Question about Pool & Spa
Spa will not heat above 96 degrees - Pool & Spa
  • 246 Answers
SOURCE: Spa will not heat more than 85 degrees or so
on the back of the board is the bottom for seting the max temp follow the intruction from the manual or get one at jandy.com
Posted on Sep 01, 2009
rsmith972278
  • 160 Answers
SOURCE: my spa heater is saying the spa is 126 degrees so
Use a thermometer to check the actual temp of the water to see if the units temp probe is accurate. Also what is the max temp allowed by the spas safety program...owners manual.
Thanks,
RSMITH972278
Posted on Oct 12, 2009
  • 990 Answers
SOURCE: Spa Heater
You need to check your temp sensor and your high limit. Both are tubes that slide into the plumbing on or near your heater. If this is a tube heater then they are probally at on each end of the heater and will have small wires coming from them that go back to the control board. Farely common problem and easy enough to fix with replaceing them both. A number of models wire them together so they come as one part. Good luck.
Posted on Jan 20, 2010
  • 366 Answers
SOURCE: my spa has stopped heating above 67 degrees. Can
it's most likely a temperature sensor, what is the readout on the top side control?
Posted on Feb 03, 2010
Daniel S
  • 4323 Answers
SOURCE: The spa heater says the
Hi
1. Turn off the power to both the pool/spa control system and the heater unit.
2. Remove the front panel door from the front of the heater to access the raceway.
3. Run the wires from the pool/spa control system through the opening, Thermostat is located on the lower right or left hand side of the heater.
Please check this link for more details---
Jandy LXI 300 POOL HEATER Manual
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Aug 21, 2010
My intex spa shows error 96 and 143 degrees F. water is cold
well first the manual should say what a error 96 is but i'll save you the trouble , the control is saying heater failure as the water should never be 143 degrees this would burn/kill you if you got in , id look at temperature probe 1st (its in pipe right past the heater ) and next id look at control itself , sometimes water intrusion dammage in controller makes for some "funny" and wrong things to happen
Oct 12, 2014 | Intex Pool & Spa
I have an intex spa and is heated to 96 and it's warm but not hot. What can I do ?
First thing to check would be the filter to make it is clean however if the tub is not getting to 104 degrees as it should you probably have a thermostat problem.
Rod
US Parts Center
May 04, 2014 | Pool & Spa
Jandy LJ Pool Heater
temp sensor might be going bad but you can go into menu and calibrate up to 4 degrees each way
Mar 24, 2014 | Jandy Laars Lite2 Lj 250,000 Btu Heater
Spa keeps overheating
Faulty temperature sensor should do this to.
A floating thermometer should read water temperature within 3-4 degrees of spa controller. If it is greater than that your sensor is bad.
The hi limit is an over heat sensor it does not control the temperature of the water. If the water is heating above 118 degrees and the spa is not shutting down its Hi Limit.
Jan 15, 2012 | Dream Maker Spas Pool & Spa
When you switch the 155xl heat pump on the digital thermometer goes up to 96 degrees and shuts down but the incoming water is 79 degrees.
It sounds like you have a by-pass valve that is open. It should be closed down. You will find this on the pipes in and out of the heat pump. The valve will be between these pipes. When you close it you will force water through the heat pump so it can warm then go back to the pool. Now your water is getting warm then just sitting in the heater. When you close the valve you start the water flowing and their by heating.
Dec 11, 2010 | Aquacal HEAT WAVE H155 132,000 BTU -
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
I just installed my new X400 Dreamaker Spa. I filled it with water (although cold) and it has been warming up for approx. 18 hours and is only at 80 degrees? Is this normal? How long should it take to...
This is normal with the dream maker spa. The dream maker spas are poorly insulated, and only run 120 volts with a very small heater.
When the unit is first filled, the hot tub will not heat full time either. Most new hot tubs will have freeze protection below 50 degrees F. They will recirculate automatically using the friction and the pumps heat to warm the water above 50 degrees, and then the heating unit will kick on. These hot tubs do not heat while the jets are on high either, so once you are in it using the jets on high, the temperature will start to fall.
Now that you are up to 80 degrees, it should heat up fairly quick however.
Nov 19, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
My spa has stopped heating above 67 degrees. Can
Feb 03, 2010 | RTO Sundance Heater Element Harness Black...
Spa / hot tub does not heat
Your temperature control is way out of calibration or, it's wired wrong. Remove it and check it in a glass of water. Use an ohm meter across the heater wires. As you add hot wwater, the heater contacts should open.
Aug 11, 2009 | Jacuzzi Home
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
