Question about Vehicle Parts & Accessories
Exhaust backfire I have a 61 Vette with a new 350 crate. Backfiring only occurs when slowing down. Can't figure it out
    Scholar:
  • 161 Answers
Check the following: 1. cracks in the distributor cap. 2. Ignition timing and advance 3. plug wires and plugs could be bad. 4. If carbureted- the power valve might be leaking. 4. Valve rocker arms over or under tightened. 5. vacuum leak. - check with a gauge. 6. Cam timing off.
Posted on Apr 16, 2014
Backfiring on triumph st sprint 1999
After-market exhaust system or stock?
A lot of after-market mufflers don't cover up a backfire pop on over-run in the way that the stock system does. Look at The Marble Mod on GIXXER forums for ways to doctor the bike's emissions system to stop the popping.
Another cause of an over-run backfire may be a slight leak where the header pipes emerge from the cylinder head. Check the bolts are tight. Consider new copper washers.
Nov 14, 2013 | 1999 Galfer-2001 Triumph Sprint ST 955...
My 1994 Yamaha backfires after going down hill ,then when I touch the gas it backfires
Your timing is off. Backfiring occurs because the exhaust valves are open when the fuel is combusting.
Apr 24, 2011 | Sport & Outdoor - Others
2007 yamaha yz450f... while riding last week it was backfiring on deceleration. it blew a 5 inch hole in the header pipe. i purchased a new one, cleaned the air filter, changed the oil and put a new spark...
Exhaust leaks near the exhaust port can draw air into pipe on deceleration and detonate any unburnt fuel leaving engine, causing backfire and high temps.
An overly lean fuel mixture on the engine can make decel backfire worse too.
Mar 13, 2011 | Yamaha YZ 450 F Motorcycles
My 86 suzuki intruder 700 backfires out the exhaust at idle. and makes a tapping noise. i already did a valve adjustment an new plugs
It could be the speed of one carburetor is faster than the other. This causes the backfiring as well as forces one cylinder to run lean which causes the tapping noise. You will experience an identical tapping or "ping" when you get close to empty on main fuel and need to switch to reserve. Most likely you or the previous owner unknowingly adjusted the speed of the rear carburetor down because of the high stock idle not realizing the front carburetor needs to be slowed down to match. While running simply turn the idle adjust screw clockwise on the rear carburetor until the idle smooths out and the backfiring/tapping stops.
Sep 20, 2010 | 1995 Suzuki VS 800 Intruder
Hesitating on acceleration, also backfiring when taking your foot off the accelerator,approaching a junction.sometimes it will just cut out. if i turn the ignition off and restart it will be ok for about a...
Sounds like a vacuum leak in the motor. Backfiring may be its own problem altogether. Backfiring only occurs when cold air is being introduced into a hot exhaust stream or when the timing is off. Check for vacuum leaks under the hood and leaks in your exhaust. If you have a leak in your exhaust it could be interfearing with your emission sensors and giving your motor false information.
Feb 20, 2010 | 1999 Volkswagen Golf
Backfiring engine on slowdown from medium speed.
Two things cause this problem, ONE: Your timing could be out a little and the bike needs a good tune, or TWO: your exhaust is cactus.
Feb 04, 2010 | 2005 Hyosung GT 650
1992 Chevrolet Suburban 1500 350 backfiring and headers glowing
You probably have a clogged up exhaust system building backpressure on the engine. Check your mufflers and catalytic convertors if you have them something is restricting the exhaust.
Sep 08, 2009 | Chevrolet Suburban 1500 Cars & Trucks
My suzuki sp 400 backfires and it sounds like 'n misfire
hi mate try changing the spark plug and its backfiring because you have to much fuel going into the barrel and all of the fuel is not being burnt so some is going into the exhaust and when you let off the throttle it backfires so on the carb there are 2 screws 1 for idle and 1 for mixture the mixture is the one you need screw it in 1/2 of turn at a time until it stops backfiring ok a picture will demonstrate 3a5087f.jpg
Aug 30, 2009 | 1991 Suzuki DR 350 S
Frequent backfiring
Usually means it is a little rich, or it has a leak in the exhaust somewhere pulling in air when you are slowing down. Check for leaks where the pipes attach to the cylinders, or look for black smoke when revved up.
Jun 11, 2009 | 2005 Harley Davidson FXD - FXDI Dyna Super...
Truck backfiring willnot idle
Check your head gaskets. And your exhaust gaskets, you have blew one of the gaskets your head gasket will leak oil and your oil will look milky and watery. Your exhaust you are going to have to take off and see
Feb 07, 2009 | 1999 Chevrolet Silverado 1500
Vehicle Parts & Accessories Logo
53 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
