Question about John Deere Gator Cx Sun Canopy Kit
Gator cx vapor lock - John Deere Gator Cx Sun Canopy Kit
Holden captiva rear door handle broken with child lock on..?
If door is in jammed state, open door by
repeatedly pressing the unlock button, while jiggle the inner or outer door handle this will help free up the
internal gears in the actuator that are jammed.
once the door is open.
Replace the door lock actuator with a revised
part;
Part No.: Description Qty:
96872800 LOCK,LHF DOOR (SX, CX, LX) 1
96872801 LOCK,RHF DOOR (SX, CX, LX) 1
96872811 LOCK,LHR DOOR (SX, CX, LX) 1
96872812 LOCK,RHR DOOR (SX, CX, LX) 1
96872803 LOCK,LHF DOOR (MAXX) 1
96872804 LOCK,RHF DOOR (MAXX) 1
96872813 LOCK,LHR DOOR (MAXX) 1
96872814 LOCK,RHR DOOR (MAXX) 1
Vehicle Torque Spec for door lock actuator
Captiva SX,CX, LX 10 Nm
Captiva MaXX 8 Nm
Apr 13, 2016 | Holden Cars & Trucks
Having trouble with vapor locking
Vapor lock can be caused by many different things, all coming down to the same root cause: too much heat in the fuel feed lines.
Low fuel pressure can cause the amount of heat needed to vapor lock to be lower than normal, so checking fuel pressure is important. Fuel pump going out feels a lot like vapor lock.
Engine overheat can also cause vapor lock. Clogged fuel filter can cause vapor lock. The fuel line should be routed away from the exhaust system.
Feb 29, 2016 | Cars & Trucks
John Deere Gator
check your gas tank screw on cap......if there is a breather hose coming out of the cap....make sure the hose is not kinked thus causing a vapor lock in the tank
Jul 07, 2014 | John Deere ATVs
What causes 1995 isuzu vapor lock problems?
Fuel injected engines cannot get vapor lock. First you need to explain how you came to the conclusion if vapor lock. But this is an old post and probably will stay dead.
May 20, 2014 | 1995 Isuzu Pickup
Have john deere gator cx it won't start, I have
My older cx won't even turn over.. Totally dead..
lights work so ignition system ok..
battery is new and hot..
fuses all ok..
Stated and ran fine through two pastures.. Turned off to fix fence..
now not a peep..
Aug 18, 2013 | John Deere 420,1020,2010,2020,2510,2520...
The battery is not being charged on my John Deere Gator 4X2 model CX. I need a wiring diagram. Thanks
I am sorry but we have no wiring diagrams here at fixya. They are copyrighted material by the manufacturer.
Aug 28, 2012 | Cars & Trucks
My gator works in reverse and low gear but locks up in high gear what is my problem
do you hear a click when it "locks up" if so you might have a bad motor or thermal fuse
Sep 20, 2011 | Peg Perego John Deere Gator HPX Ride on...
John Deere Gator Cx Sun Canopy Kit Logo
Top John Toys Experts
Vernon Taylor
Adam Fjeld
Adam Fjeld
Are you a John Toy Expert? Answer questions, earn points and help others
