Question about HP Deskjet D2545 InkJet Printer
Hp d2545 lights blinking dimly
Will not turn on.
Drivers side turn signal blinking fast other side normal, bulb change didn't help
Even after bulb change, do all lamps work? Bad ground can be shown by weak or dim bulb sometimes and this can cause fast flashing. All bulbs which flash must be working and of normal brightness which is sometimes hard to tell when they blink really fast.
Feb 27, 2015 | 2006 Lincoln Town Car
"Printer Door Open"
Uninstall then re-install the printer?
Apr 23, 2012 | HP Deskjet D2545 InkJet Printer
I had low ink and changed the ink cartage but i still can not print. also a light is flashing it looks like a tear drop. this is on a HP Deskjet D2545
Go in to your HP solutions center and click maintenance. Click on clean printer nozzles. If the printer was low for a while the nozzles may be clogged with dried up ink.
Jan 01, 2011 | HP Deskjet D2545 InkJet Printer
I have a Hp printer model D2545. It prints out
I'm having the same problem... have you been able to fix it?
Nov 20, 2009 | HP Deskjet D2545 InkJet Printer
D2545Deskjet HP printer come on but itwon"t print
hi, i work for a company who is the dealar of hp products in suriname.
you have to install the drivers of the printer.
if you don't have it you can download it from the hp site:
www.hp.com
when the page is open go to support&Drivers
Apr 17, 2009 | HP Office Equipment & Supplies
My HP Pavilion dv5000;s monitor is blinking!
This is a possible problem with the inverter that powers the back lighting panel or it could be the power adapter connector on the latop.
Wriggle the power connector which plugs into the laptop, if the LCD screen flickers then the power connector is faulty or needs resolderng (repairing).
Jan 28, 2009 | HP Compaq Pavilion dv5000z Notebook
HP Deskjet D2545
There is no envelope accessory. You feed your envelope in a slot just above the paper tray. There is usually a graphic on the tray to show you how to orient the envelope to get it printed correctly. Your word processor program should have an envelope printing utility. Hope this works for you.
Oct 19, 2008 | HP Office Equipment & Supplies
Power light dims when inserted into 6110 xi won't turn on
Spoke with HP support...they said software program and printer out of warranty so a new one was purchased....am I a ******?
Thanks
Jul 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Deskjet D2545 InkJet Printer Logo
Seeker5211
Seeker5211
