Question about Maxi Aids Round Metal 4 Alarm English Talking Watch
How to turn Round Metal 4 Alarm English Talking Watch on
How do I use the buttons in this QHY watch?
Hopefully, this will help...
Lego Watches Manual Instruction:
There are 4 buttons on this lego watch case, Light button, Mode button, Stop button and Reset button, now I will show how to set the time easily!
1, Light Button: Press this button, the watch LCD light will display for 3-5 seconds;
2, How to use the stopwatches chronograph function?
Answer: When the lego watches in normal working condition, Press "Stop button" for 1 time, then the watch goes into the chronograph mode, then you can use "Stop button" and "Reset button" to operate this function.
3, How to set the alarm time?
Answer: When the lego watches in normal working condition, Press "Stop button" for 2 times, then the watch goes into the alarm mode, then you can use "Stop button" and "Reset button" to set the alarm time, also you can turn off or turn on the alarm function and chime on every hour function by the same operate.
4, How to set the right watch time, hour, minute, second, week, date, month, year?
Answer: When the lego watches in normal working condition, Press "Stop button" for 3 times, then the watch goes into the time setting mode, then you can use "Stop button" and "Reset button" to set the second, minute, hour, week, date, month and year.
This is all. So now please have a try to set your lego watches time!
Dec 06, 2014 | Watches
When we set the alarm on the watch we cannot get the clock back to tell the proper time it stays on the time of the alarm and so we are unable to see the proper time
After the alarm has been set, press button B (lower right) to turn the alarm ON or OFF and the press the crown back to the normal running position (i.e. next to the case).
When you do this, the time should reset itself to your local time.
If you haven't got instructions, go to http://www.citizenwatch.com/Technical/English/Abbreviated/E870_condensed.pdf to view the full set of instructions.
Dec 27, 2010 | Citizen Eco-Drive Calibre 8700 Wrist Watch
How do I change the time on my Citizen Alarm Chronograph WR 50 watch?
First we need to determine what movement is in the watch.
Look on the back of the watch. You will see some numbers there will be a 4 digit number followed by a dash and 6 or 7 digit number.
The 4 digit number is the movement number. example e760 or b210. Ctizen has hundreds of them.
Next click on this link:
http://www.citizenwatch.com/COA/English/settings.asp
enter the movement number and click on get setting instructions.
Nov 07, 2010 | Citizen Watches
I got a talking watch but no instructions. Super Storm Talking Alarm Watch. Please help
For Super Storm watch:
Click Mode (upper left) button until either current time blinks (1st click) or current alarm time blinks (2nd click).
Immediately (before the blinking stops, approx 3 seconds), click hours (lower left) and minutes (lower right) to set time. When you pause the clicking, time or alarm will be set.
Sep 01, 2010 | Watches
How do I turn off the alarm on my Armitron watch?
I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
Nik.
http://home.earthlink.net/~eldonenew/armitron.htm
or
http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
Other People Are Reading
Setting Date, Time and Alarm
  • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
Using Chime and Alarm
  • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
Backlight
  • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
Read more : http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Jul 20, 2010 | Armitron Round Digital Sport 408089 Watch
On time atomic watch wrong time zone EXSV10+Talking+Watch I DON'T HAVE+instructions+owner+manual I need to set correct time?
The EXSV10 Atomic Talking Watch by On-Time sets itself to the official time standard of the United States government, maintaining split second accuracy. It can also literally "tell" you the time. It talks! The On-Time talking atomic watch also has daily alarm capability, and can be set to announce the time every hour.
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Feb 24, 2010 | Watches
Xinjia xj-686 watch can't turn alarm off
I have the same problem with the xinjia-686. These instructions posted for another digital sports watch worked for me.
noavatar_s.gif davidtolond
Rank: Guru citizen.gif jewelry_watches_small.png Expert
Rating: 85%, 400 votes
I have the AW21312W, which has 4 buttons:
  1. Light (Top left)
  2. Mode (Bottom Left)
  3. Start/Stop (Top Right)
  4. Lap/Reset (Bottom right)
To turn the set alarm off, push buttons 3 and 4 at the same time, the alarm icon should appear or disappear
To turn off the hourly chime, press button 4. While holding it down, press button 2 and the days of the week disappear. The chime is now off. If you want the chime, press button 4 and hold while you press button 2. When all the days show, the chime is on.
Feb 19, 2010 | Watches
Turn off alarm and how to set alarm
After a bit of searching I found a makers name for you. I trust that this is the make you have (I doubt if there is more than one!)
If you go to "www.accessible-devices.com/reizen.html", this is an instruction sheet for Reizen talking watches.
Jan 20, 2010 | Watches
CYBEAT W.R.3BAR WATCH MANUAL
i have a cybeat watch,the manual is in japenese i need it in english
Dec 29, 2009 | Watches
Citizen chronograph watch No EW8xxx/cal.noB023
go to this link for owners manual. Pay special attention on how to find your watches movement number.
Oct 26, 2007 | Pulsar 100 Meter Alarm Chronograph PF3277
Maxi Aids Round Metal 4 Alarm English Talking Watch Logo
18 people viewed this question
Top Maxi Aids Watches Experts
Jimmy Accardi
Are you a Maxi Aids Watch Expert? Answer questions, earn points and help others
