Question about Brasscraft 1/4 in. x 25 ft. Power Pistol-Grip Drum Auger BC86250
How do you install a cable in the drum auger with drill
Ice maker does not dispense ice through the door
Hello. I had the same problem. I replaced the auger motor(around$95) 3 times and would only last about a little longer than a year. I bought the 4th one but this time, I wanted to diagnose the issue. So it turns out that the auger motor goes installed with the impeller upwards. What was happening was that if a piece of ice would stay in the dispenser chamber and melt, the water would go into the auger motor eventually causing the auger casing to get full of water and slow it down or short it out. I took the casing apart and noticed that there was a small space between the motor and the casing. I drilled 2 nice sized holes in the dimple of the new motor very gently as to not drill into the impeller motor and installed the auger. To this day, 3 years later, no more having to buy new auger motors. Hope this helps!
Mar 10, 2015 | Refrigerators
Where to buy a drum connecting cable for a drum drain machine
I guess you're talking about the cable that first connects to the drum and then to the auger's main cable. You really don't need the connecting cable. Just connect the main auger's cable to the drum and you might lose 12" of cable. If you still want a connecting cable, then buy the Weld On Cable Ends on Ebay and a cable. If you have a Drain Cleaner dealer near you, they will have cables and probably a 3 foot piece you can use as your connecting cable.
Oct 07, 2014 | Plumbing
How to assemble
Without a model number, I'm going to guess that you have the standard model that ISN'T drill driven it has an actual motor. There aren't many parts and it should've come in one piece from Home Depot of where ever you purchased it. The three main pieces are the drum, cable, motor and frame. To remove/install the drum, pull out the lever on the back lower part of the frame and pull the drum off the shaft. The motor is held on by four bolts that attach it to the motor mount. If you need to install a cable on this machine, push the cable in through the cable guide and attach it to the mount on the inside of the drum. As you face the drum the cable will wind counter clockwise.
Apr 11, 2014 | Brasscraft 1/2 in. x 50 ft. Drain Auger...
Put snake back in
I'm guessing all the cable is out of your manual auger and you can't get it to go back inside the drum. It's very easy, all you need to do is a small kink in the end of the wire about two inches from the end of the cable and push the cable in. The bend in the cable will start it turning inside the drum, then just push the cable inside the drum.
Mar 09, 2014 | Cobra 1/4-in x 25-ft Music Wire Drain...
Left auger does not engage/spins freely
The shear pin is sheared off. Somewhere along the auger, you'll find a hole drilled all the way through it. The shaft inside also has a hole drilled all the way through it. Compare the two augers - the holes are USUALLY in a straight line with each other (when one is up/down, the other is also up/down).
Get a replacement shear pin (DO NOT use a hardened bolt!) and put it through the holes when the auger holes are lined up with the axle holes.
Feb 19, 2014 | Toro Power Max 724 OE 24 inch 205cc Two...
What are some common uses for augers?
Well, some common uses you may be familiar with are drilling through ice for ice fishing and drilling into maple trees to take out the maple syrup.
Jan 31, 2013 | Drills
What is an auger anyway?
An auger is a drilling device that has a helical blade that moves the material being drilled out of the way as it drills.
Not sure how to reroute auger cable on craftsman snowblower
I assume the cable to the auger was removed and needs to be re-installed.
There should be a clamp that the cable ran thru, then attaches to the auger
control. Find this clamp on your snowblower, and route it thru this clamp
then attach it to your auger control.
Feb 25, 2011 | Garden
The ice wheel not turning
If your model is the JSD2789GES let me know as I have the service manual 118 pages...Sea Breeze
Jun 21, 2009 | Jenn-Air JSD2789GES Side by Side...
Brasscraft 1/4 in. x 25 ft. Power Pistol-Grip Drum Auger BC86250 Logo
Top Brasscraft Sport & Outdoor - Others Experts
Are you a Brasscraft Sport and Outdoor - Other Expert? Answer questions, earn points and help others
