Question about Genius Computers & Internet
I plug in my tablet to my computer but it isnt reacting
I connect my tablet to my computer through the USB slot. How can I work my Genius Tablet?
SOURCE: RECURRING PROBLEM OF WACOM TABLET GETING STOPPED
Unplug the tablet and then plug it back in. This sorts it for me.
Posted on Jan 12, 2008
SOURCE: serial to usb wacom tablet problem
I just got Vista and it killed my Intuos2 w/serial to usb also, but here's a half solution:
Download Wacom driver 4.78-6 http://www.wacom-europe.com/int/downloads/driver/driver.asp?lang=en. Make sure you remove any other Wacom drivers, tablet, and reboot. Install 4.78-6 driver and select serial port when the choice pops up. Plug in your tablet with the serial to usb adapter, wait a few seconds and click retry. Complete the install and reboot.
Your Wacom tracking should work now, but certain things might not work like pressure sensitivity and you'll get annoying error "reinstall driver" pop-ups.
I think you can aslo buy a PCI-serial card for your computer and skip the serial-usb adapter since Vista doesn't support the adapter for Wacom tablets.. but I'm not sure if there's a working Vista serial Wacom driver either.. or ever will be. The age of XP and Legacy support is at an end my friends.
Posted on Apr 03, 2008
  • 3 Answers
SOURCE: pen doesn't work
ok i had the same problem BUT i opened the mouse pen control panel and under info i unchecked the "support tablet PC feature" and to my amazement it worked. hope it works for you :)
Posted on Jan 24, 2009
SOURCE: Crazy Tablet - Genius 8x6
I have same tablet and the biggest problem is USB cable!!!
USB able is made from bad materials and the plastic/rubbery coating of inner wires of USB cable is very easy to brake, then the wires inside of the cable get connected between them selves and all the problem that you have starts.
I had those problems and all was solved by changeing the USB cable.
Changeing the USB is litle bit problematic becous it is connected to the tablet by microconnector that is wery hard to find (for me it was inpocibile). Becouse I couldn't find the matching microconnector I connected new cable to the one on the old cable welding the wires to the ones on the microconector . AND IT WORKED!!!
You may consider to by new tablet becouse this may seam complicated, but for me it was an interesting thing to do and it payed out. Just watch out to connect all the wires properly!!!!!
I hope this was helpful :)
Sorry for bad english ;)
P.S. If you have any problem while doing this write me here and all try my best to give you answers.
Steve from Serbia!!!!
Posted on Mar 06, 2009
SOURCE: My computer doesn't recognize my tablet.
do not buy a new one... the problem is not a cheap usb cable. open the back part of the tablet and carefully remove the small plastic rings securing the plastic grid that should be inside, on the topmost part of the grid there should be some lines, clean them with a tissue or toilet paper and do the same for the ones on the circuit board (be sure to do it in the same direction as the lines) and put it all back together making sure the siny part of the plastic grid is facing you and that should fix it.
hope this helps
Posted on Jul 02, 2009
I have a Hiteker J704 tablet. I have a micro SD card with games from my pc. How can I access these on my tablet?
If the tablet has a micro sd expansion slot you might be able to run the games from there but you might have more success using a usb adaptor for the card and a lead with a usb socket at one end and a micro usb plug at the other plugged into the tablet.
The tablet should recognise the usb connection and invite you to download or run files just as a pc would.
Jun 26, 2016 | Tablets & eReaders
How do I connect the Irulu keyboard to my tablet, besides by plugging the mini usb into the port on the side? Because my tablet doesn't recognize, that it is even plugged in.
first of all, make sure that your tablet has an On the go USB port or data port if not, it can only be used to charge. If you connect our tablet to a computer usb port, and your computer recognises it, then you have a data port.
If you plug in a usb memory stick, and your computer can not read it, it does not have a USB to go port.
Also, some Cable adapters are On the Go wired, and may not work properly.
It may also be that the USB port is not providing enough power from the tablet to the keyboard. In that case, buy a split power usb cable, and plug the red (power only) into a usb charger or powered usb hub.
Apr 20, 2016 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
Replacement usb dongle
Most of these dongles interact with the software drivers installed on your computer.
Try reinstalling the drivers for the dongle and if that doesn't work you will need a new dongle.
Oct 18, 2013 | Genius M508w Wireless 5x8" Multimedia...
My Genius Easypen i405x cannot detect and sense pen pressure
I had the same problem. I have been using Win7. The solution is very simple: Uninstall your genius driver, restart your computer. Plug in the tablet, now the Windows should detect your tablet, wait a minute while the new drivers is installed. And from now it should work. Sorry for my English.
Jul 10, 2013 | Genius EASYPEN I405X 4 X 5.5 TABLET
Computer does not recognize the device
Plug your Tablet in first with Computer off, Turn on Computer and see if Vista recognizes the Tablet. Go by what is suggested on the screen. It may help to do a Hard Disc DeFrag. before attempting the above.
Sep 15, 2009 | Genius G-Pen 4500, 4x 5.5 4x 5.5 tablet...
My Genius Graphic Tablet has a short in the USB cord just past the USB plug. Any chance that I could replace this myself and where would I find a replacement part
In the cord or the usb port on the tablet?
Cord:
Easy replacement at any store that sells usb cords. Just look for a usb adapter with a usb part that matches what goes into the tablet.
Sep 10, 2009 | Genius MousePen 8x6 (MOUSEPEN8X6)
My genius mousepen 8x6 tablet had some connection problems lately. Though it worked with my laptop just a few weeks ago, it doesn't work anymore, at all. The laptop doesn't even recognize it. I've realized...
i have the same problem and i think this tablet doesn't work with windows xp service pack 3, because when i had service pack 2 i used it and after the upgrade it seems broke.
Aug 03, 2009 | Genius MousePen 8x6 (MOUSEPEN8X6)
Oct 11, 2008 | Genius MousePen 8x6 (MOUSEPEN8X6)
Tablet Pen not working
I have a G-Pen 340 which i just bought and the pen isn't being registered on the computer. The green light isnt even flashing :( I dont know whats wrong with it.
Jul 27, 2007 | Genius G-Pen 4500, 4x 5.5 4x 5.5 tablet...
Computers & Internet Logo
Top Genius Computers & Internet Experts
micky dee
Alun Cox
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
