Question about Music
Trying to use the yamaha djx 2 as a midi keyboard
5 Suggested Answers
  • 4 Answers
SOURCE: Yamaha 61 key keyboard midi usb connected but what next
Depending on what you want to do...
If it's only music Mixing, you will have to plug your keyboard via audio jack to the line in of your computer. Then Audacity (free soft) can do the job.
If you want to edit midi file with your keybord you will need midi editor software like Linux-Rosegarden or if under windows try LMMS (all free soft of course).
Good luck
Posted on Apr 27, 2009
  • 5603 Answers
SOURCE: i have yamaha PSR-i425 keyboard.can i conect it
Yes. You will need to have a MIDI interface on your OC and also select in the sounds control panel of windows that you are using the external synth. The MIDI will expect the PSR to respond to the "general MIDI" assignments.
Posted on Sep 08, 2010
jiantonyjose
SOURCE: I want Yamaha Keyboard PSR-2100 USB MIDI DRIVER
how to play with thumb
Posted on Oct 22, 2012
spraveenk759
SOURCE: my yamaha psre323 does not connect
I have a PSR-E323 and to connect it with my pc using a MIDI connector should i install driver from http://download.yamaha.com/usb_midi/ ??? I tried to install that.. An error msg popped up... error 25001 no device is connected. connect a device and try again. If the "found new hardware" wizard appears push the cancel button...What should I do?? Help me pls...
Posted on Dec 16, 2012
How to connect Yamaha per 630 keyboard tot PC connection to Yamaha per 630 keyboard PC
Assuming it is a pSr630 keyboard then there are 2 ways to connect depending on the computer you are using. The 630 uses 5 pin din midi in and out.
1) If you wish to connect to USB then you will need a USB midi interface such as
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=11173
or
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=5894
2) If you are connecting to a desktop with a 15 pin socket you can use a cable
http://www.beckettsmusic.co.uk/shop/scripts/prodView.asp?idproduct=18808
Your software then should recognise the input type in use and allow you to connect it accordingly.
Aug 09, 2015 | Yamaha Portable Keyboard
Which midi cable or USB midi cable should I use for Yamaha DGX 520 model.
It doesn't use a USB to MIDI adapter (such as the UX-16.) It has an onboard MIDI controller and uses a standard USB A-B cable. You just need to install the driver from the CD-ROM or here, and plug it in. You can get the manual from the same page or here. Setup is on page 99.
Oct 20, 2012 | Yamaha DGX520 Portable Keyboard - 88 Keys...
My yamaha psre323 does not connect
Apr 10, 2012 | Yamaha PSR-E323 Keyboard
Where can i find windows 7 x 64 drivers please help mee !!!
Your Yamaha DGX 203 Portable Keyboard - USB-MIDI Driver Version 1.2.2 ie. for OS Win9x/ME.
Yahama site does not have the Win7(x64) Drivers ie. USB-MIDI for your Keyboard Model DGX-203
But you can try the USB-MIDI Driver Version 3.1.0 for Windows(R) 7/Vista/XP 64bit for Model DGX-520 @ http://usa.yamaha.com/products/musical-instruments/keyboards/digitalkeyboards/dgx_series/dgx-520/?mode=model
I can't assured you that it will works on your system. Since your Keyboard is no longer in production, I doubt Yahama will provide you with the official USB-MIDI drivers for your Keyboard even you requested for it.
I guess this is an option you can try and hope it works & good luck.
Regards.
Apr 13, 2011 | Yamaha Dgx203 76Key Portable Keyboard
I cant connect my yamaha ypt 320 to my pc using the midi
Assuming you have a MIDI interface on your computer, you need to connect the MIDI cables between the keyboard and the PC. You cross connect, that is, in to out and vice versa. You will ALSO need the driver software for the interface in the PC AND most importantly, some software in the PC to handle the MIDI for instance to record.
Mar 27, 2011 | Yamaha YPT320 61 Key Personal Keyboard
How to connect psr-3000 to computer
You can connect it with USB connection to your computer. It should be plug and play, but some drivers might be required.
You can connect it also via MIDI interface: - you will need sound-card with MIDI input connector, or you can use special MIDI device like M-Audio UNO.
Mar 07, 2011 | Yamaha Full-Size Keyboard
I have yamaha PSR-i425 keyboard.can i conect it with my pc to play midi files stored in computer memory?
Sep 08, 2010 | Yamaha YPT400 61 Key Portable Keyboard...
Yamaha Psr-340
I don't have Cubase myself but there must be a track setting that allows you to monitor what you are playing live. Also make sure your keyboard shows up as the midi controller on the software. Your receive channel has to match the send channel of the keyboard. Make sure that synthA or synthB shows up as the sound source (audio out). XFi Midiport is your midi in but since Cubase already sees your keyboard your problem is an audio one not a midi one. Hope this helps.
Jul 18, 2009 | Music
Good luck
Oct 16, 2008 | Yamaha Portable Keyboard
Music Logo
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
