Question about Boating
Barrel is bend
Berrel is bend up like arching
Beemans sportsman rs2 trigger system not engaging after the break barrel been bend goes blank
Do you mean that you have never been able to cock the rifle ever
Like get the piston to lock up to the sear if so
Return to where you purchased it and get them to sort it
Mar 17, 2015 | Optics
Adjust jubilee bracelet
You bend it , literally take hold of the inside arch and bend it with your hands in not out this shortens the , the length and helps it close .
Oct 02, 2014 | Rolex Lady Datejust 179173SRJ Watch for...
Looking for a 30 inch hr topper model 58 full choke berrel
No idea this is a american old car with a monster carb so try a classic car site dedicated to this model/make of vehicle
Nov 03, 2013 | Cars & Trucks
Mercedes c 200 n/s rear wheel is hiting the wheel arch
check the suspension arm for bends that allow, the wheel to be in the wrong position when it comes up into the wheel arch. It will be a suspension arm or mount point that has moved .Have a wheel alignment shop check the suspension for you
Mar 20, 2013 | Suspension & Steering for Mercedes-Benz...
It will not heat up, maybe tip needs to be cleaned, if so how? I lost the manual. Thank you..
I am assuming that you installed a new tip. Note, the tip ends have to be 3/8 of an inch 90 degree bend so that when you insert the tip leads into the barrels, they go into the small holes in the barrels. Also note, the nuts to tighten the tip into the gun have to be installed onto the tip leads before bending the leads. Now when the tip is installed this way, the nuts tighten and hold the tip in the barrel. This tightening of the nuts allow the tip to have a good electrical connection to the barrels and this is what allows the tip to heat. You actually have an electrical current that passes through the barrels and the tip. It is a very low voltage (around 2) but a very high current. Over time the tip will not heat, this is a sign to either tighten the nuts, or look at the tip to see if it has a break in it. If it has an open, then it is time to change the tip.
Feb 12, 2011 | Weller 8200 Soldering Gun
When i break the barrel it doesent catch.
Try to clean the barrel and make sure there is not an object jamming the spring.
May 27, 2010 | Crosman Phantom .177 Caliber Break Barrel...
Recently cleaned unit. now i am getting arcing on
The arcing sound comes from a loose fit. You may have to bend the contact bar so it fits tightly against the unit.
Feb 28, 2010 | Ecoquest Breeze AT Living Air Purifier
Color bending
Go into the menu and look for Screen Convergence. It may also have an auto convergance option try that first. If it gives a suto error or you cant adjust it manually the convergance IC's may be bad or a component on the convergance board.
Sep 15, 2007 | Sony KP-51WS500 51" Rear Projection...
Boating Logo
41 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
