Question about Plumbing
How do I adjust Kohler faucet number 77809-aa
3 Suggested Answers
  • 25 Answers
SOURCE: My Kohler bathtub hot water faucet 77809-AA needs
My husband is a plumber. He says u need to pull it off with pliers. U need to just pull it off. It may take a couple tries, but it should come out.
Posted on Jan 04, 2010
propowerroot
  • 3 Answers
SOURCE: I have a kohler 77809-aa shower tub. The drain is clogged. How do you remove the drain. I see no set screws. But I do see a couple of pins near the top of the drain cap.
If you want to clear your clogged drain you do not need to take the drain cap off. First you need to remove the over flow plate, it's located right below the faucet and has two screws, then you need to hand snake the drain line from there.
Posted on Oct 17, 2012
Replacing hose on a Kohler model numbe K- 10433
http://411plumb.com/kohler-forte-faucet-troubleshooting-repair-guide/
Mar 11, 2014 | Kohler Model 10433: Fort® Single-control...
Kohler push pull kohler bathtub faucet will not turn off completely
The Drain handle can be adjusted under the sink, you can remove the retainer and adjust the lever.
Nov 18, 2013 | Kohler Plumbing
May 30, 2012 | Kohler Forte Single-Control Remote Valve...
How does the cartridge come out of the Kohler K 14030 single handle faucet?
Turn the water off to your Kohler K-14030 faucet under the sink. Open the the faucet to make sure the water is completely shut off. Remove the small setscrew cover from the backside of the faucet handle. You should be able to remove it by hand. Insert an 1/8-inch hex wrench in through the opening and into the setscrew. Rotate the setscrew counterclockwise three full turns; you do not need to remove it. Lift the handle off the faucet. Unscrew the bonnet nut, or cover, from on top of the cartridge retaining nut; counterclockwise until removed. This nut should be remove by hand as well. Use a large adjustable wrench to unscrew the cartridge-retaining nut counterclockwise until removed. Grasp the cartridge stem with pliers and lift it out of the faucet body. You may need to gently rock it back and forth until the suction from the seal ring releases.
Dec 27, 2010 | Kohler K-10430-VS Fort½ Single Lever...
Our Kohler Fairfax kitchen faucet 12176 has a difficult spout swing from side to side that I thought would get easier over time. It is installed on granite and when I use hot water is very difficult to...
was the base installed under the faucet..is there a single hole in granite...faucets usually come with a long base to cover the holes in sink..or with one round ring for granite installation..which the faucet should be mounted on..
Nov 22, 2010 | Kohler Fairfax Single Control Lavatory...
Replaced single handle shower faucet with rite
u hve to adjust the temprture ring i think u put it all the way so u lock it ,
Dec 25, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
My Kohler bathtub hot water faucet 77809-AA needs to be repaired and I can't get it off. I took the cap off and took the screw out, but it won't budge from there
Dec 22, 2009 | Kohler Plumbing
Kohler single lever kitchen faucet,no hot water
no its somthing in water filter rust or dirt in line.take apart and drain line. thank you for useing fixya please rate me
Feb 26, 2009 | Kohler K-10416-BN Fort½ Single Control...
Plumbing Logo
Top Plumbing Experts
Tom Chichester
Paul Carew
Are you a Plumbing Expert? Answer questions, earn points and help others
