Question about Miallegro 6007 Miarepa Arepa Maker
Where do I buy the timer knob for Miallegro 6007 MiArepa Maker?
My timer knob was broken. Where can I find a replacement?
Where can I get the Pica Tutto blade, Blender blade, aerator blade, puree blade for the Miallegro Mi Tutto 9080
Miallegro don't appear to offer spares for their own products. If you buy a new one for $70, you will have spares of what you have already. http://www.foodprocessorsstore.com/product/miallegro-9080-mitutto-450-watt-immersion-hand-blender-stainless-steel-with-whisk-and-chopper-attachment-5-speed-turbo
Or you could ditch the brand and buy Braun or Kitchen Aid
http://www.foodprocessorsstore.com/product/braun-mr320-multiquick-3-hand-blender-450-watt-220-volt-not-for-american-voltage
http://www.kitchenaid.ca/en_CA/shop/countertop-appliances-1/countertop-appliances-2/hand-blenders-3/-[KHB2351OB]-2100856/KHB2351OB/
Our Location Address:
Idea Team Work,LLC
8725 NW 18 Terr
Suite 404
Doral FL, 33172
Telephone:
1-888-Miallegro (642-5534)
Mar 08, 2016 | Miallegro 9080 Mitutto 450-Watt Immersion...
Need control knob timer dryer doesn't shut off
If you are stating that the timer knob never moves to the off position, then the timer is probably bad and needs replaced. If you can't turn the timer because the knob feels too loose then possibly the knob is just broken. Timer knobs usually just pull straight off so you can look at the back side and see if the plastic around the shaft hole is cracked.
May 11, 2015 | Whirlpool Dryers
On/off swith knob broken
Is it the actual knob that is broken or the little tab the knob holds onto that is broken. You either need a replacement knob or a replacement switch assuming the know is also the thermostat for the unit. Does that same knob control the fan speed? Temprature or timer?
Mar 31, 2014 | Pelonis Heating & Cooling
My timer knob is broken. How can I order only that part?
I would advise you to call Kitchenaid Customer Service. They would be able to send you a replacement timer knob at no cost. You may simply pull off the broken timer knob, and the new knob will snap in with ease.
Their toll free telephone number is 1800-541-6390.
Jun 16, 2009 | KitchenAid KCO1005OB 1400 Watts Toaster...
The timer knob spins freely and I can't start the machine or set the timer.
"Can I replace it with a new knob or do I have to buy a new timer?"
It sounds like the knob is rounded out where it fits on the timer post, or It may just be loose. Pull the knob off and inspect it. If damaged, yes, you can buy another one.
May 04, 2009 | GE WDSR2080D Top Load Washer
Need to change timer
Timers are pretty much non-servicable. If the knob is broken, you have to replace the timer.
Nov 10, 2008 | Washing Machines
Kenmore 70 series. knob -timer-button
The knob is a simple screw on knob and the replacement part number is 3353309. Cost is 16.50. It will have a metal back as opposed to the plastic one you must have now. Shipping would Should you choose to order, follow this link:
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Nov 02, 2008 | Kenmore 22422 Top Load Washer
Ge timer on washer is broken
If it no longer clicks, the timer assembly will need to be replaced. If just the knob broke off, the timer should be good.
Mar 16, 2008 | GE WDSR2080D Top Load Washer
The timer knob broke - can't find replacement
Assuming it has broken on the shaft then you could pry the broken bit off the shaft and take the knob and broken piece to your domestic appliance parts stockist. The shafts are usually a standard size and there might be a similar knob that you could replace it with.
Oct 02, 2007 | Solis Maestro Electric Burr Grinder
Miallegro 6007 Miarepa Arepa Maker Logo
37 people viewed this question
Top Miallegro Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Miallegro Kitchen Appliances - Other Expert? Answer questions, earn points and help others
