Question about RTO Fillpro Anti-Siphon Toilet Tank Fill Valve
The water keeps running on my fill pro valve
Not sure its seems a little older valve.
2 Suggested Answers
bloues
  • 56 Answers
SOURCE: water seems to keep running very slowly, can't
Rossouw R. im a plumber.
Were the flexi hose go in to the toilet and conect up to velve thread tape. unscrew the flexi hose and then the plastick nut holding the velve on to the sistern.
put the new velve in and bobs ur uncel.
Its very easy, just look were the 2 seal rubbers are when u remove it, may be 1 rubber.
and the flout of the velve will be a cup or ball, thast ajast that tothe right water level, u will c were the flout or ball is on new velve there will be plastick with bumps un it [most commen] if not let me know bt around that area u should find somting to adjust the hight. sorry for spelling errors, im a plumber nt a english major lol
plz let me know if u get in a rut .that is realy the onley solution.
Posted on Jul 20, 2010
When flush my toilet, water keep running until i put my hand inside the middle and pull the float , then stop. toilet make is rapid sl
the ball **** fill valve is a poorly designed valve. replace it with a fluidmaster fill valve and a fluidmaster flapper. flappers do go bad after a year or ten depending on your water quality and choice of flapper but the fluidmaster fill valve will last a long time also. you can also get the water saver fill valve by fluidmaster and there is also a conversion set to change your toilet to a dual flush. all this is at lowes and there is a plumbing pro there to explain further. feel free to give me a positive rating. thanks!
Feb 15, 2011 | Home
The toilet takes a long time to refill after a flush would there be a certain part that is plugged or wore out ?
Is the flapper valve slow to return to the closed postion allowing water to flow through the flush valve? Make sure the toilet flapper is moving freely and is sealing properly against the flush valve. If there is no lengthy or continual water flow in to the toilet bowl then this is not the problem.
Is the water valve on the water fill line to the toilet tank fully open? This may seem silly but it could be this simple.
Check to make sure your fill valve is opening fully. If you have an older toilet there may be some deposits that need to be cleaned way to allow free movement.
If toilet does eventually fill to the desired level, there is no leakage, water valve on fill line is fully open and fill valve is opening fully then recommend you shut off water supply, drain toilet and disconnect water fill line from the water valuve and toilet tanke to make sure there is not a blockage. If the water line and connections are clear you may need to remove the fill pipe in the tank and check for blockage. If this is very old, conisdering the cost and effort, it may be simpler to replace at this time rather than trying to extend the life.
Jan 15, 2011 | American Standard Home
After the tank fills water contiues to flow thru
The fill valve needs replacement unless you can take the top off snd find out what is keeping it from closing. I had one I took apart for the same reason and found a piece of plastic in the valve seat. Good Luck, Ned
Nov 01, 2009 | Kohler K-11465-0 White Cimarron Comfort...
Asko D3530 water inlet fault code, water valve is on, water comes in but after water comes in for a couple of minutes we get a (inlet water fault code) check power at circulating pump no 120v unit will not...
It is common for these valves to "appear" to be ok, meaning they begin to allow water into the unit, but then one of the two coils or plungers inside fail, or are clogged with mineral deposit from the water or other debris.
Change the valve and you should be fine. part #1164471, you can find it at select parts depots or on-line retailers like repairclinic.com etc.
** Hire a pro or make sure to use a good replacement clamp on the fill line to the tub when you replace the valve, as well as some plumbers puddy/tape on the inlet fitting. Those little buggers have alot of water pressure going thru them when they open and I've seen them come off or leak due to insufficient fastening/loose clamps, then your machine goes into "flood mode".**
Asko seems to be repeating their past. On the earlier DW95 series (mid 90's to around 2000ish) they had a dual valve inlet which had a single valve rework issued to repair the faulty dual valves, now it looks like they're doing it again. Go figure.
Hope that helps, let me know.
Good Luck :)
Oct 28, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
No water coming out when I backwash. I cleaned
water level must be about the discharge (eyeball) in the pool to back wash. Check the hose connections to make sure that hoses off the the filer head are going to the right place Look for the words "Pump" , "pool" and "waste" molded into the valve. I've seen it a number of times where "Pump" and "pool" were connected the wrong way.
Jul 04, 2009 | Hayward SAND FILTER, PRO SERIES
Bosch Washing Machine Softener Tray not emptying
You need to replace the cold water inlet valve. If the machine is older than one year it may be clogged on the side that moderates the cold water to the bleach and softener compartment. Replacing the valve fixed the problem. During the cycle when the softener dispenser fills it should fill quickly and no or little water should be seen in the soap dispenser area. If a lot of water goes into the soap dispense and little into the softener area the valve is clogged.
Feb 15, 2009 | Bosch Logixx WFT 2806 Front Load...
Trigger not working correctly
You might need to de-scale the unit to free the stuck valve.
Keep the unit unplugged.
Fill the unit with a vingar and water (filtered or distilled is best).
Screw the cap back on and place the unit in a sink upside down to allow the vingar and water to reach the valve.
After a few minutes press down the trigger several time to work the solution into the valve.
Hope this helps.
Sep 15, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Keeps filling up with water
Hi, the water valve is defective, to make sur unplug the washer 117 electrical corde from the wall and look if it still fill up, if yes then u can be sure that the inlet valve is defective, juste replace the valve and ur home free.. wish u well, Alain
May 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Scotsman CM250AE Ice Machine tech help
Check the bridge size adjustment at the top of the metal grid that the ice forms on. This determines the size of the cubes. Whenever you make a repair on the water system, especially on an older unit. make sure the unit is clean. A little bit of calcium deposits (or that other nasty looking stuff) getting into the passage ways will make it run erratically, and can drive you nuts.
Nov 06, 2007 | Scotsman CSW45 15" Ice Maker with 26 lb....
RTO Fillpro Anti-Siphon Toilet Tank Fill Valve  Logo
59 people viewed this question
Top RTO Home Experts
Mike
Asian-gem
Asian-gem
Level 1 Expert
Gene Haynes
Are you a RTO Home Expert? Answer questions, earn points and help others
