Question about Boating
Champion spark plug chart
I need a replacement for a champion spark plug QLI6V
  • 138 Answers
SOURCE: Spark Plug for Briggs & Stratton Engine
you'll need a champion J19LM [or RJ19LM, same plug except the RJ is a resistor plug]
Posted on Aug 21, 2009
ZJLimited
  • 17970 Answers
SOURCE: where can i find champion A-6G spark plugs for my 1986 Ferrari
Check the "cross reference:
Champion / NGK
A6 / DR8EA
A6G / DR8EIX
Visit here 1986 FERRARI 328 GTS 3.2 V8 F105CB FI
Good luck.
Posted on Sep 04, 2009
  • 12650 Answers
SOURCE: I have a lawn mower that needs a spark plug. I
reason for different plugs are because motors require different lengths ,temperature,design etc-it may run now but if its to long-or short can cause engine problem or damage-same for hot or cold can burn valves-or carbon up valves or plug -change it to the recommended plug mower will last longer with correct replacement parts
Posted on Mar 13, 2010
Molson02536
  • 3854 Answers
SOURCE: 2002 Chrysler PT Cruiser 2.0L need spark plug gap
It is normal for the electrodes to wear as the plugs age. This increases the distance between the electrodes which in turn leads to a gradual increase in the firing voltage required to jump the gap. The gap on a standard spark plug grows about 0.00063 to 0.000126 inch for every 1,000 miles of normal driving, which means the firing voltage requirements creep up about 500 volts for every 10,000 to 15,000 miles of driving.
The OE Champion plug gap specifications are .048 - .053" or 1.24 - 1.37mm. in accessing and changing the plugs on the PT. They have the same gap specifications as the OE plugs. Most owners gap at .050. We prefer to use the Champion Double Platinum plugs, which are more durable, provide extended plug life, and reduce the need for maintenance, given the difficulty However, if you experienced excessive rough idle with your last set of plugs we suggest gaping the OE and DP plugs to .042 and consider replacing the OE plug ignition wires.
Excessive gap can cause performance and drive ability problems, including hard starting, an engine miss and or hesitation under load, and can shorten the life of the plug (accelerated tip erosion). If it were me I would re-gap them to the correct specs if they are currently gaped at .060.
Thank you for using Fixya.
Posted on Apr 13, 2010
vincob
  • 718 Answers
SOURCE: have misplaced my owner manual.
.030 inches Good Luck!
Posted on Aug 14, 2010
A champion plug 12jyc what moter will it fit in
plugs for 350 block , 4 barrel carby 1967-19710 is j12yc
all plug descriptions have a series of letters number and letters..you can download the champion chart from the champion plug site
it works like--- this any plug that will screw in the hole will provide a spark
you have to measure the thread length in the head as the plug thread cannot be longer or shorter that that length
next the sealing is by taper or copper gasket so the plug will require the same as is in the head ( flat or taper ) whether the electrode protrudes or not depends on the application ( High speed engine etc)
there are factors that come into it as well like the heat range ---cold plugs for new engines and hot plugs for worn engines to burn the oil
Mar 13, 2017 | Cars & Trucks
Can I replace my Champion CJ2Y spark plug out of my Paulon chainsaw with a Champion EZ start 5861 plug?
Find a spark plug cross reference chart online and lookup your application.
Oct 02, 2014 | Garden
Spark plug gap settings chart
The spark plug gap depends from the engine make/model, not from the spark plug type.
Usually all engines will run with a gap between 0.7 and 1.00mm
Jul 30, 2014 | Champion Spark Plugs Marine Spark Plugs...
What spark plug replaces motor craft spark plugs in 4.6l 24 valve v8
Almost all plug manufsctures cross reference plugs.. just look up your car on a chart for the manufacturer that you want to use.. such as champion, AC, Bosch ETC.
Jul 29, 2014 | Cars & Trucks
gap is defined by motor your putting the plug in
Jul 17, 2014 | Champion Spark Plug / Champion/rl95yc
Gap setting for spark plug. champion rcj7y
30 should be yours if your trimmer is 10 years of age or less
here is a chart for further reference on spark plugs
http://www.spark-plugs.co.uk/pages/technical/champion_symbol_code.htm
Jul 07, 2011 | Echo Garden
What spark plug for 6.5 intek edge briggs and stration engine ?
The spark plug is:
RC12YC (Champion)
Use this chart to see of your spark plug gap is 0.020 or 0.030.
You will need the engine number.
Thanks for choosing FixYa,
Kelly
Jun 03, 2011 | Garden
I want to switch from champion rj12yc to E3 diamond fire spark plugs.witch E3 spark plug number?
The crossreference charts say to use an E352 to replace your Champion spark plug.
http://www.e3sparkplugs.com/pdf/e3autocross.pdf
But, I can't understand why you would want to use this plug. I use only Autolite spark plugs, the cheap ones. All the fancy high priced spark plugs are not going to increase you horsepower or fuel mileage unless your engine is running badly to begin with. If you're fouling plugs, you certainly don't want to start fouling these expensive spark plugs. You need to fix the problem. But, here's the information you asked for.
Good Luck
Steve
Jul 26, 2010 | 1979 Harley Davidson XLH 1000 Sportster
I have a 1998 cb250 (nighthawk)and need the code (item no.) no. of spark plug to be used. (Denso, champion) Thank you
Below are the stock plugs used by the factory. Both NGK and Denso plugs were used. You would need a cross reference chart to go to a Champion plug. Please rate my answer. Thanks.
Feb 25, 2010 | 1992 Honda CB 250 Nighthawk
Boating Logo
49 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
