good luck Loringh PS please leave a rating if appropriate. Thanks
Posted on Nov 29, 2008
  • 398 Answers
SOURCE: need to know oil to gas ratio mix for echo 510 evl chain saw
50:1 or of its old 100:1
Posted on Mar 20, 2009
dontbother10
  • 2220 Answers
SOURCE: How do I change the primer bulb on my Echo CS-3000
The IPL for an Echo CS-3000 is here:
http://www.echo-usa.com/pdf/documentation/CS3000T1T1E_081303.pdf
See page 8. There is no shop manual offered, you will need to interpret the pictures. Didn't look to difficult. GL
Lou
Posted on Sep 07, 2009
Testimonial: "Having the parts list helped me to understand how the primer bulb was installed. A great help. Thanks, Ed"
dontbother10
  • 2220 Answers
SOURCE: trying to replace gear on echo cs 440 chain saw
The IPL for a model 400 Echo can be found here:
http://www.echo-usa.com/pdf/documentation/CS400_C090_11_081007.pdf
It should not matter but please verify this fits your serial number.
From the IPL your saw has an outboard clutch. Use this the following as a guide. I didn't see any special tools on the IPL.
R² Drive Link Outboard Clutch
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check at the IPL for your saw to see if any special tools are needed.
  2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. It is probably a left handed thread (tighten it to loosen it).
    Let us know how it worked for you. GL
    Lou
Posted on Sep 13, 2009
  • 4088 Answers
SOURCE: Chain brake jammed on Echo CS400 chainsaw
You will need to release the brake by applying a very heavy screwdriver to the + shaped part of the brake coupling. Check the action of the brake handle and duplicate it at the the +. Hope this helps!
Posted on Jun 26, 2010
How to replace clutch spring on a echo 650 chain saw?
id replace the entire clutch as if spring came out then therese got to be a reason
Mar 01, 2015 | Echo Cs-650evl Cs 650evl Chain Saw...
Echo chain saw has no spark how to fix
Not being facetious here... change the spark plug as a first step. They require regular replacement. If that doesn't work, use a multimeter to check that the spark plug wire is actually releasing electrical pulses. If it isn't, you'll need to keep moving further up the line to the coil.
Sep 01, 2014 | Echo Chain Saw Service Repair Manual...
Which is the gas and which is the oil plug
The forward one is the fuel, and the rear (near the handle) is the oil.
Jul 07, 2014 | Echo Chain Saw Service Repair Manual...
Air vent in my echo 3500 cs chain saw
Take a fine bit drill and gently turn it through the hole
Apr 07, 2014 | Garden
How to change the fuel filter on an Echo 315
Im going to assume that this echo saw is the same as most saws. Open your fuel tank and remove the cap completely. Empty the fuel from the tank, and try to swirl around the fuel to get the last bit out and any dirt that might be in the tank. Compressed air can be used to blow the tank out or flush the tank with some more fresh fuel. This is important to help your new fuel filter last longer and also the reason why the filter would need replacing. Using a length of wire, coat hanger or smaller, make a small hook on the end, small enough to get into the fuel tank, big enough to fit around the fuel line. Place the hook in the fuel tank and fish out the fuel line and the gently remove the filter from the tank, its on the end of the fuel line. Pull the old filter off and push the new filter on, Place back in the tank, Fit the fuel cap chain and fuel cap. Job done. Hope this helps
Oct 04, 2013 | Echo Chain Saw Service Repair Manual...
Brand new Echo cs-400 chain saw: The chain spins fast on idle. Should'nt the chain be stationary on idle?
The manual is available here:
http://safemanuals.com/user-guide-instructions-owner-manual/ECHO/CS-400-_E
The idle speed of the negine may be too high.
Page 26 of the manual gives instructions for adjusting the speed with the "T" screw on the carburettor.
May 12, 2011 | Echo CS400 18" Chain Saw
Broken bolt that holds chain bar in place
As you know, your chain saw is obsolete, However, go to this website and they will have what you need:
http://www.cmsmallengines.net/echo-kioritz-c35.html
Good luck.
Jan 13, 2009 | NRS Oregon Bar And Chain Set For Echo...
Garden Logo
101 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
