Lost alarm remote now 2002 accord wont start
Speak nicely to honda dealer and see if the remote fob was recorded whenthe car was new.
The dealer may have software to get the info from your car, or, possibly phone an Auto locksmith ... they should be able to supply you with a new fob (prob who the dealer use anyway).
Do not try to by pass the immobiliser system....its doing its job!
Cheers
Roger
SOURCE: 1995 Infiniti j30s alarm wont let car start
You may need to order a key remote from the manufacturer.
SOURCE: Car alarm stopped working.. Car wont start
the jetta has a faulty alarm system from the factory i have been working on one in my shop. the alarm moddule is inside the dash behind the light switch and has a 10 pin connector and a 6 pin connector. this can be bypassed if you disconnect both connectors and jump the two large wire on the 6 pin connectors, these wires operate your starter. the car will start and run but your alarm will no longer be active. the door locks and everthing else will still work. the only issue i am having is the factory radio isn't working because it is controlled by the alarm. but worse case scenario i can use an aftermarket radio if need be.
SOURCE: lost alarm remote and jeep wont start
Is this a factory alarm, or after market? If its a factory alarm you can disarm the sytem using the key, insert into the door and turn the key so the door unlocks, this will disable the alarm.
If it's an aftermarket installed by a stereo shop, there should be a valet switch under the dash or somewhere, put the key in the ignition, turn forward and flip the dip switch in the other direction. If not, then you will need to go under the dash, find the alarm box and pull the plug out.
SOURCE: lost keyless entry remote
turn door lock left twice to un do alarm ,on old cars it may or may not work due to old age
SOURCE: my 1995 Dodge Intrepid alarm wont go off and my
there is no way to disable it other than to take it to the dealership and have them program a new remote
