Question about Yamaha 2005 RS Venture
Oil tank breather hose dumps oil in air box
Oil tank breather hose is spraying oil into the air intake of the 973cc engine
    Problem Solver:
  • 18 Answers
Make sure your oil level is just below the full mark not above it.
Posted on Oct 11, 2014
95 sl500 fuel tank holds a lot of pressure,idles rough when stopped at idle speed Where is the fuel tank breather hose?
There is no breather hose for the fuel tank, the system is designed as a sealed system to prevent gas fumes from polluting the air it is called the "Evaporative emissions control system", and yes some systems can have alot of pressure in the tank esp on hot days or after a long drive.
Nov 03, 2016 | Cars & Trucks
How do the crankcases gasses get into the intake air chamber of my 2002 volvo xc70 and does this or can this make the ngine rough
It's possible that you may have either a clogged breather box or broken breather box hose. The breather box is located under the intake manifold. It is sometimes also called an oil trap.
May 04, 2014 | 2004 Volvo XC70
Oil from oil tank breather dumps oil in air cleaner
common problems that can cause this is to much oil. engine veins blocked or the rings on the piston are gone and the back pressure from ignition creates an overflow of air into the system.
Aug 08, 2017 | Yamaha 2006 RS Venture
I have a 93 Mercury Tracer with a Ford 1.9L engine. About 2 months ago it started idling high and low when I am parked or at a stop light. After checking my air filter, I noticed that it was sucking oil...
put a can of seafoam in your fuel tank at your next fill up after doing the following
replace your pcv valve
replace all the loose, worn, broken, or missing vacuum hoses one the entire engine
clean the air breather tubes, the whole air cleaner, and if necessary the air filter
that should do it for you
Apr 08, 2017 | 1993 Mercury Tracer
1996 Honda VT 1100 C2 Shadow Sabre oil in the air filter box
Hi, Wayne and the usual suspects are:
1. Oil tank/system overfilled.
2. Faulty breather valve.
3. Engine breather hose bent, pinched, kinked etc.
4. Air filter has too much "pre-oil".
5. Crankshaft seal failure allowing transmission fluid to migrate.
6. Blow by drain tube cracked/split or filled to capacity.
For more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Oil in the air box
Honda Shadow Spirit air filter sub air cleaner crankcase breather
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
May 29, 2012 | 1996 Honda VT 1100 C2 Shadow Sabre
Why is oil going in the hose connecting to the air intake box.
Hello and welcome to FixYa!
That will be the engine breather hose. There should be no oil in the hose, if there's oil then it surely is an engine issue. The piston rings surely is bout to go so be ready for replacement soon to resolve the issue.
Hope this helps and thank you for using FixYa! Have a good one!
Jul 10, 2011 | 1997 Dodge Caravan
My 04 crf 450 is leaking oil out of the air box breather
Hi, Jmattison21 and the usual suspects are:
Engine Oil leaking out of my CRF 450 air Box
Oil coming out of airbox 2012 CRF 450
Honda CRF450X 2005 Service Manual
OEM parts for Yamaha
Honda CRF450R Owner Manual
Dec 22, 2010 | 2004 Honda CRF 450 R
Oil in the air filter ,RANGER 500 2X4/4X4
Has the oil been changed lately? A lot of times over filling the oil will cause oil to blow back thru the carburetor, Also if the air filter got caked with mud running the box with no lid or allot of dirt in the filter. The engine will try to use the crankcase breather hose as an air intake since not enough air was coming in the conventional way, therefore sucking in oil. Has it smoked at all? Sometimes if you try to shut it off oil will run back down the intake tubes into the air box. This may be applicable to your engine that the breather is being used to **** oil into the box due to lack of fresh air intake.
The other possibilities would be crank case pressure pushing the oil in (piston ring blow by), but that should (theoretically) result in low compression (since the cylinder pressure is getting to the crankcase instead of staying in the cylinder), the oil is overfull and being pushed out since air will compress but liquid will not, or poor crank case ventilation system design (but if that were the case likely there would be a recall as that would directly effect emissions which is federally regulated).
Oct 07, 2010 | Polaris ATV
2001 VW POLO 1.4 16v AHW, breather hose problem
if heave oil deposits are coming trough the breather then you may have other problems, such as worn piston rings causing exsessive blow by resulting in the oil being in the intake box, a filter will only create a restriction coursing more poblems, do a compresion and cylinder leak down test to find out how well the rings are sealing.
Oct 20, 2009 | 2001 Volkswagen GTI
When the mower is started it runs very smoothly. The blow by from engine comes through the valve on side through floor of Carburator housing fouling air cleaner. when air cleaner off oil is sprayed on...
REPLACE THE CRANKCASE BREATHER ON THE SIDE OF THE BLOCK. IT IS A SMALL RECTANGULAR SHAPED BOX AT THE END OF THE HOSE THAT IS ATTACHED TO THE AIR CLEANER HOUSING WHERE THE OIL IS SPRAYING IN
Sep 29, 2009 | Garden
Yamaha 2005 RS Venture Logo
375 people viewed this question
Top Yamaha Winter Sports Experts
Arnie Burke
Arnie Burke
bazzz7071
bazzz7071
Are you a Yamaha Winter Sport Expert? Answer questions, earn points and help others
