Question about Boating
Turn the switch off motor keeps running
I have a 1995 40 hp force outboard motor.It will crank fine but when you turn the key off the motor keeps running.I replaced the ignition switch and verified the wiring diagram of the switch paying close attention to the ground wire and the kill wire.Everything seems to be good.I also took the kill wire that comes from the outboard and shorted it straight to ground,it chokes the motor out,but does not quickly turn it off like it should.Can some one please give advice.
  • 5,687 Answers
It sounds like there is a short in the alternator or wiring for alternator. You are continuing running with the battery cut off. But the outboard generates its own power and its finding the way to the ignition. As for grounding, you may be idling too high for a quick shut off.
Posted on Jun 18, 2009
Hi have a 1984 evinrude 35 hp model no E35RLCRR that wont start
There should be two hot wires one from the battery and one from the switch the one from the switch check should be hot when the key is held on the start if it is the starter solenoid is bad
Dec 23, 2014 | Clymer EvinrudeJohnson Outboard Shop...
Tip
Outboard motors
Keep the gas in your outboard new/clean with new oil every 6 months..Keep your motor covered when not in use, Dirt dabbers (dobbers) will build nest under the hood and break loose and ruin your motor, ,,Change your water pump and thermostate every year when motor is used a lot.....Dont run stainless steel props on small hp motors ,when you hit a log it will bend your prop shaft costing big $$$ to replace..Ck your lower gear oil if water is noted ,replace lower seals...Dont buy used motors unless you run a compression ck....ck for water in gear case , Dont buy 4 strokes to heavy to slow to many parts AND are being replaced by fuel injection 2 strokes .... Dont buy FORCE motors not made by mercury no parts being made and or extink and pure junk . Etex best motors , .
on Mar 16, 2011 | Boating
What pins on the ignition switch are energized when when you turn the key on a 2003 mercury 15 hp 4 stroke outboard?
Red is Battery +
Red/purple is ignition
Yellow/red is startermotor
Black/yellow is motor kill
Black is ground
To have ignition, black/yellow wire must be disconnected
On is red/purple on bat+
To start Yellow/red on batt+
To kill: black/yellow on ground
Jul 29, 2017 | Boating
60 hp outboard motor doesn't turn over when I turn key on
usually any motor has to be in neutral to crank.
Sep 25, 2014 | Boating
115 hp johnson great difficulty to cold start,sometimes it even run the baterry flat but once it started there is no problem in starting again what could the reason for this be or do i just start the...
Hello vcd9,
When You Turn The Key On ,Press It In To Activate The Choke Solenoid And Then Crank At The Same Time,This Should Solve Your Problem, If All Is Fine With The Engine.
Cheers
Gordon
Feb 11, 2013 | Light Outboard Motor Boat Bass Fishing...
I have a 1990 90 HP mercury outboard. It is rough idling and surg
I have a 90 hp force ob. when i run it with the ears she runs fine lets me bring the throttle all the way up. when i but it in the water thru the wake area i can do 4 mph once i'am out of the wake area and give it the gas she dies, any ideas
Apr 20, 2010 | Raymarine Linear Feedback Unit For...
Yamaha 115 will not shut off with key or kill switch
not enough information on the motor. what year and model? but all yamaha outboards are shut down by the C.D.I. being grounded by the key switch or the emergency kill switch. the cheapest thing to test or replace is the key switch and the emergency kill. with more info on engine I can help you further.
Sep 23, 2009 | Light Outboard Motor Boat Bass Fishing...
1993 40 HP 4 cyl. Mercury outboard: Running along
I solved it with no help from the professional assistant team. Thanks for no help till I send money...DON'T THINK SO!!! Thanks for wasting my time.
Sep 03, 2009 | Boating
I have a 50 hp 1975 Johnson outboard. When I turn
There is a switch in the control box that locks out the start unless you are in neutral. Open the box and put in a new switch,this is a safty device to keep it from starting in forward and throwing you out of the boat. Jim OMC retired Mech
Jul 07, 2009 | Boating
Boating Logo
910 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
