Question about Zee Manufacturing VS3018OA - 30" Wide X 18" Deep, Unfinished Oak Bathroom Vanity Sink Base Cabinet
18 inch wide unfinished oak bathroom vanity sink base
Need assembly instructions for kokols pedestal combo sink in clear
Is this any help?
https://sites.google.com/site/bathroomfurniturevanitysink/installation-on-vanities/glass-vanity-set-up-guide-kk09
Otherwise you could send them an email:
http://www.kokolsinc.com/pages/contact-us/
Apr 20, 2015 | Kokols Clear Vessel Sink Pedestal Bathroom...
We have the Kokols Wallmount Bathroom Pedestal Glass Sink Vanity Combo but the p-trap keeps leaking. How do we fix it?
Remove it, (Don't forget water will come out when you uncscrew it!!!) clean it thoroughly, especially the ends, clean and check seating of any rubber washers to make sure they are fitted correctly and not being distorted when the rings are tightened, reseat it with no force (it should sit naturally without having to force it in) and tighten rings. There are lots of videos on youtube showing how. If you cant stop it leaking buy a new trap. It's worth while looking very carefully for exactly where the leak is before you remove the trap, it might be coming from higher up. Repair Leaky Sink Drain Pipe
Jun 21, 2014 | Kokols Clear Vessel Sink Pedestal Bathroom...
How do you remove right hand drawer from foremost vanity?
Release the drawer glides by lifting tabs on either side.
May 12, 2014 | Senza Fresca Potenza Gray Oak Modern...
How long does a vanity need to be in order to install two sinks?
Taking into consideration counter space and plumbing space needed for two sinks, you will need a minimum of 60 inches to install two sinks.
Sep 04, 2012 | Belle Foret Furniture
How do I properly install my new bathroom vanity?
Pipelines and also Wrenches will certainly be needed for this action. For the simplest installation acquire a brand-new vanity and also sink that coincide dimensions as the old ones.
What are shelf bathroom vanities?
Shelf vanities are typically the most simple as far as style is concerned. They consist of a single shelf (or a few shelves) mounted near your sink and a mirror. This style is ideal for small spaces.
Sep 03, 2012 | Belle Foret Furniture
Im looking for large and long antique vanity for my bathroom
You may want to get the 3 or 4 sink antiquevanity. On the net you can try this website: http://www.bathgems.com/antique-vanities/on the right side you can sort the vanities by . Good Luck!
May 29, 2012 | Furniture
Installing a vessel sink
Standard Vanity height is approx 34.5". A vessel vanity is approx 31" high. If you cannot remove the legs from your existing vanity then it will have to be replaced or cut down to the correct height. The reason a vessel vanity is lower is because your sink will be approx 3 to 6 inches higher than a standard drop in sink. This may be more work than it is worth. Vessel sinks most often will require a solid surface top, either glass, stone or another type of composite material. The standard laminate vanity top has a particle board substrate which will detiorate quickly at the drain location.
Jul 07, 2010 | Buck 31" Granite Vanity Top for Vessel...
How do I contact Pegasus to obtain missing parts?
Pegasus is Home Depot own brand of bath room fixture. The contact number should be on the installation instruction or the warranty sheet.
you shold contact Home Depot if you cna't find the contact number.
Mar 28, 2009 | Pegasus Technologies Pegasus Pegasus...
Zee Manufacturing VS3018OA - 30" Wide X 18" Deep, Unfinished Oak Bathroom Vanity Sink Base Cabinet Logo
122 people viewed this question
Top Zee Manufacturing Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Zee Manufacturing Furniture Expert? Answer questions, earn points and help others
