Question about Casio G-Shock GW500A-1V Wrist Watch
New battery in GW500A and still flashes charging
How to charge a g shock
Facing direct bright sunlight (not behind a window or on a car dashboard) for several hours.
Mar 08, 2013 | Casio G-Shock GW500A-1V Wrist Watch
Flashing charge
I couldn't find your model on thier web site but this range appears to have solar panels to charge the battery. Place your watch in bright sunlight or under a lamp (not a hot one) to charge the battery.
If this fails, consult your nearst dealer.
Jan 05, 2012 | Casio G-Shock GW500A-1V Wrist Watch
My casio 2638 will not stay on, always in sleep mode, how long do i have to charge it?\
Chances are the rechargeable battery will need to be replaced, the average life span is 1 to 3 years.
Mar 11, 2011 | Casio G-Shock GW500A-1V Wrist Watch
No time , just the charge icon keeps flashing
The charging battery sounds like it needs to be changed and the watch tested, I suggest a watch repair facility.
Dec 31, 2010 | Casio G-Shock GW500A-1V Wrist Watch
I have a gw-500a and the battery got replaced with a brand new one, but my watch still says charge and it won't let me change the mode or anything. The time is on the screen though. Please help
You have to reset this watch after battery replacement. Using tweezers or something similar you have to touch the AC & - contact on back of watch, for 2 seconds. Hope this helps.
Dec 23, 2010 | Casio G-Shock GW500A-1V Wrist Watch
I have a Casio Shock Risist watch (GW-500A) that says "charge" on the display, that is all it shows. Does it need a new battery or what?
this watch requires no battery. It uses solar cells. my watch did this as well. to make the watch functional again my advice is to not wear the watch for one day and place it near a window that gets a lot of sun.
Nov 24, 2009 | Casio G-Shock GW500A-1V Wrist Watch
Does not hold charge no matter how long it is in daylight
make sure the solar panels are clean, if not you may have to take it in to a professional watch fixer, and the panels may have to be replaced, or a connection may have to be remade with the watch and the battery.
Oct 26, 2009 | Casio G-Shock GW500A-1V Wrist Watch
I just recently purchased a brand new Casio G-Shock GW-002KA 2913
if there is a black screen and shows chg thats mean your battery level is to low ////// so you must charge as soon a possible,,,,,,
Jan 21, 2009 | Casio G-Shock GW500A-1V Wrist Watch
Blank screen
if this is the same as my watch, it's solar powered and when it gets TOO LOW< it will blank out and begin to charge .  Stick it in direct sunlight for a day if you can.  You can also stick it under a regualr lamp, but it will never get fully charged, but it should be enough to operate at least.  The battery meter is the top middle dial on the face.
Nov 04, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Casio G-Shock GW500A-1V Wrist Watch Logo
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
