Question about Radio Shack Measuring Tools & Sensors
Radioshack weather radio - Radio Shack Measuring Tools & Sensors
HOW DO I GET INSTRUCTION MANUAL FOR NEXA WEATHER STATION
NEXA KL4883 Wireless In Out Weather Station Barometer RadioShack com Didn't you get a User's Guide with it? Did you even do a search first before coming here? Did you think about going to their website? I did and found the User's Guide and it took 15 seconds.
Mar 02, 2015 | NEXA Weather Station Radio with In/Out...
Need Radio Shack weather radio Cat. No 12-521 manual
Step 1:
CHECK OP (Check Operation) means your radio has not received any type of
SAME alert signal (include test or demo signals) for about 10 days.
Make sure the antenna is fully extended and the stored location is correct. See
"Programming Locations and SAME Codes" on page 9 for more information.
Step 2:
Here is a link to the manual
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/1200521_PM_EN.pdf
Dec 06, 2012 | Radio Communications
I need to program a weather scanner for a pro 2018 weather scanner from rdio shack
Weather frequencies are factory programmed into the PRO-2018. Just press the weather button to start scanning them. You can also program one or more manually if you wish. For a list of NOAA weather broadcast frequencies, follow this link:
http://www.nws.noaa.gov/nwr/indexnw.htm
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69290.pdf
Bill B
Sep 05, 2010 | Radio Shack Pro-2018 Scanner
MY RADIOSHACK NASCAR PRO-84 SCANS THREW CHANNELS BUT STAYS STUCK ON ONE CERTAIN WEATHER CHANNEL AND WONT CONTINUE SCANNING AND I NEED TO NO HOW TO DELETE THAT CHANNEL COMPLETELY.
The NOAA weather frequencies have constant broadcasts, so your scanner "locks" onto them. The only ways to prevent this are to either delete the weather frequency or lock it out. To delete, just program the frequency "0.0" (zero point zero) into the channel. To lock it out, press the L/O key while on the weather freq.
Bill B
Aug 06, 2010 | Radio Shack Pro-84 Handheld Scanner
Radioshack pro 2067 will not recieve anything
Make sure its your local weather channel, turn squelch to minimum, get your local frequency at www.RadioReference.com ...hope this was helpful...
May 26, 2010 | Radio Shack Pro-2051 Base Scanner
How to program weather radio 12-262. Lost manual we live in Charlotte,mecklenburg NC
Here is the website to receive your owner's manual-http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/1200262_PM_EN.pdf. I hope I got the right manual for this model.
Jan 30, 2010 | Midland Weather/Hazard Radio with SAME...
Need manual for a radio shack public alert radio.
Manuals for most Radio Shack/Realistic products are available on their web site, www.radioshack.com
Bill B.
San Antonio
Apr 18, 2009 | Freeplay Energy Hand held S.A.M.E NOAA...
Measuring Tools & Sensors Logo
27 people viewed this question
Top Radio Shack Measuring Tools & Sensors Experts
 steve
steve
Are you a Radio Shack Measuring Tool and Sensor Expert? Answer questions, earn points and help others
