Question about JBL On Beat Air iPad/iPod/iPhone Speaker Dock with AirPlay Black
Jbl onbeat air - JBL On Beat Air iPad/iPod/iPhone Speaker Dock with AirPlay Black
I would like a full manual for the JBL xtreme speaker?
JBL Xtreme ' Splashproof Bluetooth Speaker with ... - JBL.com
www.jbl.com > Wireless > Portable Bluetooth Speakers
JBL
Rating: 4.7 - ‎35 reviews
Splashproof JBL Xtreme Bluetooth speaker with explosive sound, 15 hours playtime, dual USB port can link multiple speakers and ... Product Specs & Manuals.
JBL Xtreme ' Splashproof Bluetooth Speaker with Powerful ...
uk.jbl.com > Wireless > Portables
JBL
Rating: 4.8 - ‎36 reviews
Splashproof JBL Xtreme Bluetooth speaker with explosive sound, 15 hours ... http://uk.jbl.com/bluetooth-portables/XTREME.html? ... Product Specs & Manuals.
Jan 05, 2016 | JBL Audio Players & Recorders
How to open up the JBL onbeat rumble?
The power connection on my JBL Onbeat Rumble stopped working also. I could usually jiggle it to get it going but this wasn't a reliable solution. I note there were a few people online that have complained about this but no solutions or disassembly guides. With nothing to lose I set about pulling the unit apart to fix it... here's hoping it will help others:
1. Under the orange base rubber there are five screws. You need to carefully peel off the rubber to get to the screws. Also under the sticker on the input/output section there are two screws to undo.
2. See photo for positioning of rear clips. You might be able to use an appropriate tool to undo them. I used brute force to open the case and the rear clips didn't break.
3. There are two more clips and two screws at the front of the unit.
I don't know how to get to the screws - possibly you need to unclip the front of the unit and grille. I just used additional brute force which undid the clips and snapped the screw mounts. The unit was then completely opened up into two halves.
4. You can now get to the input/output section. There are four screws to undo before you can lift it out. In my case I could see a cracked solder joint on the power input so I re-soldered it as best I could and confirmed the unit was now being powered up reliably.
5. To reassemble, reseat the input/output board, clip the unit back together, re-insert the 5 base screws + 2 input/output screws, then glue the rubber back on (it might be sticky enough not to need additional glue). The snapped screw mounts don't seem to matter as the remaining clips are strong. Just shake out any plastic pieces to avoid rattles.
Jun 13, 2015 | JBL OnBeat Rumble Wireless Speaker Dock...
My JBL Onbeat Extreme has blown a speaker - I want to repair it but cant work out how to open it... there must be clips or screws somewhere
First you have to remove all of the bottom rubber feet, don't worry they are glued to the bottom, then with a sharp knife, remove the plasticdecal where the USB, AC and video plugs are. Pry it off from one corner then work your way all around, there you will find three more screws that will release the board. Good Luck!!!
Dec 20, 2014 | JBL OnBeat Xtreme Speaker
Jbl instructions
Took about 3 seconds on Google, including typing in the product name. These things are not difficult. You should try it. JBL OnBeat MINI Black JBL
Aug 15, 2014 | Harman JBL OnBeat Mini
How to reset JBL On Beat Airwifi name changed as "NONE" instead of "JBL On Beat Air"
To resolve the problem, I used my Iphone instead of my Computer to connect to the network.
On the Iphone the network "None" was not show so I've manually connected to this SSID with no password.
On the Iphone I then go to 169.254.1.1 to relink to my home WIFI :)
Hope this will help :)
May 15, 2013 | JBL On Beat Air iPad/iPod/iPhone Speaker...
When I turned my JBL Air Wireless on for the first time I have only blank screen
This is a lousy piece of equipment but i found that if you press the szooze button and power on button and then give the power supply then the system boots on and it works well
Dec 25, 2012 | JBL On Air Wireless jblonairwblkam
My new JBL onbeat xTreme when connected to my MacBook by Bluetooth and playing streaming from Spotify, keeps goimg into stand-by every ten minutes. It seems that it doesn't recognise that it is c
Same here. Streaming from Spotify from iPhone5..... every 10 minutes enters sleep mode. WTF? No idea how to get around it. Only FW upgrade I guess, if there any...
Dec 06, 2012 | JBL OnBeat Xtreme Speaker
How to connect aftermarket radio into 2002 toyota camry JBL radio (the standart wiring doesn't work).Thanks
Your aftermarket radio should have color-coded wires which identifies power, ground, speakers, etc. most depaetment stores carry a radio harness adapter kit. This will connect to your radio's exact color coded wires, and will plug right in to your factory's wiring plug. And don't forget electrical tape.
Aug 28, 2011 | 2006 Toyota Camry
The fuse keeps burning out in my jbl sub 10, even if i disconnect the input LFE.
poor design, the amps that are screwed to the heat sink are below a transistor which is catching all the heat,heat rises and changes the bias of the transistor so high it causes runway in circuits that results into failure also the amplifiers are sealed with no air flow, this can't be good.Maybe if they put air vents or remove the cover to panel then the heat will have somewhere to go instead of just building up inside.If this problem is not fixed a replacement is going to fail too.good price bad design.
Oct 08, 2009 | JBL Venue SUB10 Subwoofer
JBL On Beat Air iPad/iPod/iPhone Speaker Dock with AirPlay Black Logo
Top JBL Televison & Video Experts
Mike
mega_mind
Are you a JBL Televison and Video Expert? Answer questions, earn points and help others
