Question about Sony Grand WEGA KDF-70XBR950 70" Rear Projection HDTV
Sony KDF-70XBR950 green light flashes 6 times then goes red and flashes 6 times
When I power on the light flashes green 6 times then goes red and flashes red 6 times
experttv
  • 203 Answers
SOURCE: Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Posted on Sep 14, 2008
SOURCE: Sony KDF-55xs955 TV will not turn on. Red LED flashes 6 times.
Where is therm fuse location
Posted on Jan 30, 2009
  • 184 Answers
SOURCE: KDF-55WF655 Sony TV red lite flashes6 times
The thermal fuse has opened. Unfortunately, its likely that the ventilation system of the TV has been blocked by dust or other foreign matter. The cyclone fan mounted above the lamp housing is prone to this type of accumulation. Check for evidence of overheating in the lamp, lamp housing, and especcially the red wires going to the lamp socket. If they appear scorched, its a safe bet it got very, very hot.
To bring this TV back to life a new fuse needs to be installed, all the fans need to be cleaned, the lamp ballast board may need to be replaced as well if the wires appear to be damaged. Also, if your lamp is not new, it should be replaced too. Botton line here is cost. If you call a service company out, expect to spend a minimum of $300 and as much as a $1000 or more.
Keep your eye out for class-action lawsuits being filed on these TVs. I've seen a few of these actually melt the plastic lamp cavity to the point where it may catch fire.
Posted on Feb 20, 2009
SOURCE: red light blinks 6 times
i have the 42" same problem, i took it down and dusted it out thouroly , light air presure or blow dryer should work havent had the shut down light flashing problem since
Posted on Jan 30, 2010
  • 3 Answers
SOURCE: I have a sony KF-42WE610. When I go to power it
More than likely it is the G1 board or Thermal Fuse. I replace the thermal fuse and it is still giving me the 6 blinking red lights. Thermal fuse is $40 and cheapest G1 board I have found on-line is $120. I am about to pull the trigger on the G1 board and give it a shot.
Posted on Mar 04, 2010
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
I have a pioneer pdp-r05XE, on the plasma, the light flashes green and red alternately whilst on the receiver it flashes green 6 times. I can't get the tv to turn on...
Unplug if you have not done so BOTH units from power for several minutes (any cable or satellite box also connected.
wait several minutes and restore power to all units which may allow them to reboot.
Cannot hurt and may help.
Dec 06, 2012 | Televison & Video
LG 32LC56
that problem is usually cause of faulty T-con board..
Aug 25, 2012 | LG Televison & Video
LG 32LC56 back light on no picture
hello..
That problem is usually cause of bad t-con board..
just replace it to fix the issue..
Aug 25, 2012 | Vizio L32 32 in. LCD HDTV
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
Jun 22, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
Problem with KDF-70XBR950 TV. The TV won't come on. The power light blinks green for a few seconds than it blinks red for a while until it turns solid red.
How many time it blinks will tell you what the error is. This site will provide you with the service manual and on page eight of it will give you the list of blinks vs problems.
http://www.givemefile.net/smanuals/lcd_tvs/sony/file/8935.html ) ( The middle of the page is the download link "Download SONY service manual KDF-60XBR950 KDF-70XBR950 repair manual" )
May 05, 2011 | Sony Grand WEGA KDF-70XBR950 70" Rear...
Sony Grand WEGA KDF-70XBR950 70" Rear Projection HDTV Logo
51 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
