Question about Brother HL 5250DN Laser Printer
I love this printer but it just started making a loud cheap plastic cracking sound as some roller turns. And the paper light goes on. But there is nothing stuck in it. Any idea what this is?
    Problem Solver:
  • 5 Answers
This will work.
If you remove the paper tray you'll notice a black arm hanging down in the middle of the printer...this should be up inside (the cause is too much paper being put in the tray then when the user tries to remove the tray it hooks this and causes it to be in the way of the paper when it rises).
Disconnect the power and remove the toner/drum. Turn the printer upside down and remove the rollers from the purple plastic arm (shove the arm ahead to make this easier). Once you have this disconnected and removed you'll be able to see where the black plastic arm should go. You can push it back up in the printer without too much fuss. Replace the rollers where they go and put everything back together. Voila!
This has happened twice in the past year and both times this has fixed the issue right away. Good luck! :)
Posted on Jun 23, 2009
  • 37 Answers
Make sure the paper has not been pushed up too hard against the front of the paper tray. This machine has a motorised paper lift mechanism and this can cause it to make the loud cracking noise if it cannot lift the paper correctly. It can end up breaking part of the main chassis, so check it ASAP!
Could be many other reasons, such as seized toner cart etc, but check this first.
Posted on Jun 18, 2009
Keep getting out of paper error and paper wont feed makes loud grinding noise
A screw or something else is in the printer not allowing the gear to move freely.
Apr 22, 2015 | HP C6280 Photosmart All-in-One Printer...
Hp 4L printer won't pickup paper from tray. Sequence- green led light- motor running but with grinding- no movement from pickup roller or foot- finally a misfeed led light.
That is a very common problem with the Laserjet 4L and 4P printers. The sound you hear is caused by a broken motor drive gear. This is a small plastic gear on the drive motor shaft. They can develop a small crack which prevents the motor from turning the gears for paper pickup and toner movement. When the motor tries to turn the broken gear can not turn the other gears and makes the popping or grinding sound when the gear teeth slip. You will need to replace the motor gear, it is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_49&products_id=61
I hope this helps,
BuddyMc
Jul 16, 2012 | HP Office Equipment & Supplies
Half inch of paper goes in and paper gets stuck
Sounds to me like the pickup roller is shot. These are somewhat easily removable and cheap to replace. However, you can usually eek some additional life out of a pickup roller by cleaning it with rubbing alcohol or even water (no soap, though). Let it dry and replace it and see how you do. The service manual found HERE should help you get through the take apart... and it's really not that hard to do it yourself.
The part number for a replacement roller (if that seems to be the issue) is: RG5-1940-000CN. There are many vendors online who can sell you this part for a few dollars.
Feb 07, 2010 | HP LaserJet 5L Printer
Brother MFC 8220 -- paper keeps getting stuck in the drum. Replaced drum but still happening. Makes a loud noise when trying to print.
sounds to me like your fuser gear has broken. look for your exit rollers. they're right where your paper exits the machine. while watching them closely, open door, then close so that machine goes through its little warmup. if you don't see those rollers turning, chances are very good that your gear has broke.
hth,
razors
Feb 01, 2010 | Brother MFC 8220 All-In-One Laser Printer
Machine started making a loud clicking sound and wont copy
fuser roller gear is cracked... or a spring holding the bypass is loose
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 11, 2009 | Sharp AL-1641CS Laser Digital Copier
Copier - Paper does not feed/paper jam light keeps going on.
Depending on the type of machine, it is probably just dirty rollers that pick up your paper (slipping). If you remove the tray, and look inside you should see some rollers (usually gray) that take the paper from the tray. Use a cloth dampened with some alcohol(if you have it) or simply water to clean these rollers (gently).. dry if you have used water, the top sheet or 2 of previously used paper, and try it.
Jan 23, 2009 | Office Equipment & Supplies
Squeeking
The squeeking sound usually is in the fuser area
open the fuser roller area( clear paper jam the rollers are hot wait until it cools down get some spray silicone(similar to wd 40 with a plastic tube to reach small areas spray small amount on any e
xposed gears(plastic ) do not spray the fuser rollers
if you see nay other moving parts give them a light spray
turn back on and see if sound has stopped
If not try to determine when squeeking starts
then spary appropriate area
Dec 29, 2008 | Canon ImageClass D880 Copier
LOUD clicking sound and no print
plz give me a solution when i gave a print command there is two light one is green and second is orenge light this two lights are constend so plz give a solution.
May 04, 2008 | HP LaserJet 1020 Printer
Samsung 1710 stops after warm up
Chances are, you're getting paper jams.  Try cleaning the rollers (as indicated below.)  If that seems to help the situation, then you'll need to get new feed rollers.
Look where you put the paper in. See if you can see inside there and see the roller that turns and picks up the paper. If you can, make a mixture of alcohol and a little dish soap. Damp a rag with it, and reach in there to clean the rollers.  See if the rollers will turn manually, but be careful not to force anything.  Another way to get to the whole roller, would be to start making a print, while watching the rollers.  As soon as the rollers have turned half way, unplug the printer.  Now you can reach the other side and clean that.
There is another way to clean the rollers.  Using the alcohol mix, take a single sheet of paper, and damp one half of it with the solution.  Stick the single sheet in the paper tray, and make a print, but hold on to the paper so that it doesn't feed through the machine.  Do this several times, and the rollers turning against the wet paper should clean them.
Try to print again. It might take a few tries. The rollers have to turn against the paper and dry themselves off again.
If this works, then you need new rollers (cleaning them will only make them work temporarily and the problem will come more frequently until you change them).
Thankyou,
Oct 29, 2007 | Samsung ML 1710 Laser Printer
My New ML-2010 creates a loud annoying sound!
Ok, it is good you checked for paper jams. I need you to look inside the unit where the paper roller is on both sides and see if both sides look even and the same. It still sounds like a jam to me, and this would definitely create a loud sound as your unit is trying to print for you and the mechanism will keep trying to turn even if it can't. Something may snap or break if there is a jam so make extra extra sure you check every nook and cranny as jams can be so very tiny. I found a piece the size of a matstick width in mine that my toddler had posted in it, and it was caught in the paper roller teeth inside the unit. When you open your printer, does the cartridge holder roll by itself to the left or stay still??? Take out the toner cartridge and thoroughly clean inside with solution and replace.
Aug 16, 2007 | Samsung ML 2010 Laser Printer
Brother HL 5250DN Laser Printer Logo
243 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
