Question about Xincom XC-DPG503 (859273000053) Router
DeviceModel: DPG503 FirmwareVersion: Ver 3.3 Rel 02 Description: We are adding VOIP phone service through our DSL ISP - Speakeasy. The phone requires a Dynamic IP and a DHCP server. The instrument is a Linksys IP Phone #SPA942. The DHCP server has been enabled in our router. Our WAN 1 is a static IP and WAN 2 is dynamic. There are enough places in the IP Range and I can see the status as "offer pending" but the phone is not makingits network connection. UPnP is enabled with 30 min Advertisement Interval We use a 16 port hub in addition to the router. Can you offer any guidance or participate in a remote session in an effort to establish the correct router configurations that would permit IP phone use ? Thanks Mark Antin
  • 1 more comment
  • mark_antin Jun 18, 2009
    IP phone has been cold booted.
    Router has not been powered down due to numerous
    24x7 processes.
    Wired connections only.
    No WiFi.
    IP phone and ISP expect DHCP connection.
    Sergeant:
    Champion:
  • 226 Answers
If the rect of your system is hard wired. what you might need to try is disconnect the router from your server for about 2min,unplug the power to the router,if this router has a backup battery remove that as well,connect the voip wire while off. reconnect your router to your unit with backup battery out(if so equipt) turn router on.this should reset and recognize.the new terminal.lf so then put battery back in. If not you should call your IP provider,you may need to do a reset through them.hope this help's
Posted on Jun 18, 2009
    President:
  • 1,383 Answers
First check your wi fi router mac security is enabled?
And also check that router is configured as WEP?
Let me know.
  • kishor
    kishor Jun 18, 2009
    okay.
    so chec kin your ip phone that in ip phone ip addreses getting automatically.
    Also reset it.some times reset fix problem.
    Aslo give ip phone manual ip assigning and test it woirks or not?
  • kishor
    kishor Jun 18, 2009
    Also check in ip phone that ethenret enabled in network setings.
    Brigadier General:
  • 3,614 Answers
HI there,
For clarification:
did you try to reset the device and the router installed on your place?
better to reset them both to make another pairing/connections to the DHCp server.
Let me know
I have landline home i have dsl 1mb i want if i connect telephone dialtone with linksys device then i can operate pc or iphone any where in the world
It is not possible because you need an ISP provider like a DSL or other type.The telephone line is only for voice not data.
Mar 20, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
Tip
How to reset your VOIP modem
If you are having trouble connecting to the internet, please try these steps.<br /><br />1.Unplug the power to your modem. This is the box from your cable or DSL provider. <br /><br />2.Unplug the power to your VOIP phone adapter. If you don't have one skip this step. <br /><br />3.Unplug the power to your router. Wait 45 seconds, then Plug in your modem and wait for lights to stabilize on a specific pattern. (Usually takes about 1 minute) <br /><br />4.Plug in your VOIP phone adapter (if you have VOIP service) and wait until you have a dial tone on your phone again. If you don't have VOIP or know what VIOP is, skip this step.<br /><br />5.Plug in your VOIP phone adapter (if you have VOIP service) and wait until you have a dial tone on your phone again. If you don't have VOIP or know what VIOP is, skip this step. <br /><br />You may need to restart your computer for this to work :)<br />
on Mar 16, 2011 | Computers & Internet
Windows cannot find any networks on a HP530 Laptop, the wireless works only when manually connected
Your router is likely configured to not "Broadcast" its SSID name. You need to reconfigure the router to broadcast the SSID.
Mar 15, 2011 | Computers & Internet
I recently moved from Cable ISP to DSL ISP service. For the DSL service, I was asked to configure my Router to use PPPoE with Dynamic IP addressing. I also provided the router with my username and password...
The reason you have no internet is because the router is specifically for cable. your description contains errors what i think you mean is that you have gone from cable dsl to an adsl, correct me if i am wrong. Basically your modem connected to your router via an ethernet cable and then the router fed the wireless signal to your wireless devices or via ethernet through the 4 ports in the back. With adsl you have a feed from your phone line to an adsl modem so the only way for you to get the dsl router working is to have two ethernet leads connecting to your pc, one from the modem to the pc and one from the pc to the router. You would also need to setup internet sharing on the pc thats connected to both devices.
Either do it that way or buy an adsl router
Nov 10, 2010 | D-Link DI-624M Router (DI624MRE)
Home Computer Network Confusion
it easy plug your big plug rg 45 cable from the 2010 into your port 1 on your router then buy more rg45 cable from comp store plug it into port 2 then into comp 1 plug another one into port 3 on your router and plug it into other comp. everything should work xp will pick up and install anything needed. have fun surfing
Sep 30, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Calls cutting out with magic jack
Your ISP connection speed may be inadequate. Typically, the upload speed (outgoing voice) is much slower than the incoming speed. To check majicjack recommends that you test your system on http://www.speakeasy.net/speedtest/ .
It's also possible that your internet provider is purposely delaying the outgoing latency in order to discourage VoIP that THEY don't provide. I think this is (or at least should be illegal) but in any case a complaint to the FCC might be in order.
Aug 23, 2009 | Computers & Internet
SPA942 IP Phone d/n work with Linksys WRT54G
You must have a voip router from your voip phone company (vonage,t-mobile). It should not work at all unless you have one of these devices. Hope this helps
May 03, 2009 | Linksys SPA942 IP Phone
DSL loses signal during VOIP call.
hi,
i worked for verizon for two years and I encounter this problem many times,to tell you honestly,its not with you internet connection since if you'll notice,while you are connected to the internet and you make a call or call someone,its interrupted... Obviously,its the phone itslelf,the signal comng from the phone is different from the signal of the internet...thats the reason why you need a modem to convert the signal coming from the phone line to make it work for internet,,,what I suggest is you change the DSL plan from the Dry Loop to the regular dsl with the phone...
thanks and God Bless
Mar 20, 2009 | Westell Wirespeed LiteLine 6100...
My linksys BEFSR ver.3.1 S/N C2140DA22073, constantly drops my internet cinnection after a few minutes of none activity.
Do you use DSL for your connection?
DSL uses a phone line for the connection, and therefore if your ISP doesn't detect activity after a few minutes, it will drop the line. There is a setting called "keep alive" in your router which will automatically either redial or 'ping' your ISP to make sure this doesn't happen. It's in the basic setup screen; if you're using DSL enable it and set it to 1 minute.
May 28, 2008 | Computers & Internet
Telephone connection
what router is it its a voip router like vonage
Oct 17, 2007 | D-Link AirPlus DI-524 Wireless Router
Xincom XC-DPG503 (859273000053) Router Logo
113 people viewed this question
Top Xincom Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Xincom Computer and Internet Expert? Answer questions, earn points and help others
