Question about Canon Powershot SD450 / IXUS 55 Digital Camera
Camera is in shock
Lance is not going in when I off the camera
when I try to on just makes a sound and dos not show any thing on screen.
can't see previous pictures either
I need to know how serious is this problem?
  • 3 Answers
Re: Camera is in shock
Try wiping the battery terminals on the camera and the battery.
Use an electrical contact cleaner that you buy at an auto parts store. Soak a q-tip and go at it. You may be surprised. I was.Just a caution. Make sure the contact cleaner will not melt the plastic on your camera or the battery. Test it by wiping a q-tip dampened with the cleaner on a portion of the battery cavity. If the qtip comes back gray, use the cleaner sparingly and touch only the battery contact areas.
Posted on Jan 17, 2008
0 characters
3 Points
My Panasonic DMC-TZ3 has a black screen can't get it to view. Does anyone have any ideas why?
If you able to click the pic but all thing shows only black black nothing to see,,,all functions are working just not seen anything, then you have a problem in your lance , there is lance flex in your lance may be damaged so you must be replace it and you got your camera as before, if you are technician then first buy lance flex of your camera and replace it, if not then send it to any authorised repairer, its not a big problem its routing problem of cameras,
Nov 12, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
I have a Kodak easy share camera. It is only a few years old and now my view screen only shows dark images rolling across the screen. I cannot view or take any picures.
this is a lance flap problem you just try to clean lance properly and change the flap.
if you are technition then try it at home otherwise contact authorised person,
Aug 31, 2009 | Kodak EasyShare M853 Digital Camera
Lens problem?
its a lance flap problem, so please replace the flap and find magic.
if you are a technition then open the camera and remove the lance assembally and remove the motor too. now open the lance and the flap is in the middle of the lance , pease replac it and keep moving
remember if you are not good technition then dont try it at home its really sensetive oki byeeeeee
Aug 31, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
My camera is showing me all black not the pictures i take
hi,there is 2 solution for that, its problem of lance flap cracked so replace it,or if you can't find that lance flap cracked then replace your camera CCD
Aug 30, 2009 | Digital Cameras
Kodak Easyshare camera model MD1063 wont turn on
hi,your camera needs a servise , its a lance problem just open your camera and remove the lance assembly and servise it properly , otherewise contact authorised person,
Aug 29, 2009 | Digital Blue EasyShare MD1063 Digital...
Vibration of camera
This is a problem with the lens gyro we can keep it from shaking it requires the camera to be taken apart and amodification done to the lens repair cost 65.00 in most cases.
May 14, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Olympus sp510uz no sound on video
From SP510 camera switched off:
1. Turn dial on top plate to movie mode (selections from the menu screen apply to the mode the camera is set in);
2. Switch on SP510 power;
3. Press "MENU" button on back plate;
4. Select "Camera Menu" from screen if not already on it, using navigation buttons on back plate
5. Scroll down yellow "Camera menu" tabs to microphone picture (below "Digital Zoom"), which may be showing "off". Select OK and toggle yellow tab from "off" to "on", then press OK button.
6. Microphone tab should now show "on".
7. Return to main menu (press MENU button).
8. Return to image screen (press MENU button).
9. Test to see if video now records sound.
10. If is still doesn't record sound, try "reset" from video menu screen (this will reset the movie mode to factory settings, including microphone on).
Dec 21, 2008 | Olympus SP-510 UZ Digital Camera
Nikon D70 digital camera memory card cannot be used
First read:
Then read how, with pics:
Careful now....
Dec 09, 2008 | Nikon D70s Digital Camera
White screen
Sounds like the LCD's ribbon cable is not securely attached to its connector. If the camera's no longer under warranty, you'll need to open the camera, remove and then reseat the LCD ribbon cable into its connector. If you decide to attempt repair, remember its ultimately your responsibility, as things can and sometimes do go wrong. Also go no further than the first three pictures in the following disassembly guide.
Follow the LCD ribbon cable to its connector on the circuit board. Look for lift pins or a lift bar on the connector that you lift with your fingernail, or the flat edge of a screwdriver, to release the cable. After you release the cable, inspect the end of the cable to make sure its clean, then reinsert it in the connector, and close the lift pin/bar to secure it. Reassemble the camera, and try it out.
And finally, there is a risk of electrical shock inside all digital cameras with a flash. Recommend reading the following before opening any camera:
Feb 06, 2008 | Canon PowerShot A570 IS Digital Camera
Blue screen and lens error
i think its in the flix of your lense,
coz the flixible wire of your lense and motor are one
try to test it!!
there is something wrong in the FW i think!!
Oct 07, 2007 | Olympus Stylus 700 / 700 Digital Camera
Canon Powershot SD450 / IXUS 55 Digital Camera Logo
Top Canon Digital Cameras Experts
Are you a Canon Digital Camera Expert? Answer questions, earn points and help others
